Question about Home
My Triton Power Shower AS2000X hs gone faulty when i switch the pullcord power on it trips the fuse, I have disconnected the shower and the fuse does not trip any ideas, cheers Adam
  • 44 Answers
SOURCE: Triton T80si shower will not switch off
its the water solenoid valve stuck in the open position so when the shower is turned off the shower stays running
Posted on Dec 15, 2008
  • 44 Answers
SOURCE: triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
  • 150 Answers
SOURCE: I HAVE A JADE 11 ELECTRIC SHOWER WITH A PULL CORD
Renew the pull cord switch
Posted on Apr 10, 2010
heatman101
  • 43501 Answers
SOURCE: tripping breaker
Yes, there is an internal short... this is not repairable... likely the element has gone bad...
heatman101
Posted on Aug 04, 2010
SOURCE: My Triton Millenium shower just
there is a cut out unit on top of the element *** unit which is to prevent damage to elements if the water supply fails but i have 3 of these fail down to use have checked the triton spares and the only show it with the element unit cost over £100 you can bi pass it with out any problems just make sure always turned off at pull cord when not in use or phone to see if you can just buy the cut out if you cant its shame on them good luck spares number 08449800745
Posted on Jan 24, 2011
My Triton shower Eco Excite 8.5kW keeps tripping fuse when turned on !!
Could be a pump jam, do you have hard water ? Could be scale build up.
Is the shower head blocked ? Unscrew just the head (leaving the hose line attached to shower) and try again. If that is the blockage, then clean it with descaler.
Also check you have a good pressure on your water supply going in the Triton. Low pressure can set off safety switches. Again, check for blockages.
Check also for breaks in wiring and check there is no water ingress at any and all connections.
Is it an old unit ? Is it serviced regularly ? .......finally....
are all the settings set to MAX ? if so then use lowest setting first.
If it works then move settings up gradually until it trips.
Any filters need to be checked if possible.
Good luck Red.
Jul 16, 2016 | Home
I have a triton t100xr shower as soon I press the on switch the power keeps tripping off, please can you help?
Chances the trip switch is not high enough,as in it may need a higher amp than what has been installed.You should be able to check this out by looking at the fuse board.If memory serves me right it should be 40 amp.Check this out in the paperwork that came with the shower. If not contact Triton, they are most helpful & easy to deal with. Their number can be got on Triton site. Be VERY careful when touching any wiring either @ the fuse board or the shower.
Apr 24, 2014 | Home
Triton jade 3 running cold
Sounds like you have an instant hot water system... (no hot water tank) if true, check that fuse.
Jan 12, 2014 | Home
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
My Triton Millenium shower just stopped working mid shower. Power lights went off. Have checked fuse, power ok but will not switch back on. Any ideas.
Jan 10, 2011 | Home
No hot water
Check your fuse/breaker, should be a rcd switch. Depending when the shower was installed the fuse/breaker may be separate from the main fuse board, if it is an rcd switch it should be between 30A and 40A rating. If it is still fuse wire or cartridge fuse it should be replaced by residual current device.
Remember to turn the shower off in the bathroom before returning power to it.
Hope this helps
Apr 10, 2010 | Home
My triton martinique electric shower low pressure light comes on and the water goes cold but there is nothing wrong with the pressure
I had a brand new Triton Rapide 3 with this issue, we had good water pressure but the light on the front would keep coming on.
I found there was a micro switch located at the front almost dead center of the shower, couldn't miss it when you removed the cover. A plastic arm below this switch is raised when the water pressure increases tripping this switch and allowing the heater to come on.
I found two things wrong with this, one this plastic leaver was thin and bent easily and secondly the switch did no line up overly well with the lever. Easily fixed, I cut an inch off the end of a zip tie or panduit strap, and super-glued it to the top of the lever (not the switch as the glue will probably ruin the micro switch.) 5 minute job later and with the shower back together it works beautifully. My wife will be happy, you wouldn't believe the torrid of curses I got this morning having only replaced the old unit last night.
Probably don't need to say this but, make sure you isolate the power before removing the cover.
Jun 03, 2009 | Sony Playstation 3 (PS3) Console
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Home Logo
153 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
