Question about Fantom G-Force MegaDisk 1.0TB 7200RPM USB 2.0 16mb cache (MDU1000) Hard Drive
None of my computers recognize my hard drive, and the drive appears to be in working condition (light goes on, sounds normal). I haven't dropped or physically damaged the drive in any way. the problem seemed to happen overnight. i believe the problem is a faulty usb connection, but what can i do to fix this?
  • 34 Answers
Change the usb cable for one that you know works.
Posted on May 02, 2011
Dropped wd external drive & now not recognized by pc
Unfortunately hard drives damage extremely easily. Think of it as an old fashion record player. The needle (head) most likely damaged beyond normal repair. I had fail with less than 6 inches onto **** carpet. Sorry.
Aug 27, 2012 | Western Digital Passport Computers &...
Tip
How to detect if your hard-drive is working or not/hard disk maintenance.
Some times you don't know if your hard drive is working or not. Your external hard disk might drop on the ground, or your desktop/laptop hard drive might not be booting. Which ever the case maybe, here is how to find out the condition of your hard disk:
Put your ear close to your hard disk, if you hear your hard disk make a crackling noise, be prepared to buy another hard disk because such hard disk is damaged and cannot be fixed. Also note that it is difficult to recover files from such hard drive.
But if you don't hear a crackling sound, use your hand(s) to feel the drive, if it vibrates, it means the hard disk is in good condition.
What damages external hard drive most times is if you don't eject (safely remove) it from your computer, when it drops on the ground or hits any hard object etc
If your external hard disk stops working, firstly, check if the hard disk inside the case is in good condition by checking for crackling sounds and vibration. Once you observe that the hard disk is in good condition, this means the hard drive case is defective/the cause of the problem. Get another drive case and your drive will work again without loosing any file/data on it.
For desktop/laptop hard drive maintenance, make sure you always shut down your computer properly, don't remove the CPU's power cord while the computer is turned on. To be on a safer side, always use UPS (uninterrupted power supply) for your desktop computer.
Also, when using your laptop, makes sure its fixed at a position. Avoid any shake as the hard disk might shift from its normal position in the process.
Good luck.
on Oct 21, 2010 | Computers & Internet
Wd my book flashing blue light. sill no power up
Good luck.
Jan 22, 2011 | Western Digital My Book Essential 1TB...
Hard disk tiking when power up.
Good luck.
Jan 11, 2011 | Hitachi HTS542520K9SA00 200 GB SATA Hard...
Firelite makes clicking sound and light on top pulses on and off
Sorry but your device has had it, with a bit of knowledge it may be posible to reove your files but you need to connect the hard dive out f its device housing directly to a computer.
Jul 04, 2010 | SmartDisk (USBFLB100) 100 GB Hard Drive
Speedometer not working, mileage clock goes to
Oh dear one of these problems. Sound like a loose plug or dirty connection in plug Very hard to find Start by checking battery and ignition circuit plugs and terminals Hope this helps Feel for you!
Oct 22, 2009 | 2002 Ford SVT Focus
Vista stops recognizing external hard drive
This doesn't sound like an OS issue. This appears to be more an issue of the connection to the hard drive. The USB cable likely isn't the culprit, nor the laptop USB inputs. If the drive was ever dropped or the cable gets removed and reattached often to the actual enclosure, you might be looking at a bad port on the enclosure. This isnt a lost cause. You can always buy a hard drive enclosure from newegg and move the drive from the IOMEGA to the new enclosure. You can get a new enclosure for $15. Just because the USB port is bad, it doesnt mean the data is gone and the hard drive cant be used.
Aug 26, 2009 | Iomega 33089 250 GB Hard Drive
My computer doent recognize my external hard drive
disconnected from the computer and reconnect.
if it still doesn't recognized the device, disconnect and shut-off the power and wait 1 or 2 min. than re connect again.
with all that, if the machine still can't recognized the drive, then the drive need to be check with another work machine, make uure it is in working condition.
Dec 05, 2008 | Western Digital My Book Essential Edition...
Dropped external hd not being recognized
replace the hard drive, as dropping it has rendered it totally useless.  be more careful in the future.
Nov 13, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Dropped firelite: still spins but is not recognized
Ok same situation happened to me i dropped my Firelite 80Gig, drive would spin no light and the computer would not recognize the drive. All I did was open the case an saw the the internal hardrive had come loose from its pin connection. So all i did was pushed it back in and BAM now it works, hope this helps other people. Thanks C.J.
Mar 20, 2008 | SmartDisk FireLite 40 GB Hard Drive
Fantom G-Force MegaDisk 1.0TB 7200RPM USB 2.0 16mb cache (MDU1000) Hard Drive Logo
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
