Question about Garden
Several months ago i had a drainage problem where the water was coming into my house. it was a bad pipe that was causing the problem. they had to did my front lawn up to take the old pipe out they replaced the pipe and filled the hole up.my wife had some landscaper come and sod our whole front lawn which they did a very good job i started watering the lawn and after awhile i noticed that the next day a found a part of my lawn had sunk making a pretty big whole.the hole was located where the area was dug up before to put the pipe in. i went to lowes and was told that i could use top soil to fill the hole i did and it worked util we had a bad rain and caused that area to sunk again what can i do to fill up the hole so it wouldn't sunk again and that i can put some more sod down in that area.
  • 417 Answers
hi,
they may not have fixed the leak or its leaking from somewhere else. make sure all the water is off in the house open up your water meter box and watch the water meter gauge closely to see if your leaking. use a strong torchlight to identify the leak.. if the leak is after your water meter, your paying for that leaky water seeping into the ground, if the meter is moving, I would have the company that fixed that pipe come back out and tell them your meter is moving when you have no water running in the house.if the meter is not moving then I would carefully dig it up to see exactly whats going on. if its not leaking at all then I would suggest some gravel first then the rest dirt.
good luck
jm
Posted on Oct 03, 2010
I have a faema x1 grandaitalia machine , the water coming out of the boiler is only getting to 33 deg can you send me or a diagram of hot water system thanks or tell me what to fix problem
Ope you mean from hot water spout if so several problems exsist as this machine has a cold mix system to bring the roughly 120c water from boiler down to roughly 94c to use for americano. check spout and descale hot water nozzle or see if any black/brown particals in defuser(fine mesh in spout)as boiler pressure is roughly 1.3/1.4bar and mains water is roughly 2/4bar thus cold water will win if black brown particals in mesh poosible boiler contamination causing restriction to which once again cold water will win. question did any one take any pipes apart about 5 months ago????? as there are restrictors within the system.
Aug 15, 2012 | Faema Coffee Makers & Espresso Machines
Water is dripping from the inside unit and not coming out of the drainage pipe outside
The reason the water is coming out of the unit and not the drainage pipe outside is for a few possible reasons.
1 -the drain pipe is clogged / plugged (due to calcium build up,or frozen)
2- the line is kinked or blocked.
check the drain pipe carefully, there may be obstuctions.
Feb 21, 2011 | Heating & Cooling
Model ck42-1a compressor won't come on. I replaced the intake filter about a month ago. It was a pleated filter and was real caked when I replaced this month. Can that cause the compressor to go out? I...
The fact the filter was very dirty and the door partly open allowing non filtered air to enter the system leads me to a possible dirty evaporative coil on the furnace. That can cause poor airflow and iced up coil reducing airflow even more. In the long run can damage the compressor to the point of failure.
Oct 18, 2010 | Goodman CKL42AR42 Air Conditioner
My WR 250 is a 2001 model I recently had it serviced but there is oil coming out one of the pipes that seems to be a drainage pipe leading from the head
check all your drainage tubes, my kx had a drainage tube that came loose and leaked all over my exaust and rear
Mar 17, 2010 | 2003 Yamaha WR 250 F
Sink dishwater intrusion
Hello- Find drain hose from dishwasher under sink. Should have gooseneck ~ in hose run to keep water from getting back into dwshr. Does full sink drained all at once push water into tub? Sometimes stuff not disposalled yet blocks drainage. Older motors can tend to become weak with age, not pumping as much water out of tub as it used to.Anyway- Hope this helps- ED
Mar 01, 2010 | GE Dishwashers
Water coming from indoor unit
The problem is caused by fine particulants such as dust, pet dander, etc. which mix with the collected condinsation water and forms a grey gel eventually clogging up the drainage pipe. The solution is to attach a wet vaccuum hose to the discharge end of the drainage pipe and vaccuum out the gel. It is advisable to flush the system by adding water to the a/c's drain pan while the vaccuum is still running.
Oct 07, 2009 | Mitsubishi Heating & Cooling
Water on floor under front of fridge
CHECK AT THE BACK OF YOUR FRIDGE IF THE DRAIN PIPE IS STILL ON THE COMPRESSOR. ON TOP OF THE COMPRESSOR THERE IS A BUCKET WHERE THE WATER FROM THE DRAIN PIPE RUNS IN. THE HEAT OF THE COMPRESSOR CAUSES THE WATER TO EVAPORATE.
Sep 07, 2009 | Refrigerators
Whirlpool dishwasher adp4407 wont start
be sure the door is shutting properly the door switch may also be bad
Apr 24, 2009 | Whirlpool 24 in. DU915PWP Built-in...
How to Clear Drainage Pipe?
High pressure water jets are good, but if you do not have the equipment, a large quantity of very hot water will do as well. This will melt the deposits and flush them down the pipe. I flush my home's kitchen and lavatory drains once a year with a large stewpot full of scalding hot water. This must be done with great care by someone strong enough to keep the pot under control. Wear a long sleeves and pants and a raincoat over to protect from splashes, use heavy mits and pour slowly. Take steps to make sure no children or pets can come near. Make sure your path is completely clear. Failure to take great care can result in a very bad burn. Done regularly, this maintenance can greatly reduce, or even eliminate, blocked waste pipes.
Aug 27, 2008 | Danze D495008PBV Polished Brass 1-1 / 2...
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
