Question about Motorola Mobility L6 Cellular Phone
Does this phone connects with computer? - Motorola Mobility L6 Cellular Phone
    Problem Solver:
  • 9 Answers
Use Motorola Phone Tools. update the software online and it works.
Posted on Oct 03, 2010
Downloading photo to computer
You have to connect the phone via blue tooth or usb cable. If you connect via bluetooth you have to run the software to tell it what file on the computer you want it save pictures. then you need to pair the phone to the computer and after it connects you will be able to see the files in your phone. You have the option to use the computer to look at the phone's files or the phone to send files to the computer.
Feb 19, 2015 | ZTE Cell Phones
How to install phone suite
connect your phone to a computer using the usb bluetooth connection on the phone and the usb connection to your computer once connected it should show on your computer
http://www.soft32.com/windows/system-utilities/mobile-phone-tools?rel=breadcrumb
there are many phone utilities
hope it helps
Jun 07, 2012 | Myphone Computers & Internet
Cannot exchange the data between my computer and my mobile my computer use window 7 Thanks in advance
Whenever you connect your phone to a computer using the USB cable, the Connect to PC screen opens and lets you choose the type of USB connection. Select one of the following choices, and then tap Done: Charge only Select this option if you only want to charge the battery while your phone is connected to your computer. HTC Sync Select this option to synchronize contacts, calendar, and other information between your computer and your phone. Disk drive This mode is available only when there's a microSD card on your phone. Select this mode when you want to copy files between your phone's storage card and your computer.
When Disk drive mode is enabled while your phone is connected to the computer, you will not be able to use apps on your phone to access the storage card.
May 03, 2011 | HTC Desire HD Cell Phone
How do i connect my phone to my computer
There are two ways you can connect your phone to your computer.
1) Using the cable which connect one end to the phone and another end which connect to the USB
port of your computer. After connecting the phone, you can see your phone, by visiting My
Computer. Your phone will be listed in harddrive portion
2) The other way is to connect your phone using bluetooth technology, for this to happen your pone
must have Bluetooth technology as well as with your computer. If your computer and phone
both has bluetooth technology,
a) Turn on bluetooth device on your phone as well as your computer. Then from your computer,
you can discover your phone. After searching most computers will give a code to put in the
cell phone to pair. Enter the code and computer will pair with your cell phone
Try your luck!! :)
Apr 03, 2011 | Samsung Cell Phones
I need to use this phone as a modem for internet. How?
  • Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the AT&T Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
  • Launch Internet Sharing, found in the Start menu on your AT&T Samsung cell phone. Open the application.
  • Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than AT&T is showing on the display.
  • Start the Internet Sharing connection. On your AT&T Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
  • Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your AT&T Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
Feb 04, 2011 | Samsung SGHE250i Cell Phone
How to connect my nokia 2690 to nokia pc suit
  1. Get the PC suit on your computer,
  2. Click and open the PC suit,
  3. You will see a phone with a message, "CLICK TO CONNECT A PHONE",
  4. The set up wizard will pop up, then you follow the instruction from there, asking your preferred mode of connection " Cable connection, Infra red connection or bluetooth connection, Make sure your computer has a infra red port or bluetooth on it, or you get the necessary infra red or bluetooth dongle and connect it to your computer.
  5. Then you will be able to operate your phone using the pc suit.
That is how to connect your phone using the PC suit.
Take care
Dec 25, 2010 | Nokia 2626 Mobile Phone
How do you put your pictures on the computer?
Hello there and welcome here
As far I remember, when I connect my phone to my computer there is coming a screen (in the phone or the computer) where i can connect it to the computer in several ways !! that means if I connect in in one way I have only possibility to reach my mp3 files, but if i connect it in full connection then I can transfer my photos too. So When you plu your phone in to the computer you have to choose the connection way, and bee sure that it is the full connection otherwise you only have the possibility to access your songs.
Hope that helps
IF NOT then try to return here
Have a nice time over there
Please rate my answer
Jan 02, 2010 | Verizon Communications LG Chocolate Cell...
How can i use my motorola z3 to connect with the internet
If you mean "how can I connect my computer to the internet using my phone as a modem," then this is possible. Just set up an internet connection from your computer to go through your phone (works wirelessly, I've never tried with USB), and make sure you have a Data Plan on your phone. Connect to the internet with your phone and then use it like Wi-Fi. Keep in mind this will be much slower than using an internet card or any other sort of wireless connection to the internet.
As for getting internet on your phone through your computer, I'm pretty sure you can't do this. It doesn't make sense to even try. It's redundant. Just download what you need using your computer. Then sync the phone to the computer via bluetooth or USB and transfer whatever files you desire to your phone. There's no need to get the phone directly connected to the internet if you have a computer that can get on the internet.
Jan 26, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
Connecting phone to computer
Go to vzam.net to download the latest software for XP. That might help. Also I believe you can save songs to a memory card using a card reader instead of the cable.
Oct 25, 2007 | Samsung SCH-u740 Cellular Phone
Motorola Mobility L6 Cellular Phone Logo
19 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
