Question about Boating
I have a yamaha 2 stroke 3 cylinder carbureted 90 hp outboard , when i start it the taco reads full rpm even when it is only idling , what is my problem
  • 2 more comments
  • jethrodog Oct 04, 2010
    the taco only has electrical wires on it
    about 1990 i think
    has picture of oil can in lower centre with low level mark on left of it and high level mark on right ,on the back , has 3 wires at top rear black , green , yellow also light bulb stuck in back and 4 wires at bottom black with brown spot yellow with brown spot red with black spot and green with brown spot
  • jethrodog Oct 05, 2010
    hi removed green wire taco read zero , when motor was cranking over taco went up to full rpm, is there meant to be voltage on black wire..thanx
  • 1,711 Answers
On the tachometer back you have secured a wire thread just like the one from the brakes of a bicycle. The other end of the wire is secure to the engine. This wire complete, need to be replaced.
As a test first disconnect it from the tachometer and see if ok if not then the problem is with tachometer.
Posted on Oct 03, 2010
  • 3 more comments
  • espressonist
    espressonist Oct 04, 2010
    which model and year please
  • espressonist
    Also how is your tacho,with oil, temp other, just note what informtions on the tacho front.
  • espressonist
    You should try to remove only the Dark Green wire from tachometer. Start engine and see if the tachometer now shows zero. If it still full RPM the you need a new tachometer.
    Below is a link with multifunction kit which includes the wiring diagram for you. This will help you a lot.
    http://www.mbcboats.com/perfbull/YamahaM...
    http://www.mbcboats.com/perfbull/YamahaMFGaugeKitInstall.pdf
  • espressonist
    Ok try the procedure we have already sent.
  • espressonist
    espressonist Oct 05, 2010
    No you just need a new tachometer, is not very expensive for your case.
    We have here a link that has some tachometer but you can also check other places before buying a new one.
    http://www.lowcostboatingstore.com/TELEF...
    http://www.lowcostboatingstore.com/TELEFLEX-63473P-STERLING-TACHOMETER-0-7K_p_435.html
Hard starting on Yamaha 130 2 stroke. Always starts easily with ether. Choke works well.
This can have some reasons:
1 clogged carburettors. Too less fuel means a hard start.
2 Worn spark plugs
3 Loss of compression... On a 2-stroke, measuring compression is not an exact science. Have throttle wide open. No spark plugs, check compression on all cylinders. They should be all within 1bar from eachother...
Aug 02, 2017 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
Have 115 Hp mercury outboard motor missing at full throttle and on idle. At mid throttle it is running fine. Any Idea what the problem could be. Thanks, Milton
Have your spark plugs changed AND carbs cleaned and adjusted.
Usually that can also be caused by a seized advance system ( plate under the flywheel, commanded to turn with the throttle linkage... )
Aug 16, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
115hp 1985 yamaha outboard 6e5 AETO running at low revs as if on 3 cylinders,on low revs only when i accelerate it goes well and fast without issues,when i slow to trolling speeds it runs a bit rough...
sounds like a bad coil or trigger. Find the offending cylinder with a timing light and physically move the coil to a good firing cylinder. If the problem follows the coil, you have it, if not you need a trigger,
Nov 09, 2012 | Clymer Marine Maintenance and Repair...
Free Mercury Outboard ONLY, 2-40HP 1965-1989 Repair Manual 1-2 Cylinder, 2 Stroke
I have a problem with my 2 stroke 20hp mercury 1989,when I run 10-90% throttle it's works fine but when in 100% its only runs in 90% and doesn't sound normal like it's not burning right.
May 11, 2012 | Seloc Mercury Outboard Engine Repair...
Yamaha 30 HP 3 cylinder 2 stroke
pull the spark plugs and see if they look like there burnning the same if so then i dought its a spark issue and if it was in the lower unit u wouldnt here a loud anything it sounds like a rod bearing i have had the same thing happen to several yamahas under a load
Jul 06, 2009 | Light Outboard Motor Boat Bass Fishing...
40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Apr 27, 2009 | Boating
Boating Logo
705 people viewed this question
Top Boating Experts
ray gallant
Bill Boyd
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
