Question about Hotpoint Refrigerators
HOW DO I ADJUST THE DOOR OF A HOTPOINT RLS150 FRIDGE PLEASE. THERE IS A GAP AT TOP OF DOOR
joboo1
  • 257 Answers
SOURCE: Refrigerator Door not closing properly
Hi, No the door is not adjustable like you might think Since it is smaller than the other door any alignment problem is really visible. First do check the bracket to make sure you didn't lose a screw and that the brackets are solid and don't move. The problem is the level of either the refrigerator or the floor. If you have a 3 ft bubble level put in on the top of the refrigerator along the front, NOT on the door. There are feet on the bottom front corners of the refrigerator, you may have to remove the plastic grill to access them but depending on the model and age of your refrigerator it should be attached with clips. The feet screw in and out but with weight they won't move easily so you may have to jack the front a little, remove some stuff or try a crescent wrench. Once the front is level check the front to back, the refrigerator needs to tilt slightly to the rear so the door when partially open will close by itself. Again you didn't give a model so on some the rear feet are not adjustable and some are. I suspect you may have adjustable and the box is not squared up. If after adjusting the front and the entire refrigerator tilts like an uneven table leg then you have to adjust the feet likewise. Use your level diagonally across the top both directions, it should be exactly the same. If you have non adjustable and they are uneven it is the floor and you have to use shims under the low foot. Good Luck!
Posted on Jan 30, 2009
farfield
  • 462 Answers
SOURCE: Top freezer door pops slightly open when frig door is closed
try to adjust hinges and check the door gaskets for pinching. Also I have seen that if the fridge is slightly pitched forward and not slightly towards the back gravity sometimes this causes the problem you describe.
Posted on Apr 26, 2009
milten1
  • 1304 Answers
SOURCE: I changed the door from right to left hinge, but
make sure that you used all the spacers properly
but 9 out 10 times
loosen the top hinge do not remove the screws, lift he door up inot place if your in the right screw holes on the top hinge you should have enough play to close the gap then tighten the door as you hold it in place
hope this helps
Posted on Oct 24, 2009
SOURCE: kelvinator Opal CS 390 F door has dropped down on handle side.
My sister has the same fridge model. We've removed the door and the bottom bracket supporting the hinge had collapsed up inside the door. We're going to cut out a piece of steel (3-4mm thick) and glue it along the bottom of the door in order for the door hinge to insert into something solid. Looks like it's a weak point in the door construction. Pity Kelvinator wouldn't acknowledge the problem and come up with a solution (other than replacing the door at $340 - which is what we were quoted).
Posted on Nov 08, 2009
SOURCE: Smeg Fab 32 door problem
The Door on my SMEG Retro Fridge keeps opening on its own accord ? There's nothing inside poushing up against it so why does this keep happening ?
Posted on Dec 13, 2009
My samsung freezer door does not close all the way causing frost buildup. I have replaced the gasket and leveled the fridge.
The hinges usually have some adjustment on them. Two person job, or put something under the bottom of the door to support it. Loosen the hinges a bit, pull the door forward at the hinge which should close the gap on the other side. Tighten down the hinges and check again.
Jun 16, 2016 | Samsung Refrigerators
Fridge light not working
door light switch Need full model # for better idea .
but normal switch should be at bottom of door or at hing side of ref
some model have at top it may be broke off and thats why you don't see it send us a full model number we will find for you
Feb 28, 2015 | Hotpoint Refrigerators
The 2 doors on my Maytag SXS aren't even in the front when they close. The refig side sticks out. The doors are otherwise level and even in all respects. I adjusted top & bottom hin
Hello Joe;
My name is Peter. I am a retired field service refrigeration technician.
This was your first time setting the gap between the doors. So, I will share with you the various ways to adjust the doors gap.
1.) On the bottom of some doors there are adjustment screws for pitching the door left or right to set the gap. This was a good design idea, but there is not locking nut to hold the setting. Opening and closing the door will remove the setting. So, if you have these adjust screws, we will forget them.
2.) Lets try this: Adjust the front leveling bolts. Loosen the top of the door hinges. If the gap is smaller at the top, lower the leveling bolt up on the left hand side. Turn the bolt counter clockwise to raise. Pound on the doors to free them to adjust. If the gap is smaller on the bottom, on the right jacking screw, raise the jack bolt by turning the jack bolt clockwise. Once again, pound on the door to free for the adjustment. Then tighten to top door hinges.
3.) OK, This did not set the gap. The gap between the door is different depending on the model. Determine the gap which you would like to set. Using something solid like pieces of wood (do not use cardboard it will crush), loosen the top hinges, evenly space the wedges and tape them to the door. Now tighten the top hinges and remove the wedges.
4.) Ok, This did not set the gap. Look on the bottom of the door at the hinge. You have a matching set of grommets. These grommets interlock when the doors close to keep the doors closed. These are high wear components. The doors rest on these components. One grommet set may be more warn than the other affecting the door gap
Dec 04, 2014 | Maytag MSD2542VE Side by Side Refrigerator
Frost in freezer FFFL 2010
There should be a defrost timer built into the fridge, every fridge has them. This may need replacing.
Jul 25, 2012 | Hotpoint Refrigerators
Swap door sides on hotpoint future RLA30 fridge?
tip unit over on side,placing an old blanket or similar on floor under unit.there are 3 little bolt/screws holding each bracket to the underside of unit,unscrew these/lay brackets on floor, slide door down off pin on underside of top.and unscrew this pin.change over from right to left replace door onto pin replace bottom hingepin,adjust door for" squareness " and tighten all screws lift back upright and switch on...will take a little time to settle down temp wise.... make sure seal sits tight all round good luck ..geoff
Feb 19, 2010 | Hotpoint RLA30 Compact Refrigerator
Refridge door does not close evenly on my side by
Top hinges can swing right to left slightly when all 3 screws are loosened under removable cover. Use a 5/16 nut driver. Hinge cover may be phillips, 1/4" or 5/16".However, fridge case must be level left and right first. Level fridge with adjusters behind toe kick cover. Once level, you can adjust gap between doors with top hinge movement. Keep in mind that this is a man-made product and you may not get the doors exactly straight due to lose manufacturing tolerances.
Jul 24, 2009 | Refrigerators
Apr 26, 2009 | GE Refrigerators
RLA80 FRIDGE IS ALWAYS DRIPPING WET
the cold air is leaking that's why there's condensation build up outside... a fast way to check is to get a plastic card and try to slide it through the rubber seals or the door all around. if it passes through easily then you have a leak in that area. a good door seal won't let your plastic card pass thru easy.
Jul 24, 2008 | Hotpoint RLM80 Refrigerator
Remove the lower hinge on the fridge door and pack out using a piece of cardboard resrcew the hinge onto the door, this will resolve the problem Regards Advisor Smeg Agent
Jun 08, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Open Questions:
Refrigerators Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
