Question about GE JBP69 Electric Kitchen Range
Kitchen Aid superba (electric oven)
Oven doesn't come on. Light indicators are all fine but the oven elements (top &bottom) don't kick in
  • 93 Answers
You will need electrical meter. Take unit out of hole remove back plate( unplug or turn breaker off first). Turn power back on set temp for bake check leads to element. If no voltage replace control
Posted on Jul 18, 2008
My kitchen aid "superba " convection oven is not maintaining it's temperature. It has only one heating element on top.
There is a good chance there is a hidden element on the bottom. This is common on higher end ranges. It could be a bad element.
Sep 28, 2014 | Kitchen Ranges
My kitchen aid electric convection oven (superba series) is not maintaining it's temp. I do not believe the fan is turning. My oven has only one baking element on top.
You do have a lower element. On convection ovens they are usually covered. If you look in the bottom of you oven you should see it is elevated in a rectangular metal cover. You should be able to slide it forward and lift it away to expose bottom element.
If visual inspection shows no signs of burn out on it then you will have to test to see if it is getting power.
Can you tell if the top element is working for sure?
Kitchenaid superba stove baking element does not heat
There has to be a baking element. Find it and replace it.
Aug 19, 2017 | KitchenAid Kitchen Aid Superba Series...
Electronic control board
If you are hearing a clicking sound, that would be the igniter trying to light the gas, however you said elements not heating up which says it's electric... hmmm. If it's electric, try the broiler and see if the element comes on. It's pretty easy to troubleshoot by process of elimination. By all means do not try and repair it yourself unless you are qualified working with electrical.
Jun 14, 2017 | KitchenAid Ovens
Using an oven with a broken element
if it's electric the broil element also comes on when baking or using the bottom element,it comes on for even cooking when baking so whatever you're cooking will cook on top and bottom so don't use it until you buy the new element and whenever you work on the machine unplug it,also you can damage the clock assy. and that's the computer board and those can be very expensive,i've gone in,changed out the element and it still doesn't work from the element shorting out when it broke and it takes out the computer board so hopefully this doesn't happen
Nov 16, 2011 | Kitchen Ranges
I own a frigidaire es200 electric range MODEL# FEF352DWE my oven wont heat up, indicator lights are working but no heat at all in the oven yet the broiler and stove top works just find just the bottom...
Thanks for choosing FixYa and welcome to the site. If you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defetive heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection. Thank you for your time and thanks for choosing FixYa.
Apr 14, 2011 | Frigidaire PLEF398AC Electric Kitchen...
The oven portion of my kitchen aid superba range won't heat up.All of the topside burners are working fine. I recently turned the breaker off then back on to this appliance, would this have affected this...
there is an element in your oven that needs to heat up before it will light. it needs to be replaced. collect the serial number and model and if you go to sears they should be able to help you with the problem
Feb 09, 2011 | KitchenAid Ovens
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
Kitchen aid superba electric convection range
ouch thats gotta hurt!! how about the clock os that back on atleast??? sounds like a bad thermo stat on the back wall of the unit maybe a quater sized thermo 1 wire in one out, should have ( BUT DOUBt it does) have continuity through it. ifthe clock still doenst work ther is also a small inline thermal fuse connected right to the wire warness connecting to the main control
Mar 18, 2008 | KitchenAid KESC307 Electric Kitchen Range
Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Oct 27, 2007 | Frigidaire FEF366DC Electric Kitchen Range
GE JBP69 Electric Kitchen Range Logo
263 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
