Question about HP Compaq 6720s Notebook
My dvd rom does not open and does not read any DVD or CD and noticed that the data cable behind the dvd rom when opened has been cut.dvd rom is not getting detected? What shud i do ? change the whole dvd rom or can i change the data cable only? please assist.
  • HP Master
  • 4,924 Answers
Change the cable
Posted on Oct 03, 2010
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
I have e machines EL1300G-02W desktop pc has dvd rom can i add a cdrom drive?
Your DVD-ROM drive will also play CD's. You can also easily remove it and replace it with a CD-ROM drive if you like. Simply open the case, unscrew the DVD-ROM, remove the power and data cables from the back and pull it out through the front of the case. Installing the CD-ROM just involves doing this in the reverse order. Make sure your computer is off and unplugged during this process.
Mar 05, 2011 | E-Machines eMachines Desktop PC
My DVD-CD rom (TSST corp. DVD +-RW TS-L63H) don't function or maybe it was corrupted by virus.
The problem might be that the DVD-CD rom might be having a lens/laser problem, the lens might be weak and cannot read discs anymore. So it would not be functioning anymore. The solution to that is for you to get the laptop opened and remove the DVD-CD rom Then open the CD rom up and replace the lens.
Also the problem might be that the DVD-CD rom might have been disconnected from the inside, so all you have to do to solve that problem is for you to open the laptop up and try a new connector cable and secure the connection to the mother board is tight, then run the CD rom after reassembling the laptop together.
Take care and good luck
Oct 19, 2010 | Computers & Internet
I cannot hear sound system play cds and videos
Every CD/DVD-ROM drive has an audio port opened. An audio cable connects to the back side of the CD/DVD-ROM and connects to the motherboard. Most MB's have two four pin audio ports, one slot white in color and a second black in color. As far as the CD/DVD-ROM not reading the disk. Make sure the disk is free from scratches; oils from you're fingers or just plain dust. Open the drawl and blow out the CD-ROM drive or buy a CD cleaner which will clean the internal laser. These days it’s hard to find a CD/DVD ROM drive with a warranty longer than 1 year. Most ppl buy a new one when it fails to read CD's.
Cheers'
Mike
Jun 19, 2010 | Intel Motherboard
My sony dvd rom is not displaying on my computer., for example G drive. So i am not able to read and write any dvd.
check the communication cable are inserted or not, you can see it to open the cpu cover and look for the same, there are two cables are inserted in dvd/cd rom first for the power and second for data. if you find all the things are ok you can check it from your BIOS settings.
Jun 07, 2010 | Sony DDU-1615 / 16x DVD-ROM / 48x CD-ROM /...
Programs not reading the burner
you mean CD/DVD rom is not being found by ur system.
Well check out in my computer whether CD rom is displayed or not. and if not, then i guess u've to open ur cd rom. Dont worry, m not sayin u to open it completely, unscrew few screw from behind, u'll find a power cord from cd rom. adjust that. and also adjust the data cable connected. This might be a problem due to loose connections of power cord or data cord.
If still it doesn't works, then it might be ur system problem. try to restore it using System Restore in Accessories-System Tools to the date when u last used it...
hope it fixes u up....
Aug 27, 2009 | HP Pavilion DV6700Z Notebook
My sony dvd rw aw-g170a drive is not detecting certain DVD's!!!!!
if you have CD RAM and DVD ROM then change it to CD/DVD ram because in case of CD RAM and DVD ROM it may read CD but not DVD but sometimes it can read DVD also but when we copy data to computer it may freeze or give us error so i give you one suggest to buy a new CD/DVD RAM
Jun 26, 2009 | Sony (1-796-293-13) Plug-In Module DVD...
Packard bell CD rom
Cheak cd rom data cable pluge in maight be cable is unpluged and verify the port connection also
Jul 01, 2008 | Packard Bell GCD-R580B (gcdr580b) Internal...
DVD NOT SHOWING
hi frined
change ur data cable & power cable & try to ditecing
if not show then do one ting go in a device manager >system devices>pci bus>right click on it & uninstall then ur pc is restarts
& insatll ur all divce drivers correctly
thnx using fixya
Apr 01, 2008 | LG (CRD-8400CB) CD-ROM Drive
HP Compaq 6720s Notebook Logo
115 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
