Question about Bose 901 VI Main / Stereo Speaker
Connecting the 901 series VI equalizer
Thanks for the manual, it should help. However, it is still not clear to me how the switches on the front panel will work simultaneously. If I hook up the equalizer to the tape 2 monitor connections, then choose any of the other buttons (CD, FM, AM, Tape 1 monitor, etc) the Tape 2 monitor (i.e., the equalizer) is switched out of the circuit and does not apply to the other input sources. I am assuming the receiver front panel switches are mutually exclusive. I'll post the results when I try to connect a receiver to the speakers. I need to purchase one first. Thanks again.
sk
    Problem Solver:
  • 18 Answers
Hello
please make sure your receiver has a tape monitor switch on the front panel or pre-in/out sockets at the rear. only then all sources will play thru the bose equalizer. also remember if you need a 5.1 or greater setup, you will need 2 amps/receivers.
hope this helps
Posted on May 27, 2008
How do you hook up the Bose 901 series VI to a Harman Kardon AVR 510 receiver?
Search Fixya for the dozens of times I have answered this type of question. The central theme is you will need a separate power amp for the 901's and use of the Pre-Outs.
http://audio.manualsonline.com/manuals/mfg/harmonkardan/avr_510.html
Aug 22, 2011 | Bose 901 EQ1915 Home Equalizer
The Bose 901 series V speakers originally came out with brushed aluminum side panels. I have seen several set of series V speakers with wood side panels. Did Bose offer both aluminum and wood side...
I've passed your question on to person (camino3x2) who posted a good article on eBay.
http://reviews.ebay.com/Bose-901-Speakers-A-primer_W0QQugidZ10000000001314034
If you're registered with eBay you could ask him any other questions.
I have series V's with brushed aluminum side panels. As you probably know, a 901 system also includes a series-matched Active Equalizer which must be used with it.
Jan 06, 2011 | Bose 901 VI Main / Stereo Speaker
I have a Harmon Kardon AVR 247 and I want to connect with Bose 901 VI equalizer. No other speakers are connected, just the 901's. Where do I connect the wires from the equalizer to the AVR 247...
I have this exact setup. 901s are my Mains.
The AVR247 has PreOuts on all of the channels.. No jumper to remove either. Just get a power amp or two and place the 901 EQ between the AVR247 and the Power Amplifier.
Jeff
Nov 28, 2010 | Bose 901 VI Main / Stereo Speaker
`Which ampliphier is compatible for my Bose 901 series 6 with equilazer.
Ideally, an amplifier or receiver should have either a "Tape Monitor" selector switch and Tape Input & Tape Output jacks, OR have Preamp Output & Amp Input jacks to enable insertion of the Bose Active equalizer into the circuit before the amplifier stage. Power requirements - according to the 901 Series VI manual:
"Your 901 speakers are designed to work compatibly with receivers or amplifiers rated from
10 to 450 watts per channel."
If you have questions not answered by the manual, you can contact customer service at The Bose Corporation in Framingham, MASS toll free at:
1-800-999-2673
Hours of operation:
7 AM - 2 AM ET, 7 days a week
I hope this helped & good luck!
Nov 22, 2010 | Bose 901 VI Main / Stereo Speaker
Bose 901 series speakers to Bose 901 Equalizer
There is no direct connection between the 901's and their Active Equalizer. It is designed to be inserted between the source and the DEDICATED amplifier driving the speakers. Typically, this would be in a Tape Monitor loop on a receiver.
Tape Rec/Out to EQ In; EQ Out to Tape Play/In on the receiver. If you have a tape deck(s), it(they) would go into the back of the Bose EQ as if it was the receiver and you would use the Tape and 1/2 buttons for selection.
Or,if you have access to any other point that doesn't use the Tape Monitor, like a Pre Out/Main In jumper set, place the Equalizer there. That way it's always in front of the speakers and doesn't take up the Tape Mon.
Flip in the Tape Monitor and leave it on or the speakers will not receive the essential ACTIVE Equalization they require for proper frequency response. DO NOT place non-901's onto any amp using the Active EQ.
Like any speakers, the 901's will attach to the speaker terminals in the conventional manner.
Apr 12, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
BOSE 901 ACTIVE EQUALIZER
i, trying to hook up a powered subwoofer to my hafler dh 110 and dh 500 running a bose 901 series v active equalizer and series v 901s any info would be appreciated
Mar 15, 2008 | Bose 901 VI Main / Stereo Speaker
Connecting Bose 901 Series VI Direct Reflecting Speakers to JVC RX-8020VBK Receiver
in order to make those speakers sound good (if they can sound good at all) you need to use equalizer box witch came with them. If your receiver does not have tape monitor loop or preamp to amp jumpers you can not use those speakers. To be honest you do not loose much... none of this stuff is any good (sorry for bad news), but if you like those speakers (I know they have big fans, even if in HI-FI world, they not consider as good) you have to change you receiver. Dariusz
Feb 13, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 VI Main / Stereo Speaker Logo
193 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
