Question about Frigidaire FAC126P1 wall/window Air Conditioner
FAC127P1A1 we bought the house with 2 of these window airconditioners and non of them has instruction.we never used these so we need help please. where we could get some paperwork on these items? how to install? Thank you Villa family
  • Anonymous Jun 12, 2008
    I NEED TO KNOW HOW TO SET THE AC ON TIMMER, TEMP, SLEEP, AND THINGS LIKE THAT?
    TKS
  • 20 Answers
Instalation is straigth foward .open bottom window,place air conditioner trough window,spred the acordion partition on the sides,install a screw on both sides,and bring your window down to meet with air conditioner.and that should do it
Posted on May 27, 2008
There is dirt behind the air directional louvers inside the air conditioner unit. How can iot be cleaned? The crevice tool of a vaccuum won't fit inside, besides the "dirt" seems to be...
Download manual from here: http://www.searspartsdirect.com/partsdirect/user-manuals/FAC127P1A1-Frigidaire-Parts-Room-air-conditioner-Parts-manual
Jul 20, 2011 | Frigidaire FAC127S1A Air Conditioner
We have just had an electrician do work around our house when we went to use the airconditioner it doesnt work. Tried to call our electrician but of course no answer. Any ideas how to start my...
Check the electrical panal and make sure the breaker is on(220 volt 2-piole breaker). Check at the air conditioning unit and make sure the disconnect is on and there are fuses in the disconnect. Some disconnects are a non-fusible type. Turn the breaker off at the electrical panal and make sure the fuses at the disconnect are good. Also check and see if the switch at the furance is on. Or check the electrical panal and make sure the breaker for the furnace is on(110 volt single pole breaker). This is only if it is a split system type air conditioner. Part insude , part outside. You need control voltaged (24 volts) from the furance to the outside contactor at the air conditioer for the system to operate.
Jan 27, 2011 | Mastercool 67680 Evaporative Cooler Air...
Frigidaire air conditioner # FAC127P1A1
You can view the manual directly on Frigidaire's website: Use and Care Manual. Look on page 11, under "Care and cleaning". Note that the link is to an Adobe PDF document.
Jul 08, 2010 | Frigidaire FAC126P1 wall/window Air...
My GE wall Airconditioner is not cooling brings out warm air?
mcdevito75, here, wall A/C do they also give out Heat, if so, refer to the owners manual for instructions on how to use the cooling. Set switch to low cool and the switch with the blue scale about 1/2 way thru the blue scale shown on the switch (Knob) Both your A/C units may be set on heat, double check position on switches, (Knobs)
Jun 24, 2010 | GE AJCQ08ACB Air Conditioner
Just bought after market tail lights (entire housing) and bulbs for head lights, high beam and fog. Non came with instructions?
The tail lights are held in with 2 screws, look on the new ones and you can find where they are. The headlights are held in with 2 rods, lift rods up and out, the headlight will almost fall out.
Jun 05, 2010 | 2005 Chevrolet Suburban
2002 Nissan Maxima SE - Air condition not blowing cold air
simply "adding a can"is a good way to end up with non-functional A/C. the typical system has high/low pressure switches that enable/disable the system. you need to be at the correct volume of refrigerant as specified on the sticker under the hood. i recommend using the proper equipment, evacuating, pulling a vacuum, and then refilling the system with the appropriate amount.
Jun 23, 2009 | 1995 Nissan Maxima
I never put an air conditioner in a window. The air conditioner was given to me with no instructions. Please tell me all I should do to make it safe.
window type airconditioners have a shell or outer body. Install the shell first. "L" braces are okay to use for bracing the protruding condenser outside. Once the shell is secured you can just slide the main airconditioner in it.
May 03, 2009 | Heating & Cooling
CARRIER HEATER FAN WONT TURN OFF. PLEASE HELP
Need more information.... Is this a whole house unit, a window unit or what? Model #?
The breaker would be in your basement or wherever your breaker box is. If it's a 220 unit, one side could be kicked if whoever hooked it up used 2 seperate breakers (very unusual but it's been done).
Geno
Mar 06, 2008 | Heating & Cooling
Frigidaire FAC126P1 wall/window Air Conditioner Logo
461 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
