Question about Lenovo ThinkPad R51
R51 thinkpad display problem
R51 thinkpad spontaneously cropped display to the left 3/4 screen horizontally and a double image, as if 2 desktop screens one on top of another, with the bottom one showing 1" to the right. On external monitor, all is ok. computer works well. Any ideas? Thanks.
  • grenon May 29, 2008
    Thanks, However, the screen at times comes ok, but mostly it is showing the above. The problem comes on even before windows logs in. Hence it is felt that this is a bois problem. I tried to reset bios o default but it helped only once and by next day, it was back. Any suggestions different? Thanks.
  • grenon May 31, 2008
    Yes, it works perfect with am external monitor.
  • 100 Answers
I think the LCD screen is not working properly. The only solution is to replace it.
You can find replacement LCD screens for IBM R51 here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Pantallas%20portatil%22
Posted on May 28, 2008
How do i change the screen from vertical display to horizontal
The IBM ThinkPad Z61t computer runs the Windows operating system. Normally, Windows is displayed on a monitor in a manner that makes it easy to read. If you want to change the screen display configuration (from vertical to horizontal), modify the screen display properties in Windows itself. This process causes the computer to rotate the image displayed on the screen by 90, 180 or 270 degrees, depending on the setting you choose.
1.Right-click on an empty portion of the Windows desktop on the Z61t.
2.Click "Properties."
3.Click "Display."
4.Click "Change display settings."
5.Click the "Orientation" drop-down window. Select the "Landscape" option to make the screen display items in a horizontal manner.
Sep 19, 2011 | Lenovo ThinkPad Z61t Notebook
Hello, my IBM Thinkpad R51 gives 4 beeps and won't start up. Can you help me?
1.check ram
2. check processer
3.check display connecter&display
please vote me and rate it
Sep 11, 2011 | IBM ThinkPad R51 Notebook
IBM Thinkpad R51, screen went dark. At the right screen angle, I can see some light from the windows and cursor, but very faint. At that light angle I can maneuver the mouse and click on windows, so all...
The problem
1 The LCD screen is out or
2 The invertor board behind the LCD screen is out or
3 The backlite is out
You have 2 options
1 To use an external monitor for the time or
2 get the laptop fixed by a tech shop
Nov 18, 2010 | IBM ThinkPad R51 Notebook
Why did my picture become big so I can not see the sideline information
Press the RATIO button repeatedly to select the desired picture format. You can also adjust Aspect Ratio in the OPTION menu.
  1. Set By Program. Selects the proper picture proportion to match the source’s image. (4:3 → 4:3, 16:9 → 16:9)
  2. 4:3. Choose 4:3 when you want to view a picture with an original 4:3 aspect ratio, with gray bars appearing at both the left and right sides.
  3. 16:9. Choose 16:9 when you want to adjust the picture horizontally, in a linear proportion to fill the entire screen.
  4. Horizon. Choose Horizon when you want to adjust the picture in a non-linear proportion, that is, more enlarged at both sides, to create a panorama view.
  5. Zoom 1. Choose Zoom 1 when you want to view the picture without any alteration. However, the top and bottom portions of the picture will be cropped.
  6. Zoom 2. Choose Zoom 2 when you want the picture to be altered, both horizontally extended and vertically cropped. The picture taking a halfway trade off between alteration and screen coverage.
  7. Cinema Zoom. Choose Cinema Zoom when you want to enlarge the picture in correct proportion. Note: When enlarging or reducing the picture, the image may become distorted. You can adjust the enlarge proportion of Cinema Zoom using D / E button. The adjustment range is 1~16.
