Question about Minolta Office Equipment & Supplies
Minolta 5000 coppier showing C0072 trouble code. what's the proublem and how do I cancel the code? Help and thanks.
Don't understand the Franch, so it means nothing to me. can someone translate to English? thanks
Posted on Sep 03, 2008
Engrenagem do motor do frasco de toner quebrada.
trocar revelador.
limpar ATDC
limpar ima do frasco de toner
limpar o sensor maguinetico da caixa reveladora
trocar o rolo de alimentaçao de toner
Posted on Aug 31, 2008
C0072 copy error
The error code C0072 deals with the toner hopper. I would remove the toner bottle and close the front door and wait till the copier comes to ready and make a copy, if it works install the toner and see what happens. The problem may be in the toner bottle holder.... There is a "HP" sensor that may be dirty or broken. Good Luck
Nov 05, 2013 | Minolta EP4000/5000 CS/PRO Copier
Code c0072 at Minolta ep 4000
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the cover and turn on the machine. Let the machine go through it normal routine. IF code appears open close front door,When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Sep 23, 2013 | Minolta EP4000/5000 CS/PRO Copier
Minolta ep 5000 error c0072
A C0072 error code deals with the toner bottle. Remove the toner bottle and close the front door and let the machine warm up. Make one copy and install the toner bottle again. The toner holder may have not been in the correct position. If it continues, you may need to call a service person. Good Luck
Dec 07, 2012 | Minolta Office Equipment & Supplies
I have received code C0072? what can I do to
The toner bottle is in wrong, take out the toner bottle and close the front door. wait until the motor stops running or until the copier asks for toner. open the door, the bottle should go in with the hole up.
Jan 27, 2010 | Minolta EP4000/5000 CS/PRO Copier
Minolta 6100 displays message C0072
Are you certain it is a Minolta 6100? The only 6100 I am aware of is a Magicolor 6100 color printer. My service manual for that model lists no service code C0072.
C0072 is a common Minolta copier code which pertains to the toner add system. I had a service call the other day for C0072 and it was the toner cartridge not fully "locked" in to it's receptacle, so you can start there. Opening and closing the front door on most Minolta's will reset this code.
Good Luck
Oct 21, 2009 | Minolta Office Equipment & Supplies
Minolta c0072 code, hopper or toner?
C0072: Sub Hopper Toner Replenishing Motor M9’s
Failure to Turn
Sep 03, 2009 | Minolta EP4000/5000 CS/PRO Copier
Copier Minolts ep4050 error code C0072 +
C0072 is aerror code for the sub hopper unit. It is having a hard time adding toner or that the toner motor is ON for to long. It is having a hard time kepping up with the ATDC. The M2 is a counter, it can be reset in service mode, but major parts have to be replaced to clear it..
Mar 25, 2009 | Minolta EP4000/5000 CS/PRO Copier
Minolta 5000 copeir
the only code that i see in the service manuel is : c0070, c0071 and c0072
All of these's code refer to the toner replenishing, check if your bottle of toner is correctly position....
To make sure, take the bottle out and close the front door, the copier replace the mechanism correctly, after that replace the bottle to it's position and close the front door....Please let me know !
Mar 27, 2008 | Minolta EP4000/5000 CS/PRO Copier
98 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
