Question about Canon Pixma iP4500 InkJet Printer
I have a Canon iP4500 and it has just started to show banding. It appears that a line is missed off approx every 7mm. I am using cartridges from Cartridge world and have done deep cleans etc. When I do a test print after each clean the test print is OK but prints show banding.
  • Canon Master
  • 3,083 Answers
This site has some suggestions for trying before spending any money:
http://club.myce.com/f7/canon-ip4500-banding-301454/
Sounds like the best advice, good luck, and hope it helps.
Posted on Oct 04, 2010
I'm having a problem with the ink magenta on an IP4500 Canon Printer, it's not printing any magenta even with new cartridges and I've done all the maintenance checks!! Help!
there are small metal spring contacts between the cartridge holder and the cartridge itself, these send the signals to the print head via the cartridge holder. Over time, as a print cartridge moves from side to side during printing these flatten out and no longer come into contact with the cartridge. Find the contacts behind your magenta colour cartridge and re-tension the spring metal contacts so they once again contact the metal faces on the cartridge. They maybe hard to find as they will be in the place where the cartridge goes, use the flat copper faces on the cartridge to give you a clue as to the position of the contacts in the holder.
Apr 16, 2012 | Canon iP4500 Photo Printer
I put in a new ink and my canon ip4500 came up with service error 5c20 and the orange light started flashing how can i fix it?
It has not detected the cartridges correctly or it has a waste ink problem, not sure which. Are they genuine Canon carts? I hope this helps will you let me know how you get on please?
reseat all the cartridw0zz_3.jpgges and read the attached which should work with the 4300 (thanks also to tech1569 for this)
Jan 26, 2011 | Canon Pixma iP4500 InkJet Printer
I have cleaned and deep cleaned the printer a number of times but when I do a print check the yellow line does not print neither does the black line under it print. When I print anything else the yellow...
If a line doesn't print, the ink is out of the cartridge for that inkjet cartridge color. Replace the cartridge. Deep cleaning can use a lot of ink up at a time.
Nov 11, 2010 | Canon Pixma iP4500 InkJet Printer
Copier appears to be functioning well, but page comes out blank
You actually answered your own question, you said it started fading and came out with lines missing. Looks like and could possibly be that the ink cartridge you are using wasn't as full as you thought it was, and the computer really has no idea, it's just software and i do not recall seeing sensors on the inside of the ink tank to tell the computer how much ink is in the cartridge. Try refilling the ink again or maybe a better idea is to buy a new cartridge since over time the cartridges can get contaminants in them which will block the ink from the inside of the cartridge.
Hope this helps
May 31, 2010 | Canon PIXMA MX310 All-In-One Printer
Colors missing on Canon Pixma
hi,
since you are ready to find a replacement if this doesn't work, you can try a few things by yourself.
see if the the jack connecting the printhead to the ink cartridge holders is intact(it is a source of many problems in these type of printers)
also. if there is too much heat emanating from the printer during use, its advisable to chuck it.
cheers
Jul 24, 2009 | Office Equipment & Supplies
When refilling canon ip4500 cartridge they still show empty
I'm sorry you got that STUPID answer first. The Canon cartridges you use have a chip or small circuit board on the bottom front. You have to either reset that chip or get the reset chips from the place you get your ink. That little chip tells your printer how much ink has been used and once they are empty refilling doesn't help without a new or reset chip.
Jul 18, 2009 | Canon Pixma iP4500 InkJet Printer
Canon ip4500 flashing yellow light
Check for improper cartridge installation. Change the cartridge(s) if the problem persists. It's a pure catridge problem ok. Good luck
Apr 27, 2009 | Office Equipment & Supplies
Canon PIXMA iP4500 Cartridge changing
http://software.canon-europe.com/software/0032530.asp?model=
There u go! you will find the users manual there, its a zip-file, download it, extract it and read it:)
Good luck
Nic
Apr 15, 2009 | Canon Pixma iP4500 InkJet Printer
Ink not working
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | Canon Pixma iP4500 InkJet Printer
Canon Pixma iP4500 InkJet Printer Logo
158 people viewed this question
old marine
old marine
