Question about General Electric WBVH5200J Front Load Washer
I have a GE (wbvh5200jww) front load washer. when i push the start/pause button to start the washer it would come on normally / the door says locked / water would come out normally / then a minute or so later it would stop the water would drain out / the start/pause button would blink and the door would become unlock? then nothing happens? i would push the start/pause button again same thing would happen? i do not know what is wrong. i cleaned the filter trap and looked in with a flash light there is nothing inside blocking the passage way? the setting is set for colors normal - i change the setting to rinse & spin / the same thing happens again?
  • 99 Answers
SOURCE: washer pauses itself
My name is joyce
Are you using He deturgent?
If not this is the problem.
to remove the suds from the pump now you will have to put one tsp of oil in where you put powders at and run cycle on normal and then see what you get. if this dont work let me know and we will go from their.
thanks,
joyce
Posted on Feb 06, 2009
carputers
  • 255 Answers
SOURCE: GE ADORA WASHER IS NOT DRAINING AND IS STUCK IN PAUSE MODE
bad pump/motor or bad belt going to pump
Posted on Sep 08, 2009
SOURCE: GE front load washer, wbvh5200j1ww. no power.
the door can be manually unlocked by removing the bottom front panel, reach up and there is a pull tab on the lock mechanism. it is a crime that they do not post this online or in the manual, and let folks ruin their clothes.
power problem was a part called the "FILTER" it is where there power cord plugs into, something along the lines of part number 201. cost is $85 plus tax. service man has not seen one of these ever go before.
Posted on Dec 09, 2009
  • 29 Answers
SOURCE: ge WCVH6800 front load washer.
Has this been solved? I have the same problem only I do not remember a power failure. But the other things are the same. <!-- from fixya rte -->
Posted on Aug 16, 2010
SOURCE: No water no Spin
Check your 2 in 3 out water valve part# WH13X10029, this responsible for filling of water. By the way wash cycle will not run, until washer sense enough water.
Posted on Aug 31, 2010
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
GE WCVH6800 Pressing start results in two short beeps. The pause/start button keeps blinking and it will not start a cycle.
Is the door lock button on, but the door not actually locked? Our door lock switch keeps going out. We have replaced it 4 times in the last 3 years.
Jan 16, 2011 | GE WSXH208A Front Load Washer
Can the door swing on a GE wbvh5200j3ww washer be switched?
AFTER PUSHING THE START/PAUSE BUTTON IT JUST BEEPS AND WILL NOT LOCK DOOR AND ELECTRIC SUPPLY IS GOOD
Nov 17, 2009 | General Electric WBVH5200J Front Load...
Ge washer wcvh6260 ...... start/pause button flashes, won't start
Does the 'door locked' light come on? If not, check the switch and it's actuator (a pin that is part of the door latch).
Aug 22, 2009 | GE WCVH6260F Front Load Washer
Front loading ge washing machine only 2 months old. door locks,
take water lines off of water valve at rear of unit and clean dirt out of screens.
Jun 19, 2009 | GE WSXH208A Front Load Washer
The door is locked on my front loader washer.
PUSH THE START PAUSE BUTTON, AND CLEAN THE LINT TRAP AT THE BOTTOM OF THE UNIT
ROB
Apr 14, 2009 | GE WPXH214A Front Load Washer
Push start different sound water may start may not start pause
I would check to make sure the connectors to that door lock are all connected. If they are it's probably the lock/switch mechanism itself. Wow I just checked and they are about $120. The p/n is wh10x10006 You can google around for the best price. Good luck!
Mar 04, 2009 | General Electric WHDVH660H Front Load...
GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
Washer Start/Pause button is Falshing and won't start
Try some WD40 on the door lock. The washer won't start if the door doesn't lock.
Jan 13, 2008 | GE WSXH208A Front Load Washer
General Electric WBVH5200J Front Load Washer Logo
323 people viewed this question
Top General Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Chris Goulet
Are you a General Washing Machine Expert? Answer questions, earn points and help others
