Cutting blades are broken need replacement where can i purchase new cutters
    Genius:
  • 1,218 Answers
You don't say what make or model..try to "google" the manufacturers name and parts.
Posted on Oct 05, 2010
Not sure of the model number but my paper shredder was purchased on Jan 16 of this year and quit working the middle of July except for the reverse mode. I need help.
no
we don't sell anything
there is something stuck in the blades
in the middle of the cutters there is a small plastic lever that is the micro switch for the forward action . paper is stuck and that lever is now not operating the microswitch to drive the cutter motor
either that or the lever has broken off, again not activating the micro switch
If you want repairs or warranty , contact the manufacturer direct by phone
Aug 17, 2016 | Omnitech 12 Sheet Cross Cut Shredder
How to replace thread cutting assembly
contact a sewing machine shop in your area ask them about the cost
Nov 14, 2015 | Brother InnovIs 4000D Computerized Sewing...
I replaced cutter blade on Elna PRO DC 5. New blade won't cut fabric. how do I adjust it?
All sergers have 2 blades. Just like scissors. Only 1 blade of scissor is sharp = not good cutting.
Feb 14, 2014 | Elna 1010
Are bolt cutter blades really sharp?
A pair of new or freshly sharpened bolt cutters will be sharp enough to cut through skin if you run your finger along the blade. Never run your finger along the blade to check for sharpness.
Nov 14, 2013 | Cutter Tools
What is the difference between the angle cut blades and the shear cut blades on my bolt cutter?
angle cut blades have the cutter head angled at 25-35 degrees for easier insertion into tight spots. Shear cut blades are light normal scissor blades
Jan 16, 2013 | Cutter Tools
Locked in blade
My old Cuisinart has this problem because the motor shaft and the corresponding socket on the cutter are worn. The shaft has jammed in the cutter. To un-jam it, stick a bar of wood behind one blade of the cutter (I use the wood handle of my dough whisk) and give it a light, sharp tap with a hammer. Check after every tap to see if it is loose, if not do it again. You want to tap against the back side of the cutter, not the cutting edge side. The socket on your cutter may be cracked, allowing it to open up and slip (and jam) under the stress of cutting. You'll probably need a new one. If the motor shaft is also worn, that can also be replaced. The new part is about $10. I got a few more months of life from my cutter by reinforcing the inner socket with a thin plastic tube from the barrel of a syringe.
May 15, 2010 | Cuisinart DLC-5 Food Processor
Cutters on Elna 744 serger won't cut
is there lint or thread caught between blades preventing them from meeting?
scott
Jul 26, 2009 | Brother 929D Mechanical Sewing Machine
Husqvarna Sapphire - thread cutter not working
Does the metal arm come out to grab the threads to cut it? Is there a blade in the metal arm that cuts the tread? I think a standard utility knife cutter blade is the same size (just like the one that cuts the bobbin thread when you put in a new bobbin). What happens when you activate the cutter is the arm comes out, grabs the threads, brings them to the blade which cuts the threads, the velcro by the cutter holds the bobbin thread in place for the next stitch. Otherwise the thread may end up on top and the top thread would not be able to pick it up for the next stitch.
Good luck.
Jun 27, 2009 | Husqvarna Viking 1
29 people viewed this question
k24674
