Question about Dualit 40352 4Slice Toaster
Dial stops turning leaving heat on. How can I stop this happening?
It's your timer thats faulty due to wear and tear.Dial stops turning leaving heat on. How can I stop - 140.jpg this part is available from catering parts and should look like item pictured. Fitting part is simple for any half competent D.I.Y enthuiast requiring a posi screw and a flathead screwdriver(Any flatblade will do).Step1.Remove all six retaining screws at base of toaster four are holding the feet and a couple more holding the plate.You will see the back of the timer assembly.Step 2.Using the flat screwdriver or blade gently lever off timer dial which will expose the dial spindle and also 2 retaining screws which holds the timer assembly in place.Remove these screws with your posi screwdriver.Make a note of terminal wires to the timer unit as these will all have to be removed and put back unto your new timer unit.Step 3 relace all wires as they were on faulty unit and a re-assemble toaster.This should definately solve your problem.Happy toasting and don't forget take your time and get it right keep all your screws as they will probably have to be re-used as replacement units some times come without screws so old screws may have to be used.Good luck
Posted on Oct 17, 2010
How to Use PadLock?
FOLLOW THIS STEPS
1.Spin the dial at least three times to the right (clockwise), all the way around.
This "clears" the lock of any previous numbers. If at any point in putting in your combination you mess up, do this again to start over.
2.Enter your combination. Turn the dial to the right and stop at your first number. Always start with a turn to the right!
  • For your second number, turn the dial to the left, going past zero and your first number. Then stop at your second number.
    • Some locks are a bit odd or finicky -- if your locker isn't opening after you put the three numbers in correctly, try turning left past your second number once and stopping on it on the next go around.
  • For your third number, turn the dial to the right and go directly to the last number. Leave your lock on this number. Always remember: right, left, right.
Oct 19, 2016 | Computers & Internet
Need to reset speed dial numbers but cannot get the cursor to appear.
Dear
Storing One Touch Dial Numbers 1Press Menu, 2, 3, 1. 2Press the One Touch key where you want to store the number. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit. Storing Speed Dial Numbers 1Press Menu, 2, 3, 2. 2Enter a three-digit (a two-digit for FAX-4100e) Speed Dial number, and then press Set. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit.
Thanks.
Feb 03, 2015 | Brother IntelliFax-4100e Fax
Hi, my Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer, won't rinse and I have to manually turn dial to spin, any ideas please?
Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 26, 2013 | Beko Washing Machines
My dv600 trys to start up after about a sec it turns off and try and reboot but nothing happens i hear the fan can you help
It sounds like your onboard graphics card has become corrupt due to overheating. It's a common fault with these laptops. There's a gap of about 1mm between the graphics chip and the heat sink which is usually filled with a heatpad. Unfortunately these don't conduct heat as well as they should so the graphics card tends to overheat and corrupt the motherboard. Once this happens, there is a function in the BIOS that stops the laptop from booting, supposedly to stop the motherboard from frying. If you leave the laptop for long enough it might eventually start, I've had them do so in the last, and the problem might even seem to have solved itself but unfortunately it will only be a temporary thing. You need to replace the motherboard and when you do so put a copper shim and heat sink compound between the heat sink and the graphics card to stop it happening again. If it were me I'd sell the laptop for spares and buy a refurbished one.
Jan 25, 2011 | HP Pavilion dv6000z Notebook
Combination rotation
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
3 Digit Combination Locks for Security Safes
31-10-31
  1. Turn the dial to zero.
  2. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  3. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  4. Turn the dial to the left to the last number (stop the first time on your last number).
  5. Insert the key; turn right.
  6. Pull on the key while it's in the lock to open the door.
3 Digit Combination Locks for Gun Safes
31-10-31
  5. Pull the handle down; the door should open.
Electronic Locks
31-10-31
  1. Insert the tubular key into the lock to the left of the key pad.
  2. Turn the key all the way to the right until the plunger pops out.
  3. Press the five-digit factory code. The green Proceed light will come on.
  4. Pull the handle down; the door should open.
4 Digit Combination Lock
31-10-31-10
  2. Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the fourth time).
  3. Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
  4. Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
  5. Turn the dial to the right to the last number (stop the first time on your last number).
  6. Pull the handle down; the door should open.
You can find more information about Sentry Safes at www.SentrySafeShop.com
Dec 11, 2010 | Sentry Fireproof Safe
Is pattern to sentry 1230 safe right left righ
31-10-31
31-10-31
31-10-31
Electronic Locks
31-10-31
31-10-31-10
You can find more information on your Sentry Safe at www.SentrySafeShop.com
Dec 08, 2010 | Sentry Fireproof Safe
I know the combination of sentry 1610 safe but can not open.
Are you sure that you are turning the dial correctly? 3 Digit Combination Lock
31-10-31
31-10-31
31-10-31
Electronic Locks
31-10-31
31-10-31-10
You can find more information about your Sentry Safe at www.SentrySafeShop.com
Nov 21, 2010 | Sentry Fireproof Safe
Element light staying on
sometimes this is a wireing problem....elements will heat but do they turn orange. if not then the stove may be hooked up like a 110volts..
Nov 04, 2009 | Office Equipment & Supplies
No heat....i turned the dial while it's running
Your complete problem may lie with a bad timer. Replace the timer and it will stop at the end of the cycle. If it still does not heat, update your post for the next step.
However, replacing the timer may solve both problems.
Apr 10, 2009 | Kenmore Dryers
Won't complete the cycle
Try using a quick cycle and see what happens. Don't use sanitize or any extra heat cycle. Sometimes during sanitize high temp rinse or other cycles the timer motor is stopped until the water heats up. The sensor could be defective. Not all machines do this and I'm not real familiar with your particular one.
Jul 03, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dualit 40352 4Slice Toaster Logo
163 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Ross Keen
Piyal Perera
Piyal Perera
Joseph Hoffmann
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
