Question about Dryers
Dryer will not turn on. checked breakers and fuses
  • rootboy May 27, 2008
    I've reset the breaker at the panel in the garage, no luck. A few weeks ago the dryer "mysteriously" stopped in the middle of an auto dry cycle and would not turn back on. Later, it turned on OK. This time it stopped in the middle of an auto dry cycle, turned back on fine, but when the next load went in, it would not turn on. This is a Maytag LDE412, still looks like new after nearly 24 yrs.  :-)  Only repairs in that time are one belt and the heating element. Great machine. The accompanying washer has never had *any* repairs.
  • rootboy May 11, 2010
    Thanks for the tip on that. No need to consider the door switch or the startup switch? Or? When I changed the belt a few months ago, I totally vacuumed and blew out every spec of anything in there - I likes me a clean dryer!  ;-)  I found this post, with good troubleshooting tips, about a hard to start LDE412, but unlike the one in this post, pushing the startup button on mine yields no more response than if you had your finger on a brick. http://applianceguru.com/forum2/4390.htm...
  • 525 Answers
You may want to inspect your motor for lint build up around the windings. Symptoms will be exactly as you described, due to the motor overheating and opening the auotmatically resetting thermal protector built in to the motor. After allowing the motor to cool for a period it should reset and run again. If no harm has been incurred to the motor, a good cleaning may help. After removing the dryer from its power source, you can access the motor through the rear motor access panel which is about 9 inches square and has vent slats cut into it. If this fails to correct the problem, then a new motor is called for.
Good Luck!
Posted on May 27, 2008
Thanks again for the tips. Turns out one side of the twin 30 amp breaker at the panel in the garage was bad - my dryer was fine, just couldn't get good power. Checking voltages at the plug, one leg of 110 (half of the 220) didn't read any voltage. I then -carefully- checked both sides of the breaker at the panel and compared what I saw to other twin breakers. $16 part at Orchard Supply. It had tripped -only once- about a month ago, so that led me to investigate it before taking the dryer apart.
Thanks again!
Frigidaire Affinity panel turns on (lights up), even counting down, but the dryer won't tumble or heat. Help?!
Hi margaretc920 - Often when a dryer turns but will not heat, it is because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and if one is tripped the unit as well will experience this issue. The heater of a dryer requires 220 to 240 volts to operate. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If the issue persists, it could also potentially mean a number of other things: defective cord, wiring, control board or door switch. I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Jun 16, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Dryer has warmth but clothes are not drying. vent is not clogged, temp set at regular,drum is turning What could be the Problem?
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Gas Dryer---
2. Check for the continuity of the heating element in your gas dryer using a multimeter. Replace the element if continuity is not there.
3. Inspect the thermal fuse if it is burnt out, it is attached to the exhaust duct on the back panel of the gas dryer. Replace if necessary.
4. Check the igniter by first disconnecting it, and then place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance, if it is above 100 then replace the igniter.
5. Check the continuity on the flame sensor. The sensors are usually located close by the igniter so are easily visible.
Hope this helps...
Daniel
Sep 25, 2010 | Maytag PYE2300AY Electric Dryer
DRYER WONT START,IT HUMS, MODEL #LNC8760A71
Hi
If the dryer is not turning on or is not drying the clothes then you would need to check for the following things—
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 13, 2010 | Dryers
MY OLD GE ELECTRIC DRYER TURNS ON BUT WILL NOT HEAT
Make sure you check these to fix the problem.
  • Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
  • Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
  • A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Thank you
Aug 02, 2010 | GE Profile Harmony DPGT750EC Electric...
Mdg2600bww is not ignighting, cleared ventline, turns on, just no heat
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Jul 02, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My maytag front load dryer turns on and runs,it does not blow any hot air
Jul 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Problem with hotpoint as66vvxna1 dryer
There are a couple of things that you can check. FIRST go to the electrical box where the circuit breaker or fuse for the dryer is. Sometimes on half of the circuit breaker is tripped allowing the controls of the dryer to work, but not the heating element. Turn off the breaker and turn back on. Or replace the fusees. If this does not work, then you may have a loos wire or a burned out heating element. Sometimes there is a bad high temperature switch. Do the circuit breaker or fuse first. If the washer did not spin out the water well enough, the water can short the element to trip the circuit breaker or blow a fuse.
May 26, 2010 | Hotpoint Ariston AS66VXNA1 Electric Dryer
Turns on no heat
The very first thing to check. If you are on a fuse panel check to make sure both 30 amp fuses are ok. One fuse operates the motor and timer, but requires two fuses to operate the heat. If you are on breakers, turn the breakers off and wait a few minuites and turn back on and test.
Jan 21, 2010 | Maytag MEDB800VQ Dryer
Gorenje Tumble Dryer WT 881 - how do I replace heating element fuse?
I would start with house fuses or breakers, if breakers then turn breakers off then back on several times then try the dryer again. Then I would check the cord where it connects to the dryer. After that I would start checking elements, thermal overloads/cutoffs, etc. most dryers have several normally closed t'stat/ overloads and a thermal fuse. If the thermal fuse or cutoff is blown you also need to check your venting. these safety fuses are not resettable and are usually an indication that the vent may be clogged and/or obstructed.
Nov 04, 2008 | Dryers
GE Profile Harmony Dryer DPGT750EC Drum won't turn & no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Heating element
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
Jul 04, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
2,018 people viewed this question
Top Dryers Experts
