Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Compressor runs, fans don't
I checked power to the interior fan with the compressor on and it had voltage across the leads. Have reset unit several times with no result. Suspect burnt out fan transformer unless there is a reset button somewhere or another control that I cannot see.
  • 3,037 Answers
Hi thomasej
There is no reset button anywhere for the fans. Like you said, it could be a burnt out transformer or it could be that the defrost timer went bad. Let me know what you decide to do and if you are able to fix it. If not, let me know and I would be glad to help you with any further questions or concerns that you may have.
Posted on May 27, 2008
    Genius:
  • 1,066 Answers
Fans wear out too, did it make any unusual noises befor it stopped working?
Our hear pump digital display is working but the top fan doesn't seem to be working.we have been away from the UK for and the unit has not been used for a while so cld that be the reason?
If you are talking about the top fan of your outside condensing unit, it could be several things. The fan motor could have failed, the run capacitor could have failed, or the motor is not getting power. Most units have a contactor that turns on the fan and compressor at the same time. If you only have one contactor, the fan motor or capacitor has failed. If you are good with a meter, check to see if you have voltage on the fan leads AFTER the contactor. If you do, I would recommend replacing the fan motor and capacitor
Aug 06, 2016 | Miscellaneous
Wiring diagram for dometic a/c model600312.331c
Assuming the fan has only one speed. Remove the two leads going to the fan and connect them directly to the incoming power to the entire unit on the switch side, that way soon as you turn on the unit the fan will also come on, but not go off until you shut down the unit. Just make sure the voltage required by the fan and the supply voltage to the unit is the same.
Aug 20, 2014 | Dometic Rooftop RV Air Conditioner
I have a 6 yr old lennox merit 10acc system and the compressor doesn't seem to be running as there is no cold air and line out of compressor is not cold/sweating like my 2nd (good) unit.
you cant check capacitor with power on it nor using volt setting.need micro ferred setting on meter and check with power off and wires removed. leads go as follow for fan one lead on "C" and one on fan. For compressor one lead on Common and one on HERM. Also be sure voltage on capacitor is correct 360V or 440V. 440V will work for either. Also double check micro ferred requierment on motor and compressor. If its been replaced before may have been replaced with incorrect size. It happens.
Aug 23, 2012 | Heating & Cooling
Intertherm Air Conditioner S3BA-042KA compressor and fan not working (has power)
It sounds like that unit is connected to a "power saving load controller" device from the power company. The power company can turn your unit on & off with a radio signal. If you manually activated contactor and unit ran. I would bet that the power company's device or the wiring connecting it is where the problem lies. Call the power company and have them check their device. If they tell you that the device has been tested remotely and is working fine. Explain to them that you can activate your unit manually and it works fine. They should not charge you to come out. Those "load controller devices" have a pretty good longevity record.
Jul 11, 2012 | Intertherm Heating & Cooling
Interior fan not working on Vauxhall corsa
@John Patchett
"Interior Fan.."
Orange is positive so brown is negative, which is at 0V potential in relation to a negative-earth car.
So when testing directly across the orange and brown terminals when unplugged from fan should give you 12V DC with [+] test-lead on orange and [-] test-lead on brown, and switched on.
Try touching [+] tester lead to battery [+] then [-] tester lead to brown. If nothing with switch on, then negative is lost somewhere between here and there.
Do you have a circuit / service manual, or can you post a photo of the fan-connector ?
Regards,
Clive.
Oct 25, 2017 | Ford F-150 Cars & Trucks
Unit will not start up evaperator fan runs
Hi, if your indoor unit is running and you have high voltage to the outdoor unit as the compressor runs, I would check the control wires at the indoor unit, coming from the outdoor unit, and from the thermostat terminals to see if the condenser is wired correctly. I'm not sure what relay you are jumping out to get the compressor to run, and no fan, but if you look at the contactor where your high voltage leads connect, you can energize the contactor by pushing down on the plastic part of the contacts and the outdoor unit fan and all will start. Carefully, use a insulated screwdriver, or I have pushed them down with my finger to see, but be careful! You do have high voltage there or the compressor wouldn't have come on. If all runs when you do this, the thermostat control wires to the contactor have no 24 volt control voltage to it. Check your red and yellow wire connections. If you have a meter, check across the 2- for 24 volts. If you have no low voltage, this is your problem. Go to your indoor control section. If this unit has a circuit control board, look for a plug in type fuse like you would find in your car, a 3 to 5 amp fuse. Make sure its not blown. If the led light is on, it will be good. You have lost the low 24 volt power to run the outdoor unit. Check the wiring there, Red and Yellow. Make sure they are terminated. If none of this helps you or your not at ease doing these checks, call out the contractor and tell them that the outdoor unit will not run if it is new and just installed. They should have done a start up on it. Check the contactor first by pushing it down, it will spark but don't jump as it may scare you some. If all runs, check everything I have told you and you should find the problem. If you have any questions, contact me through this site by my user name, shastalaker7. Keep me posted.
Sincerely,
Shastalaker7
Jun 16, 2010 | Fujitsu 24C1 Air Conditioner
Goodman ac unit is not cooling
If your uniy is not producing water then check if the compressor is running. Whether you have a central or a wall unit you will hear the compressor come on. There is a way to check the compressor by removing the compressor cover and wires then ohming out the compressor terminals. REMEMBER THE ORDER THAT YOU TOOK OFF THE WIRES. You,ll have run [R], start [S], and common [C] you should a reading across all three. If one or more do not show a reading then the compressor has an open winding. If all have readings then the compressor motor is ok. Check for burnt or broken wire which might have saw when you opened it. If the compressor is running then you are low on refrigerant.
Sep 28, 2008 | Goodman CLQ36AR49 Air Conditioner
Lighns on - nothing else
well i have a 75r also with the same symptoms but there's no freezer in this model so I don't know how it could be the defrost timer.
Dec 03, 2007 | U-Line 75R Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
78 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
