Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Troubleshooting tree diagram of no sound - Sony FD Trinitron WEGA KV-32FS120 32" TV
1994 camaro code 36 optical module troubleshooting tree
Code 36- Distributor ignition system. Faulty high resolution (360X) pulse or multiple low resolution pulses detected. Check pigtail connector from distributor to main harness for any opens or shorts. Verify wiring is okay before replacing distributor.
May 28, 2015 | 1994 Chevrolet Camaro
Tree diagram...is there a threaded tube running between the two parts of the tree on the front end?
There is the steer tube that is pressed into the lower tree/clamp. This tube is threaded on the top so that you can put a nut on it after the upper tree/clamp to preload the headset when you install the front end.
Oct 05, 2013 | Honda CB 750F2 Seven Fifty Motorcycles
Our navel orange tree froze up last winter,,we cut back as much as we could,,this summer got like 10 oranges,,and tree looks awful,,hardly no leaves,,should we cut it back more? is there a life span of...
I would cut it down and burn it, after a freeze trees go to bearing a sour fruit that only a pig would eat. it sounds like your tree might need to be replaced. sorry
Sep 10, 2013 | Pool & Spa
Mower deck belt diagram for poulan 42 inch ride mower
Go to Craftsman, Order Tree or Parts Tree.com and input your model number. Choose the correct tab and go to the mower deck. It will give you a good over view of how the belt routes. Hope this helps.
Nov 02, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Is sierra easy family tree for windows 95/98 compatible with windows 7? I have no problem with windows xp.
It probably will not work on win 7
If it will install you can try to run in compatibility mode by right clicking on the install after installing and clicking troubleshooting compatibility and adjusting the settings in the new box that will pop up
Sep 17, 2011 | Sierra Generations Family Tree Liberty...
I have a 1985 Ford f 250 I don't have a owners manuel or a fuse box diagram and am trying to figure out what the 5 amp fuse toward the top goes to it's blown and am clueless to what it operates and...
You can buy a good service manual for your truck from Haynes for $25 on line, eBay, or check your local library for a loaner copy. We have a Haynes manual in each of three vehicles and they have been very valuable when problems arise. They have both electrical and mechanical details and step-by-step instructions for us shade-tree mechanics-
1985 Ford trucks
Jul 28, 2011 | Ford F-250 Cars & Trucks
My a/c isnt working in my 2003 suzuki aerio. I have been told its an electrical problem in the air conditioning circuit... or if the conditioning compressor clutch will not engage try with the ignition key...
Hello Jgilly90,
I'm not sure if i would place a jumper across the low pressure switch. Unless the troubleshooting tree in the service manual
suggested this test I would be careful experimenting.
Here is your HVAC schematic:
Aug 17, 2017 | 2003 Suzuki Aerio
I have family tree maker version 6, i recently bought a macpro and wanted to transfer my files which are extensive. i had to wait for family tree maker mac version which i now have but the files wont...
Try saving a copy of your family tree as a .GED file. for example "familytree.ged" onto a USB drive or disk, then put said disk in your MAC, open family tree maker and try and import your tree.
Files using the .ged extension seem to be the most portable.
Feb 26, 2011 | Broderbund Family Tree Maker Version 6 -...
Trouble shoot sound
Open the Control Panel.
Open "Systems".
Click on the "Hardware" tab.
Click on the "Device Manager" button.
In the device tree, expand "Sound, Video and Game controllers".
Look for your audio device. Right click and select "Properties".
In the box labeled "Device Status", does it say "This device is working properly", or does it say something else. There is a "Troubleshooter" button you can try if necessary.
If the above does not help, then right click on the audio device (still in the "device manager" tree) and select "Uninstall".
Reboot the machine. It should scan for new devices and attempt to install it automatically.
Mar 03, 2008 | Dell OptiPlex GX260 PC Desktop
Projector automatically shuts off immediately after turning it on
If your comfortable w/surface mount troubleshooting and soldering, download the service manual from elsewhere online. Part of the troubleshooting tree for this type of problem is to check the surface mount fuses on the underside on the Main PWB (schematic page 1/8). On mine, the 12V surface mount fuse, F3004 (2.3A) was open (quadrant C1 on the schematic). Replaced it, reassembled the projector (3 interlocks don't 'cha know) and it came up just fine.
Nov 12, 2007 | Mitsubishi XL8U Multimedia Projector
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
85 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
