Question about Gigabyte GA-8IPE1000-G (MBGA81PE1000G) Motherboard
Computer doesn't start-up anymore, goes into looking for a bios backup file on hard drive. Has motherboard had it now, as there isn't a back-up for bios
  • Gigabyte Master
  • 27,725 Answers
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Oct 03, 2010
Ms-7548 mobo no post beep and screen goes black after startup
this sounds like you have picked up a virus there are a few that will do this, you will need to reformat the hard drive. or use a backup disc if you have one made to install on computer. make sure you only go into computer in safe mode and use virus software to try and remove it. this virus attacks the startup file on the hard drive, and the reg files allocation. hope this helps failing this the hard drive has wiped its self when it has not shut down properly.
May 09, 2014 | HP MS-7548 System Board Motherboard...
How can recovery Hp bios when it has crashed
Mugisha,
This could be a memory probably but very unlikely depending on the timing of your restart. If you restarted in the middle of running the BIOS update then the problem is very likely that you have the BIOS in a non-recoverable state. There are lots of warnings that say don't restart the computer and unlike 99.9% of software, this one can break your hardware. Your BIOS the part of your motherboard that sees all of the connected hardware and if it isn't working then nothing is going to work ever. The good thing is that motherboards aren't that expensive for desktops. Also your HD is still readable so you will be able to get your data off it if you need to.
If you didn't restart early and did it when the installer said it was OK to then it could actually be an issue with RAM. Bad memory can/will cause your computer to not POST which is that screen you first get when powering up your computer, behind the HP splash screen. A quick easy way to test if you have bad RAM is to swap it out. Unplug your computer and open it up. Hopefully on the motherboard you will see multiple sticks of RAM. You can google search SD or DDR RAM to get an idea of what you are looking for. Next take one of the sticks out then plug the computer back in and power it up. See if it works and if it doesn't do the same thing with the other stick. If you only have 1 stick then you can't test this because you need at least one plugged in for your computer to work.
If that doesn't work then you might have a dead motherboard from a bad BIOS update. Running BIOS updates always make me nervous because if anything goes wrong your motherboard is dead in the water.
You can bring it to a computer repair shop to see if they can get it working again. Like the issue with the RAM there are other pieces of hardware that could be bad but people don't normally have the hardware laying around to swap out. Also they can take your hard drive out to backup the files needed if you do have a bad motherboard.
Oct 21, 2012 | HP Compaq Business Desktop dx7400 - Core 2...
Maxtor basics 500GB external hard drive not working
Every time you turn your computer on it is going to "spin up" and the light is going to come on. Just because the light goes out and it idles so that you can't hear it anymore doesn't mean it isn't still on. It is. You can verify this by using windows explorer to view it and its files.
Jun 29, 2012 | Maxtor BASICS Personal Storage 3200...
I have a asus motherboard it restarts on starting windows screen I've tried to boot in safe mode that doesn't work
That means there is a problem in the booting environment of the system. This usually results from a virus attack that changes the booting environment. The best way to go around this problem is to slave the hard drive to another desktop computer, access it and make a data backup. By slaving the hard drive i mean, connecting it to a working computer but do not let that computer to boot from your hard drive because it can not. Boot form the working computer so that you can be able to see your hard drive in the 'my Computer" menu as drive E of D or F depending on how many partitions are available.
After making a backup, take it back to youe ASUS motherboard and perform a clean installation of an operating system. This should fix the restarting problem.
Mar 25, 2012 | ASUS Computers & Internet
I dropped my Inspiron 1545 laptop about 2 feet from ground while it was on. At first, when I tried to start it it goes directly to a screen that says software or hardware malfunction and recommends I start...
If you got lucky and the shock only damaged the hard drive, what you need is a formatting and a reinstallation of the OS. If the damage is more extensive than that, say, the soldering on the circuit board was knocked loose, it is probably a cheaper and less painful venture to buy a brand new laptop. The RAM is most likely not the problem here, so there's no need worrying about that.
If you have replaced the hard drive, you need to make sure that an operating system is installed on it. If the hard drive is completely blank, your computer doesn't know what to do because it doesn't have anything to do. Does anything at all on the screen appear on startup? If there's an image saying 'Dell' or something to that effect, you can access the BIOS from there. justkos_0.jpg
All computer motherboards have a built in program called BIOS (basic input/output system) where you can accomplish simple tasks like looking at your machine's statistics and choosing from where to boot from. Typically, to access bios you must immediately hold down a key while the computer boots (usually F2 or F12). Once you are in BIOS, you can have your computer booted off of an operating system disc in the disk drive by selecting the disk to boot from.
