How to remove lock on digital top box - Televison & Video
  • 49 Answers
Sir You enter the code by remote (it is default). or I will give some comman codes try. 1234 $ 0000$9999$receiver modelnumber
Posted on Oct 03, 2010
Indesit iwdc6125. All 5 top lights flashing and rinse and door lock lights are on. Does this mean the module needs programming?
The door lock is faulty. I removed the top cover and removed the red control box from its nylon casing on the lock. I then broke the locking mechanism. Leave the control box connected or it won't work. My machine works but no longer locks so could be a problem if you have small children.
Mar 29, 2012 | Indesit Washing Machines
Screen says write protect
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If that doesn't do it, try another card.
Aug 05, 2011 | GE A1255 Digital Camera
How to remove left and side casing from kyocera fs-c5025n please
FS-C5025N left cover removal.
1. Open the rear cover.
2. Open the top cover.
3. Remove the opening and closing axis from the main unit frame and then remove the top cover. It pry's out at the hinges.
4. Open the left side cover and then remove the one screw.
5. Remove the waste toner box. To remove waste toner box, press the lock lever in.
6. Remove the paper feed unit .
Feb 18, 2011 | Kyocera FS-5025N Laser Printer
My brighthouse remote can turn my tv on and off but not change channels
The remotes have several device keys at the top of the remote. They have abbreviations like "VCR", "DVD", "TV", "CBL". By default some actions are locked into a specific key. By default, the volume buttons will always control the TV volume and the channel buttons will always change channels on a digital box.
If you have a digital box, and the channels wont change, the default locks might have been removed. Consult the instruction manual that came with the remote and re-lock the buttons to the correct device key. Otherwise you will need to press the "tv" button when trying to change volume and the "cbl" button when trying to change channels.
If you do NOT have a cable box and are just simply trying to use the universal remote as a primary remote, you will need to unlock the global channel lock. Consult the manual for the remote or check online for the remote guide. The Company which makes the remotes is called Universal Electronics and you can find digital copies of their manuals on the Brighthouse Websites.
May 20, 2010 | Sylvania LC320SS8 32 in. LCD Television
Get engine air filter out and install new.
Step 1 Unfasten wire harness to MAF (massive air flow) sensor located on top of the black tube leading from the air box to the plenum.
  • Step 2 Unplug the vacuum line located on top of the black tube. This simply pops in and out so you might need to be forceful, but apply common sense since it's a plastic vacuum line.
  • Step 3 Loosen band clamp with the screw driver at the top of the black tube that is attached to the aluminum air chamber that run to the plenum. Also, loosen the other band clamp located at the bottom of the tube closest to the air box. The idea is to remove this tube with the MAF sensor intact in between. Do not remove the band clamps, simply loosen them enough to wiggle off the tube and move it out of the way.
  • Step 4 Unclip both fasteners at the top of the air box and pull out and up to remove air box cover. Remove old air filtermag-glass_10x10.gif and if there's a good deal of dust and debris inside the air box, you could wipe it out with a rag or even vacuum it out with a shop vacuum.
  • Step 5 Insert new filter and replace air box cover. Make sure the retaining tabs are locked in at the bottom correctly. Refasten top locking clips to air box cover.
  • Step 6 Reinstall air tube making sure to replace top part back on correctly to aluminum air chamber. Not properly reinstalling this air tube will result in the computer of the car throwing a check engine code. On the bottom of the black air tube is a small tab and if tube is replaced properly should line up in a notch molded into the air box cover. Tighten band clamps with screw driver and reconnect wire harness and plug plastic vacuum line back in.
  • Mar 15, 2010 | 2002 Buick Rendezvous
    There was a problem closing the door on the lock box. The tennant did something and finally the lock closed. I think there was a reset of the combo. Since they left we cannot open the lock box. Now we have...
    I've got a similar lock here in the UK.See photo No.3 I do know that the combo can be changed but only when the box is open. The original combo is then negated and only the new one can be used. Some models have an override key
    If not then from the inside the house unscrew the box. The code is contained in the outer section with the push buttons. Look at the back and there should be visible the locking pins under a back plate with pin numbers - usually the tops of the pins are coloured red=a number of the combo code
    If no colours can be seen, remove the plate, with care as there are small springs under it, then push and hold the C cancel button and ease out the pins noting that the pins are grooved, differently for lock and non-lock Lay them out on each side of the lock and look for a number of them with the same grooves equal to the No. of combo digits & the pins will be the lock pins. Replace in the order of your new combo No. and reassemble [these pins are handed - a left will fit a right by rotating through 180 degrees]
    Hint - watch the springs they can fly out and are vital
    Hint - note new combo in cell phone
    Hint - red paint tops of pins for next time
    If this is a key storage box, I have this too. email me plz rod-davies&hotmail.com
    Jan 11, 2010 | Master Lock 5400d: Portable Select Access...
    How do you remove the cover to replace the air filter?
    1. Unfasten wire harness to MAF (massive air flow) sensor located on top of the black tube leading from the air box to the plenum.
    2. Unplug the vacuum line located on top of the black tube. This simply pops in and out so you might need to be forceful, but apply common sense since it's a plastic vacuum line.
    3. Loosen band clamp with a screw driver at the top of the black tube that is attached to the aluminum air chamber that run to the plenum. Also, loosen the other band clamp located at the bottom of the tube closest to the air box. The idea is to remove this tube with the MAF sensor intact in between. Do not remove the band clamps, simply loosen them enough to wiggle off the tube and move it out of the way.
    4. Unclip both fasteners at the top of the air box and pull out and up to remove air box cover. Remove old air filter and if there's a good deal of dust and debris inside the air box, you could wipe it out with a rag or even vacuum it out with a shop vacuum.
    5. Insert new filter and replace air box cover. Make sure the retaining tabs are locked in at the bottom correctly. Refasten top locking clips to air box cover.
    6. Reinstall air tube making sure to replace top part back on correctly to aluminum air chamber. Not properly reinstalling this air tube will result in the computer of the car throwing a check engine code. On the bottom of the black air tube is a small tab and if tube is replaced properly should line up in a notch molded into the air box cover. Tighten band clamps with screw driver and reconnect wire harness and plug plastic vacuum line back in.
    Oct 27, 2009 | 2003 Buick Rendezvous
    Digital safe
    remove the stickers next to the digits, the loosen the screw.. remove the panel.. and there u'll find the keyhole 2seconds of work
    Sep 26, 2009 | Safe International Digital Electronic Safe...
    The remote control for my digital set top box,has stopped working i have changed the batteries to no avail.could you help.
    Have you tried to unplug your set top box from the mains electric supply, leave it unplugged for about one minute & then power the box back up & then try the remote control. Sometimes the box can lock up & cause problems like this.
    Jul 12, 2009 | Televison & Video
    Televison & Video Logo
    15 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
