Question about Samsung Microwave Ovens
My samsung microwave oven is not heating up food. It works normally, lights on, food turning on plate, but not heating the food.
  • 560 Answers
If your microwave does everything you have described , and you can hear the cooling fan running as well after you press the start button , you probably have a faulty wave guide. The wave guide is also called a Magnetron Tube. It is the main part of the microwave which produces the microwave energy . If this part is not functioning it is best to replace the entire unit, rather than have it repaired .
Posted on Oct 03, 2010
Food not getting heated
There are three common issues, magnetron "heats food" cracked high voltage diode, or a shorted high voltage capacitor. In order to find out you will need a professional to assess, it will be probably cheaper to replace the microwave oven.
Mar 16, 2012 | Electrolux Microwave Ovens
Lights working..plate rotating. normal sound is heard but not heating food on any level
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jan 24, 2011 | Baumatic BTM231SS Microwave Oven
My GE Profile over range microwave spacemaker xl 1800 model jvm1870bf02 was working just perfect until my daughter decided to use the microwave as a timer and actual ran the microwave with nothing inside...
Magnetron is blown.
This high-energy microwave-transmitting device hides behind a small plate on side of oven.
The waveguide sticky-out part looks like a small tube.
Normally, water molecules absorb the energy, heating the food.
Without an absorbing 'load' inside the oven cavity, the high-frequency, high power energy bounces back into the magnetron and it destroys itself. (Magnetron Hari-Kiri).
In a nutshell, tech must renew magnetron.
Then iInstruct family members to never run it empty.
Oct 11, 2017 | GE JVM1850 1000 Watts Microwave Oven
Unit does not heat food. the light and rotating plate work but food is not heating.
It could be a faulty magnetron, which is responsible to warm up the food. If that is the case, then the cost price of that part is quite expensive and you are better off replacing the whole unit rather than spending money on buying the parts.Hope this helps.
Aug 14, 2010 | Samsung MT1066SS Convection/Microwave Oven
Microwave lights up plate turns something hums inside but the inside of the microwave never produces heat.
Sounds pretty normal but the inside is not supposed to get hot - only the food is.
Try heating a half glass of water for 1 minute if it gets hot... its working - if not then the actual microwave generating device inside has probably died.
In that case buy a new microwave oven as the cost of parts and labour to repair is usually more than cost of buying a new one.,
Jun 09, 2010 | Maytag MMV1153A Microwave Oven
Food won't heat up
Hello, I had the same problem, and just fixed mine. Start by turning on your microwave (on mine, the light turned on and timer worked, but the fan nor the plate turned)... push the door upward and see if the microwave turns on... (mine did). so far so good. open the door and take the upper hinge cap off with flat head screwdrive. take the door off and place a small washer on the bottom hinge, put the door back on. your microwave should be good now. essentially, the door just needs to be pushed up a bit so it will work.
good luck, hope that works for you...
Jun 01, 2010 | Frigidaire FMV156DC Microwave Oven
Not heating food
Sounds like the magnetron has failed. It will need replacing by a qualified microwave engineer to be sure it's safe.
Jul 18, 2008 | Samsung Microwave Ovens
Microwave Ovens Logo
2,080 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