Oct 18, 2009 | LG 42LC2D 42 in. LCD HDTV
R51 Thinkpad Monitor Problems
To answer your question Morgan, yes you can get a new LCD display for your laptop! Typically people sell the entire assembly which is the screen, backlight, display cable. It then fits into the thin plastic casing around your current screen. They are actually pretty easy to replace the problem is you oftentimes have to remove the computers keyboard, and other pieces of plastic on the top that might be in the way. Also there are usually anchoring screws on the bottom that have to be removed as well. There should be one little teeny tiny cable you have to pull out that connects to the mainboard, and then reconnect with the new display. Try this website if you want to order a new one their price is only $120 (which is great for a new LCD screen).
http://www.blisscomputers.net/servlet/the-44892/IBM-R51-THINKPAD-LAPTOP/Detail
Feb 21, 2009 | IBM ThinkPad R51 Notebook
HAVE A CD ROM TEAC CD-224E PART #1977047B-12 DO YOU KNOW WHAT IT WILL WORK IN
This slim CD Rom is compatible with the Cubid and Travla mini ITX cases.
This is also compatible with:
Portege 3440CT, Portege 3480CT, Portege 3490CT, Portege 4000, Portege 4000CT, Portege 4005, Portege 4010, Portege M100, Portege M200, Portege M205, Portege M205-S809, Portege M205-S810, ProLiant Content Delivery , ProLiant DL140, ProLiant DL320, ProLiant DL360, ProLiant DL380 G2, ProLiant DL380 G3, ProLiant DL560, ProLiant DL560 R01, ProLiant DL580, ProLiant DL585, ProLiant DL590, ProLiant DL590 R01, SAN Management, Satellite 1550CDS, Satellite 1555CDS, Satellite 1715XCDS, Satellite 1730-S101, Satellite 1730CDT, Satellite 1735-S101, Satellite 1800, Satellite 1800-S203, Satellite 1805, Satellite 1805-S203, Satellite 2060CDS, Satellite 2065CDS, Satellite 2100CDS, Satellite 2100CDT, Satellite 2105CDS, Satellite 2140CDS, Satellite 2140XCDS, Satellite 2180CDT, Satellite 2210CDT, Satellite 2210XCDS, Satellite 2215XCDS, Satellite 2230CDS, Satellite 2250CDT, Satellite 2250XCDS, Satellite 2255XCDS, Satellite 2510CDS, Satellite 2515CDS, Satellite 2520CDS, Satellite 2530CDS, Satellite 2535CDS, Satellite 2540CDS, Satellite 2540CDT, Satellite 2540XCDT, Satellite 2545CDS, Satellite 2545CDT, Satellite 2545XCDT, Satellite 2590CDS, Satellite 2590CDT, Satellite 2595CDS, Satellite 2595CDT, Satellite 4000CDS, Satellite 4000CDT, Satellite 4005CDS, Satellite 4005CDT, Satellite 4010CDS, Satellite 4010CDT, Satellite 4015CDS, Satellite 4015CDT, Satellite 4020CDT, Satellite 4025CDT, Satellite 4030CDS, Satellite 4030CDT, Satellite 4060CDT, Satellite 4060XCDT, Satellite 4070CDS, Satellite 4080XCDT, Satellite 4085XCDT, Satellite Pro 4600 (14.1), Satellite Pro 4600 (15), Satellite Pro 6000 (14.1), Satellite Pro 6000 (15), Satellite Pro 6100 (14.1), Satellite Pro 6100 (15) , Satellite Pro 6100 (15 SXGA), Satellite Pro 6100 (15 UXGA), Satellite Pro M10, Satellite Pro M10-S405, Satellite Pro M10-S406, Satellite Pro M10-S407, Satellite Pro M10-SP405 (14.1), Satellite Pro M10-SP405 (15), Satellite Pro M15-S405, Satellite Pro M15-S406, SUN FIRE V100, SUN FIRE V120, Tecra (14.1) , Tecra (14.1 SXGA) , Tecra 8000, Tecra 8000 (12.1), Tecra 