I also have a Conia CPDP4209 Plasma TV. Last time I turned on the mains to it I only have a clicking relay and no sound opr picture. Please can you identify the problem and solution? I left it for a gfew days in case intermittent but I just plugged in again and clicking with no sound or picture is still the case. Please help retired technician.
  • jim8850 Oct 03, 2010
    I wouild like to identiry the exact faulty components. This appears to be a common fault on this model and I would have hoped the fix was common also. Thanks.
    I was hoping that one of the experts did have the exact solution as I was advised that this common fault has appeared on "Fixya" before and appeared to be rectified ok, I think! Thanks guys.
  • 5,138 Answers
Look for Bad Capacitors on the power supply board they will be vented swollen or puffed up on Top, 2200uf 10v 3300uf 10v
Posted on Oct 03, 2010
  • 1 more comment
  • rickell4350 Nov 27, 2010
    I found a 10v 1000uf cap about half way along and towards the top of the power board was the problem in my conia cpdp4209
  • ladywinn
    ladywinn Nov 27, 2010
    Capacitors should be Flat as a board on Top ,if any of them look Bugled,vented or puffed up on top replace them and yes 1000uf 10v is also one of them.
  • Allan Harper Aug 24, 2013
    Thankyou all on this page I have repaired my Conia CPDP4209 power supply and it was exactly what you said it was, bad capacitor 1000uf 10V.
  • 6,993 Answers
its a bad capacitor on the power board that is causing the clicking sound. Obviously, there is something wrong with the power board of your TV.
The power supply board is defective that's why the TV won't power up. Its receiving power but it cannot transfer the current to the necessary part of the TV because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the TV might not come on.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
Good luck.
  • Walesarumi
    Walesarumi Oct 03, 2010
    to fix this problem, you need a meter. You just have to read the power board in other to detect the bad component(s) and make every necessary replacement.
    Since you are a retired tech, this should be an easy task for you. The problem is certainly from the power board. But without knowing what part of the board that is causing the problem, you cannot proffer a solution. This is why you need the meter.
    Take care.
How do i connect a sound bar to my conia cpdp4209 plasma tv?
depends on what type input jacks the sound bar has.
mine uses RCA av cables
Apr 03, 2018 | Conia Televison & Video
I need a user manual for a Conia CL4206FHD 42 LCD TV.
http://get-files.review/n/q2a/?q=Conia+cpdp4209+manual+pdf
Visit this site. Manual for 4206 & 4209 are the same.
If you wish to get some details; visit the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Mar 03, 2018 | Conia Televison & Video
How can I connect a pc to a conia plasma tv
Your TV is supposed to have a DVI connector. But I only found that information on 1 website.
Your computer needs to have a DVI (white) connector in the back, just connect it to the same connector on the TV. You'll need a DVI cable too.
Then you will have to go into the menu and set your TV for PC input.
Nov 13, 2016 | Optics
Conia tv plasma clicking wont turn on
someone needs to look at the power supply as the clicking may be a physical relay on the power board.
Aug 26, 2012 | Samsung Televison & Video
My tv keeps turning itself off and on??? conia 42" Plasma -HDMI Product code CPDP4209
The TV has a Auto On/Off timer, so I would locate that option in the menu, and make sure it isn't set up to do it. If you find it and it is set to Off, I would imagine it is a hardware problem, which I hope it isn't! Good Luck
May 17, 2011 | Televison & Video
I have conia tv plasma model CPDP4209 O picture or sound /stand bt light on and A relay clicking on and off contiually I think the problem is A power supply fauilt .part no LJ44-00133A ACE-W2 PSPF...
I have the same tv with the same problem. On close inspection I found a capacitor was leaking. Replacing the capacitor fixed the tv. The capacitor is a 10v 1000uf, it is about in the centre and toword the top of the power board. I hope this helps.
Rick
Jun 26, 2010 | Televison & Video
My conia plasma tv model CPDP5001 has no picture when turned on only displays blue screen
hi cerrianne!
hopefully you have managed to have your TV serviced! if not and if you are intending on selling it please let me know as i have the same tv with missing boards!!
Thanks
Rob 0408 392429
Jun 12, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
42 inch LG Plasma TV - Lost picture
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
Universal remote codes for a conia tv?? Help me PLEASE :)
Thank you guys! just bought our universal remote control and now we able to use 1 remote for everything especially our conia plasma tv and it really works the 0821 code...
Mar 05, 2008 | RCA Universal Remote Control
Open Questions:
Televison & Video Logo
605 people viewed this question
Top Televison & Video Experts
