Question about Zenith R40W46 40" Rear Projection HDTV-Ready Television
Question regarding convergence resistors
I'm having the blue convergence problem exactly as desrcibed in this forum and have purchased new IC's. I also purchased a pack of 3.9 ohm 2 watt flameproof 5% tolerance resistors as described as well. I have two resistors on my convergence board that are discolored, I can't tell what the original color codes on these resistors are as the bands now all look black and the position numbers are not the same  as described in the other posts. The discolored resistors on my board are labled R2726 and R2732. My question then is are these two resistors also 3.9 ohm 2 watt resistors? or another way of putting it is are all of these resistors on the board  the same type? Or do I need to find out the ratting of these two resistors and purchase different ones that those I already have?
  • 2 more comments
  • dougbrown May 27, 2008
    I see that this topic is discussing all sorts of brands and models, so I thought I should specify that my TV is a Zenith R40W46
    sounds good, I'll let you know how it goes then
  • dougbrown May 29, 2008
    worked like a charm, only problem was I learned not to solder your fingers
  • mitchelldrj Aug 08, 2008
    Yes, we are neophytes to the whole do it yourself in tv repair. Anyhow, we have blue arcs in our pictures, too. We have worked on computer circuit boards before. Is it similar? All we need to do is locate the circuit board and which resistors and IC's (?) are out and replace, right? If so, I think we can handle that once we get the parts. Thanks for your assistance. We are always up for a challenge.
    Problem Solver:
  • 13 Answers
Www.tv-solutions.redtienda.net
Posted on Aug 10, 2008
  • Zenith Master
  • 8,617 Answers
Yes those two resistors are also 3.9ohm 2watt 5% resistors
Posted on May 27, 2008
  • Sonny Berry
    Sonny Berry May 29, 2008
    Glad you got it working, you saved yourself about 400.00 doing it yourself. Glad I could help you out.
Colored lines at top and bottom when tv comes on and seeing double vision in different colors at all times
If your tv is not a DLP the problem is in the convergence, try to adjust it using your original remote control go to the setting menu then to the convergence section. Adjust the red and blue convergence. you should move the red and the blue in up, down and left, right if this color does not move far enough your convergence IC is already defective. Replacing this convergence IC will solve the problem. In locating this convergence IC you should remove the back cover of your unit but be sure to unplug it before doing this. This convergence IC is attached to a large aluminum plate, it is the heat sink, and it has a marking of stk- ### followed by numbers. You can try to pull it out using a soldering iron and soldering pump but be careful you may damage the board and cause much problem to your unit. Or you can contact a technician to do it for you and save you from stress good day and best regards.
Aug 28, 2011 | RCA Televison & Video
The colors are not aligned blue image shadows
hi ,thats is your convergence circuit is defect,you got 2 integrated circuit call
STK 390-xxx the ic # are depend of the tv chassis model number,
they got to be replace whit new one/ the component arround the ic like resistor ,capacitor
and some time 2 transistor for the minus 25volt,and plus 25 volts
some time you replaced just the stk ic and its ok,anyway taht have to be trouble shoot
if you know a good tech its will be better, or if you have some experience whit this ok
that is an hour job about to verify the circuit component near the ic like some low value resistor
.thats all i can do from here....
hope that give you an idea and have a merry christmas
regards : Alan tech for hitachi ...
Dec 23, 2010 | Hitachi Televison & Video
Double photo
Replace both of your STK ICs STK392-110s use 150s Mats has Them 1-800-628-1118
Jun 02, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Blue cast to screen and words at the bottom of screen run uphill.blue does not seem aligned to grid. magic focus did not correct. Can align red and green manually but not blue.
The IC /resistor in convergence circuit(blue) is bad
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 21, 2009 | Hitachi 51F500 51" Rear Projection...
Convergence
Did you remove 1 leg of each resistor out of circuit when you checked the resistors? sounds like thier is still one resistor open or maybe one of the new IC pins need abit more solder.
Apr 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Auto focus convergence on blue doesnt' work
this is an idication that eather the convergence ic's or convergenc ic output resistor have blown
Feb 16, 2008 | Samsung HCM422W 42" Rear Projection...
Help
your having convergence circuit problems, you`ll need to change the convergence IC`s and any burnt resistors in the convergence circuit, if you have questions e-mail me back, good luck, BMW Rider
Jan 03, 2008 | Toshiba 53HX71 53" Rear Projection...
Convergence
you have a bad convergence IC and probably one or two precision resistors next to the IC`s that have to be un-soldered and replaced, if your very proficient with electronics you can do the repair if not call a tech. If you decide to do the repair yourself
you`ll need a volt/Ohm meter (to find the bad resistor(s) and soldering equipment to remove the parts and re-install new parts, let me know and I`ll get you part numbers for IC`s, you will have to check resistors and tell me which ones are bad for their respective part numbers.
Nov 30, 2007 | Hitachi 43FDX01B TV
Phillips 60PP920217F Convergence Problems
replace ic chips pt# stk392-120 or stk392- 150 and there are 12 resistors located near ic clips pt# 6r8 ( color code blue - gray - gold - gold ) board location no#s 3149 thu 3160 if you look close you may find two resistors discolored as i found on my convergence circut board , also use heat sink compound on new ic chips , take your time to mark all wire connectors going to board from tv , also use .022 dia gage rosin -core solder and a 15- 25 watt soldering iron you may have to adjust the red - blue convergence afterwards my tv set is 3 yrs old also ( thanks holbert )
May 03, 2007 | Philips 60PP9202 60" Rear Projection...
I need help please...
You will need to replace the convergence output IC's and check the resistors in that circuit.
Apr 12, 2007 | Panasonic PT-56HX41 56" Rear Projection...
Zenith R40W46 40" Rear Projection HDTV-Ready Television Logo
1,088 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
