Hi i have a daewoo front loader air power 7 kg and it keeps saying E8 error can you tell me what that means please as it is only a week old thanks
SOURCE: front loader washing machine, 7.5 kg model no. WD 1049C
The machine will not start of the dial where you select the wash time it has the letters CL
What does this mean?
Why is it not starting - had it for about 2-3yrs has been fantastic until now.
Posted on Oct 14, 2008
SOURCE: i can't open the door of my washing machine it is
FOR ANY REASON THE WASHER MACHINE DIDNT FINISH ITS CYCLE!!! AND IT IS A SAFETY THAT IF DOESNT FINISH ITS CYCLE THE DOOR WONT OPEN!!!!
I HAD ONE LIKE THAT AND I BROKE IT APART!! AND I SAW THE WATER PUMP WAS THE PROBLEM SO I CHANGED IT AND PUT IT BACK TOGETHER AND LET FINISH ITS CYCLE AND OPEN THE DOOR!!! AND STILLS RUNNING!!!
Posted on Oct 05, 2009
ginko
  • 19396 Answers
SOURCE: Daewoo Washer Error E8
Hi.
E8 is fault connection from CCU (Control board) to balancing sensor.
When you get E8, this is often because of a faulty control board.
Try first disconnecting power for a couple of minutes, to reset the appliance.
If you still get E8, then you need to call a technician. Testing is done jumping the two wires to the sensor to bypass the sensor, then replacing either sensor or control board.
If you want to arrange a repair, then you can call the phone number listed on the machine owners manual.
Regards.
Posted on Nov 08, 2009
  • 10 Answers
SOURCE: electrolux Front Loader 7 Kg Error
From the manual E20W Problem with water draining
Posted on Feb 08, 2010
  • 3 Answers
SOURCE: E8 code when washer fills on front loader daewoo
E3 CODE WHAT MEANS
Posted on Apr 09, 2010
I have a Daewoo washing machine DWD-F1011 S, 7 KG..IT STOPS AND gave us an error with code E8.. HOW CAN WE SOLVE IT?
this is what I found E8 Washing machine motor error detectedA fault has been detected with the main drive motor.
  • Check motor connection block
  • Abnormal loading condition
Mar 13, 2015 | Daewoo Washing Machines
My new bosch logixx front loader washing machine (3 weeks old) is showing a flashing error code F:43....what does this mean ? Thanks
I just realised that I don't appear to have a comprehensive list of Bosch error codes, but some quick research tells me that F43 is a motor error, usually associated with the motor brushes requiring replacement (Though they may also be sticking and just require removing, cleaning and re-fitting).
Jun 30, 2011 | Washing Machines
User guide washing machine nikai
I have nikai top loading washing machine6.5 kg, machine showing error code E8 , what is the problem, i have no manual booklet , so please tell the problem to solve.
Jan 28, 2011 | Washing Machines
I have a DAEWOO DWF-1150P top loader washing machine and when I switch it on I get an error code E9. Can you please tell me the fault and how to repair it?
I have a daewoo top loader washing machine ,,
Mode W/M-DWF-200MP
The power main board does not take the programs to work how should be its olny one program
Apr 29, 2010 | Daewoo Washing Machines
Error code E8
Most likely a control or motor issue. Probably should call service.
Sep 15, 2017 | Daewoo Washing Machines
Hi.
Regards.
Nov 22, 2008 | Washing Machines
Siemens XLP 1400 stops with F12
The manual says that it means there's water in the base pan because the apliance is leaking and you should callCustomer Service.
I cleaned the filter and then put the machine onto its Empty cycle. After that it worked.
Oct 19, 2008 | Siemens WXLP1460 Front Load
Error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Sep 08, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Water usage per cylce
water usage is about right. top loaders use far more and so does hand washing
only way there would be excessive water usage is if machine were overfilling
Aug 13, 2008 | Washing Machines
Washing Machines Logo
115 people viewed this question
Top Washing Machines Experts
