SOURCE: OS X 10.5 Leopard & Canon PIXMA MP510
hi i am a certified Canon repair tech for this printer. if you follow the link below this will take you to Canons support site where you can download the software for your printer. hope this helps
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
SOURCE: The printer is stuck in fine (photo print) mode - how do I get it back to normal tex printing?
go here for instructions:
http://www.canon.ca/product_reg.asp?lng=en&pid=315&pname=PIXMA+MP750&pr=0&shlink=http%3A%2F%2Fcanoncanada.custhelp.com%2Fcgi-bin%2Fcanoncanada.cfg%2Fphp%2Fenduser%2Fstd_alp.php%3Fp_li%3D%26p_page%3D1%26p_prods%3D15%2C288%26p_pv%3D2.288%26p_cats%3D0%26p_search_text%3D%26p_new_search%3D1%26p_search_type%3Ddflt%26p_sort_by%3Ddflt
SOURCE: Canon MP510 prints uneven lines.
I assume that you've cleaned the nozzles and alignment utility. Try wiping the carriage bar with a lint free cloth dampened with rubbing alcohol. Also, the paper feed rollers may have collected some "goo" and should be cleaned with the rubbing alcohol. This should clear the problem.
SOURCE: my canon mp510 has problems printing
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
SOURCE: Canon MP510 wont print. Error message B300 or
May I know the exact error messages in the printer screen. If it's green and yellow lights that are flashing you need to push more the two cartridges that you replace....also try to clean it using the printer program installed in your computer....good luck and hope it will help....
