Question about Sony KLV-30HR3 30 in. LCD Television
Getting sky and the lady said my TV would be HD but there's no evidence of this - any way to "make" it HD with cables etc? Its a Sony KLV30HR3.
  • Sony Master
  • 8,457 Answers
You only can get,what is in air broadcasting shows signals,u can't changes the signal modes format.You getting those shows in modes 1080i or 1080p.The shows have a display said HD logo on right side or left side of the tv.U are getting a HD air broadcasting signal.
Posted on Oct 03, 2010
Why does the picture do this. Press sky on remote and all colours seem to b wrong but when tv button is pressed the pic is fine but not hd
If you are getting your video picture (t.v) through a cable box, satellite dish etc. you will have to adjust the internal settings of that box to match the HD settings of the T.V. as well.
Nov 27, 2013 | Televison & Video
LG 37LC2D-EC
It sounds like the TV is having sync issues with your Sky+HD box. HDCP is the "High-bandwidth Digital Content Protection" that is used between components. It requires a sync between the devices to ensure that you are not trying to "steal" the video content you are watching. This intermittent message and blacking of the screen is good evidence that this is your problem.
Even though the HDMI cable worked fine on another set, I'd try a new one anyway. Some TVs and components are more sensitive than others, and a weakened cable may not show a problem on one set, yet show it on another.
Barring the new cable not working, check LG's website for a possible firmware update for your TV, and also try using a different video source, like BluRay and see you have the same problems.
Beyond that, it may just be an issue with the TV itself starting to die.
Sep 15, 2012 | LG 37LC2D Television
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
May 08, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
How do i connect to sky hd and sony kdl 40w 4710 and dav-is10 i have hdmi from skyhd to tv and hdmi from home cinema to tv what else is required as i cant get surround sound from tv
you need a Optical audio cable, run this from the back of your Sky HD box to the Surround sound. Not all Broadcast are transmitted in DD so press your i button on the sky remote and you will see this on the yellow bar above the program information if it is..
Might be worth running a set of White and Red audio cable from the HD box to the Surround sound as well that way you can just mute your telly and have the lot coming through the surround sound system.
Hope this clears things up for you
Little Dish Fitter
Jun 05, 2009 | Sony DAV-IS10 System
Bravia & Sky+HD, aspect problem
There is nothing wrong with you Sony Bravia TV and it suppport all HD and SD formats.
Are you viewing the HD version of the channel when it is showing a standard defination show. e.g SKY1 HD instead of SKY1.
This means that regular standard defination shows are in a 4:3 ratio and does not fill the whole screen. In order to view these type of shows you will need to tune to regular channel instead of the HD version.
You can check if a show is brocast in HD by going into the tv guide and checking for the HD symbol in the programme symposis.
Example
Apr 13, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Is it hd
Strictly speaking to be HD Ready a TV must fullfill 2 things:
1. Have a Screen Resolution of at least 1024 x 768.
2. Have at least 1 HDMI Socket.
Your TV has neither of these, so it is NOT HD Ready, however, it will still be more than capable of showing SKY HD, and it will still look very nice indeed.
I would need a list of the connections on the rear of the TV to tell you which cable to buy, but:
If it has DVI, then a simple HDMI to DVI cable will do for the video.
If it has component, i.e Yb, Yr etc then you will need a more expensive HDMI - Component Video cable.
But otherwise, yes, SKY HD will work fine.
I hope this helps.
Mar 28, 2009 | Televison & Video
Ive just moved to a house with sky all ready and have not got a clue how to set the thing up. I have a 50in PS-50Q96HD Samsung HDTV Plasma. I have the sky cable and the normal tv cable, what goes were...
first of all you would need to have a Sky HD set top box.
The cables coming into the wall.. you said one was the terrestrial aerial and the other was a sky cable. In order for you to benefit from Sky HD you would need twin cable or two single cable running from your sky dish.(allows you to record a program and watch another etc.
summary:
skyHD box
two feeds coming from your dish,
there is only one place these can go as they are screw on ie F connectors. so they would screw onto input 1 and 2 on the back of the Hd box.
Run a HDMI cable from the back of the sky box from the HDMI port to one of the HDMI ports on the back of your telly. last but not least you would need to get a power cable (kettle plug) to power the thing.
In regards to your terrestrial aerial you can plug this directly into your telly or via your aerial in port on the back of the skyHD box. then you would have to run an aerial cable from the RF out 1 or 2 to the back of your telly this would allow you to record two things on your Sky HD box then switch to your built in freeview that your telly has.
Hope this has answered your questions
Cheers
Little Dish Fitter
Feb 28, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Probem getting sky to work with a new TV
An HD TV connects in the same way as a standard TV.
Connect a scart lead from the TV scart of the Sky box to the TV.
When you switch on the Sky box it should automatically switch the TV to the correct external input.
May 19, 2008 | Televison & Video
Sony KLV-30HR3 30 in. LCD Television Logo
85 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
