Question about Cisco Linksys E2000 Advanced WirelessN Broadband Router Network Routers
I purchased a Linksys E2000 wireless router. With my old Linksys router, my 2 wireless pcs were getting a 270mbps connection. The new one will not go any higher than 144.5. Is there some setting I need to change? Thanks.
  • David Zieber Oct 04, 2010
    Hello...I followed the instructions you sent, but, I'm still stuck @144.5. Anything else I might try?
    I've got it figured out. Thanks in part to your help, and in part to just some "experimenting" on my part. Thanks for your help.
  • 4,281 Answers
First make sure your wireless local area connection support to 270mbps speed. make sure compatible driver is inastalled for wifi lan. Then if every thing on computer is fine then you need to access your router. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless settings change channel type to 3 or 6 or 111 by 1 then save settings and restart router then check..Set channel type which gives best speed. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Oct 04, 2010
  • On your router configuration make sure wireless configure as access point in 802.11 B+F+G standard then check.
    If all settings are perfect then it is your new router limitation .
Where is the security key on a cisco linksys E2000
if you enter into the configuration mode of your linksys,go to wireless and in security the section for enter the passphrase or key is what your router is asking for.copy that and use it.
Oct 27, 2012 | Cisco Computers & Internet
Need Driver for the Linksys E2000 Advanced Wireless-N Router? Where can I download?
You can Find the Downloads Here
http://homesupport.cisco.com/en-us/wireless/linksys/E2000
Mar 06, 2011 | Cisco Linksys E2000 Advanced WirelessN...
Wireless laptop will cannot connect to the internet through the e2000 router. Wired connection works fine. Flash drive setup for wireless connection was also used.
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
There a great article at General Router Setup.
Feb 18, 2011 | Cisco Linksys E2000 Advanced WirelessN...
My acer aspire one netbook will not connect with my new linksys e2000 router.. It was fine with my former linksys router
If your former linksys router was NOT N but rather b/g, then the problem is likely that your new router is running N and must be reconfigured to run b/g instead of n on its wireless. The acer aspire one netbook's integrated WiFi is 802.11b/g and the only way to do 802.11n is by using a plug-in USB 802.11n wireless adapter. To manually configure the router's wireless for 802.11b/g or n...
1. Connect the netbook using an ethernet utp cat5 patch cable between one of the four RJ-45 LAN ports on the router to the 10/100 ethernet RJ-45 port on the netbook's left side.
2. Start a browser like Internet Explorer and enter IP address 192.168.1.1 (default for Linksys)
3. On the login window, enter admin for username and admin for default password, then click OK
(The password may be changed if the router's setup software on its CD has been run.)
4. On the Linksys Setup page, click the Wireless tab
5. On the Linksys Wireless page, for Network Mode, click v for drop menu and click BG-Mixed
The preceding is from Chapter 3: Advanced Configuration which starts at page 16 of the 59-page Linksys E2000 user guide/manual. If you are missing this manual, it can be obtained by clicking...
http://homedownloads.cisco.com/downloads/userguide/E2000_UG_USA_V10_NC-WEB.pdf
A final note: The easiest way to setup the router is to run its setup software on the CD that comes with it. If you want to do this with the netbook (which doesn't have an internal CD drive), an external CD drive would have to be plugged into one of its USB ports.
Jan 25, 2011 | Cisco Linksys E2000 Advanced WirelessN...
Cisco Linksys E2000 Advanced WirelessN Broadband Router Network Routers Logo
575 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
