Question about Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot No. 4705814. No memory space. Card is Ok! What can I do to fix?
  • Sony Master
  • 4,924 Answers
First get the card out and check not to be blocked from he side slide button ...and after that insert it on a card reader of a laptop or desktop ..and see if there is anything on it ...or if it is full...If it is full download the picture either using the cable ...and driver ...or just by copying the pictures from the card ..
If you know that you did not make enough pictures to fill the card ..it means that the camera is not set to store the pictures on the card ..but it is still storing on the internal memory and this is the reason that it is showing no space ..even if you know the card is large enough ..
After being sure the card is not locked and it is not full ...go to shooting menu ..(press menu in shooting mode) ..and choose the last feature -setup...
in the set-up you will have choices for internal memory and card memory ...choose the card ...and format it ..but be sure that you downloaded any picture from it first cause this will erase anything that it is on ....
after format ..choose in the same option for memory card the copy ..item ..and this way you will copy on card all the pictures from the internal memory ...and after that the camera will store to the card ..
If you knwo that you did make many pictures and this cased the card to be full ...be sure you downloaded them all..and after that do like I explained and format it ..this will erase and format and will be ready for to take pictures again ..
Posted on Oct 03, 2010
My Sony Cyber ShotDcs-P10 tells me no memory space when I only have 7 photos loaded??
That is its built in memory. It has a low memory normaly. Try inserting an additional memory card to the camera.
Oct 07, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
No memory space in internal memory. What does this mean?
This camera has small internal memory like 32MB to store few pictures and shows no memory space message after storing these few picture files.
You need to insert memory card in camera and go to menu and select Copy option to copy internal memory images into memory card then take out memory card from camera and delete internal memory pictures one by one or perform format memory to delete all of them at once.
Sep 30, 2010 | Sony Cyber-Shot DSC-W5 Digital Camera
My Sony Memory Stick PRO Duo says there is no space on the memory stick when I insert it into my Sony Cyber-shot but I've deleted everything I can find on it. How can I fix this?
Hi! YOu will have to reformat the memory stick via pc. When you insert it on the pc a new drive will appear. Right click on the drive and click format. This should fix it, if no luck.... then i believe that the stick is faulty and may require replacement. Hope this helps and have a good one!
Jul 02, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
I shot alot of pictures on my sony cyber-shot W55 and when i wanted to view them it says file error
It may be a problem with the memory card. Try the card in a card reader or another sony camera. If it works ok then, you've a camera problem.
If it fails also, it's a card problem, the files are corrupted somehow, the only thing in this case is to re-format the card in you camera, it will be one on the menu options.
The trouble is, when you format, it clears every thing off the card.
Another way is to buy a spare memory card, always handy, if that work ok straight away, again your first card has a problem and probably needs formatting.
Apr 30, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
No memory space on internal memory. How do I fix
Stop using the internal memory and insert a memory card.
Dec 27, 2009 | Sony Cyber-shot DSC-W180 Digital Camera
No memory space memory stick
Yes reformat and try again this should take care of the issue, Please rate me I am not compensated to answer free questions I rely on your rating so if you could please rate me accordenly.. Thanks
May 15, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
DSC-T1 model has no internal memory and it requires memory card due pro to store pictures.
Oct 24, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Wrong memory card size insterted
Opening of your camera would not be good because memory slot has very very little space in it and you can't do any thing, use tweazer to pull out that memory card.
Jun 20, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Sony Cyber-Shot DSC-P41 Digital Camera "no memory space"
you can download the manual for this camera from here
http://esupport.sony.com/perl/model-documents.pl?mdl=DSCP41
click on "Operating Instructions"
good luck - Robert
May 11, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
How to clear my memory stick
This camera has both internal memory and allows use of Memory Stick Duo type cards. To format Memory Stick Duo, choose "Memory Stick Tool" and then "Format" from main camera menu, hit "Ok". Choose "Create REC Folder", hit "Ok".
Apr 26, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
22 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