8000 (12.1 STN), Tecra 8000 (13.3), Tecra 8000 (14.1), Tecra 8000 (14.1 PIII) , Tecra 8000STN, Tecra 8100, Tecra 8100 (13.3), Tecra 8100 (14.1), Tecra 8200, Tecra 9000, Tecra 9100, Tecra PE2100, Tecra S1 (14.1), Tecra S1 (15) , Tecra S1 (15 UXGA), Tecra TE2000, Tecra TE2100, ThinkPad 1300 1171 (12.1) , ThinkPad R50 1829 (14.1) , ThinkPad R50 1829 (15.0) , ThinkPad R50 1830 (14.1) , ThinkPad R50 1830 (15.0) , ThinkPad R50 1831 (14.1) , ThinkPad R50 1831 (15.0) , ThinkPad R50 1836 (14.1) , ThinkPad R50 1836 (15.0) , ThinkPad R50 1840 (14.1) , ThinkPad R50 1840 (15.0) , ThinkPad R50 1841 (14.1) , ThinkPad R50 1841 (15.0) , ThinkPad R50e 1834 (14.1) , ThinkPad R50e 1834 (15.0) , ThinkPad R50e 1842 (14.1) , ThinkPad R50e 1842 (15.0) , ThinkPad R50p 1832, ThinkPad R50p 1833, ThinkPad R51 1829 (14.1) , ThinkPad R51 1829 (15.0) , ThinkPad R51 1830 (14.1) , ThinkPad R51 1830 (15.0) , ThinkPad R51 1831 (14.1) , ThinkPad R51 1831 (15.0) , ThinkPad R51 1836 (14.1) , ThinkPad R51 1836 (15.0) , ThinkPad R51 1841 (14.1) , ThinkPad R51 1841 (15.0) , ThinkPad R51 2883 (14.1) , ThinkPad R51 2883 (15.0) , ThinkPad R51 2887 (14.1) , ThinkPad R51 2887 (15.0) , ThinkPad R51 2888 (14.1) , ThinkPad R51 2888 (15.0) , ThinkPad R51 2889 (14.1) , ThinkPad R51 2889 (15.0) , ThinkPad R51 2894 (14.1) , ThinkPad R51 2894 (15.0) , ThinkPad R51 2895 (14.1) , ThinkPad R51 2895 (15.0) , TRANSPORT NX
Mar 05, 2008 | Computers & Internet
Screen darkening from right side
1 lool
change lcd panel ok
Jan 19, 2008 | Lenovo ThinkPad R51
Scanning Problem
Scanned image is unsatisfactorily cropped
You can turn auto-cropping off or adjust how the image is cropped.
To turn auto-cropping off:
From your desktop, double-click the Lexmark X6100 Series
All-In-One Center
icon.
The All-In-One Main Page appears.
2 Click See More Scan Settings.
3 Click Display Advanced Scan Settings.
4 Select the Scan tab.
5 Click Select area to be scanned, and then select a size from the
drop-down menu.
6 Click OK.
To adjust how the image is cropped:
All-In-One Center
icon.
4 Click the Scan tab.
5 Select Auto-crop the scanned item.
6 Slide the Tolerance bar to the left to crop less or to the right to crop
more.
7 Click OK.
Dec 06, 2007 | Lexmark X6170 All-In-One InkJet Printer
Thinkpad R51 Blue screen
First:
does this also happen in safe mode boot. (press F8 just before windows boots). If not then go to your event viewer and check the messages at the specific time,hour messages. for example. computer booted at 23:30. in windows around 23:31:10 and then blue screen. Go to safe mode. and look in the logs what registered at 32:31:10(around this time).
If not possible to boot in safe mode. Try to remove one of the 2 memory dimm(if you have 2). so you boot with 1. maybe 1 of them doesn't work good anymore.
Nov 30, 2007 | IBM ThinkPad R51 Notebook
Horizontal Span across 2 screens - now displays multiple offset background image
you have tried differrent setting in your video resolutions, what you need is just return to your default settings
Nov 29, 2007 | XFX GeForce Fx5700 (128 MB) Graphic Card
Computers & Internet Logo
267 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