If you still have the old HD, I recommend taking it to a professional who can extract all of the documents and files you want, if the old hard drive is indeed damaged. I hope I helped in some way. Good luck!
Jul 19, 2011 | Dell Inspiron 1545 Notebook
The pc does not detect the usb drive, the usb flashes. But nothing comes up
Make sure it is inserted all the way into the usb port. If nothing comes up, this doesn't mean it isn't connected, it just means autoplay isn't on. Once it is plugged in, go to the start menu > computer. This will open a folder with all your drives, both internal and external. Double click on your flash drive's icon to open it.
Jul 03, 2011 | SanDisk 32GB Ultra Backup USB 2.0 Flash...
When booting the laptop it says PXE-E61: media
When you start your computer, the motherboard searches connected drives for the operating system. The search order is usually the optical (CD/DVD) drive first, possibly a USB drive next, then the hard drive. If none of these work, some systems are set to try booting the operating system over a network cable. What the cryptic message you're getting is telling you is that the system tried a network boot without success, and that maybe the trouble is a bad cable.
This all means that your hard drive isn't being detected, or that there's no longer an operating system on it. It's possible the connector from the hard drive to the motherboard has come loose, which can sometimes happen since laptops get moved around. The hard drive may have gone bad, or there may be a problem with the motherboard that is causing it not to find the hard drive. Or the hardware may all be fine, but something (a virus or other malware, for instance) has deleted files needed to load Windows.
When the computer first starts, you'll see a message about how to enter BIOS setup. The BIOS is the motherboard's built-in program, and through the setup pages you can see what devices it detects. This will let you know if the hard drive is being found. Some boards include diagnostic tests you can run on the hard drive if problems are found. You can also check the boot order; you may find that for some reason the boot order has been changed so that the network boot is being tried first. Strange things can happen to BIOS settings, often a sign that the backup battery for the memory where the settings are stored is getting weak.
If you have access to a Windows XP operating system CD, you can set the BIOS to boot from the CD drive and try using the Recovery Console feature. Information about this can be found at Microsoft's site.
Good luck getting your laptop back up and running quickly. Thanks for using Fixya!
May 29, 2011 | Acer Computers & Internet
My computer goes to start windows normally page and then to the windows page but doesn't load and it goes back to the start windows normally page
I reformatted and reinstalled windows when mine did that. If you have a backup of your files then you're in good shape. If you don't have a backup then it's a little tougher. Take the drive out of your computer, put it on another one as a secondary or on an external exnclosure. Then copy the files you need to the host computer and copy them to a flash drive or a cd. Finally, reformat your hard drive, reinstall windows, and restore your files from your backup. Have fun!
Sep 20, 2010 | Computers & Internet
My drive is full so it won't back up anymore!
Check the backup settings in the software that came with the device. You may be saving every backup instead of saving incrementally. An incremental backup will back up the files that have changed after doing one full backup.
You can also view the files on the drive through Windows Explorer.
The files should be dated. Delete the oldest files making sure that they seem to be the same size as the next oldest file.
If your computer is not faulty, and the files on the backup are not the only place that they are copied, you can start over with the backup drive, change the backup settings and create an incremental backup routine.
Depending on the size in Gigabytes of the backup drive, you are limited to the amount of data you can back up.
Example:
If you have a 500Gigabyte drive in your computer and the external backup drive is 250 Gigabytes,a full system backup will not fit.
Go to Windows Explorer, Click on My Computer and view the available space and total size for each drive.
If you need more help, Use Fixya's new Phone Call Service. For $29.99 an expert will walk you through the setup and drive check.
Mar 17, 2010 | Western Digital My Book Essential Edition...
BACK TO MY DUAGHTERS E MACHINE
Remove the BIOS battery on the motjher board and unplug it ffrom the back and wait a few minutes to reset the BIOS. Its a watch battery on the system board, little smaller than a quarter. Once this has happened it should reset the password for the bios and you can boot into the bios on start up. ( usually the DELETE Key or F1 at the splash screen. Set the password or disable it entirely and you shouldnt have that problem anymore.
You could slave the drive to another computer and go into it like another drive on your computer, copy the files you need and then re-install the windows
May 28, 2008 | Intel Motherboard
Gigabyte GA-8IPE1000-G (MBGA81PE1000G) Motherboard Logo
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
