Question about Garden
Hi, I have the Ryobi RLT5031 electric trimmer. There was no power when I pressed the trigger. I opened up the handle to see if all was well. There are two blue and two brown wires on 4 pins of a 6 pin switch. Can you tell me which wire goes on which pin. Is this why it's not working? Many thanks, Mel
Mechanic688
  • 204 Answers
SOURCE: wiring a mic
The Delta Force and Omega Force are wired the same way, so if the mic is not working on the radio, check the mic out to make sure it's working. Make sure you have the mic gain turned up on the radio. I assume the mic was not wired for another style of radio??
Posted on Jan 13, 2008
SOURCE: Ryobi Electric string trimmer
TJ, I've had the same problem since yesterday and I found the solution (lots of googling - that's how I found your post BTW).
It turned out that the switch malfunction is a common problem.
The part number for the FA3-4 switch is:
ut41002a-36 ("switch assembly")
Available here (thru Amazon):
http://factorylawnandgarden.com/product/553902/B000PLVCX8/SWITCH_ASSEMBLY_UT41002A_36/
It's a Homelite part, which is identical to Ryobi.
Here is the manual showing it (part 6):
http://www.m-and-d.com/pdfs/ryobi_tool/RY41002.pdf
Here is the thread with the solution:
http://www.ryobitools.com/dc/dcboard.php?az=show_topic&forum=112&topic_id=597&mesg_id=597&page=3
HTH,
Adi
Posted on Jun 25, 2008
SOURCE: RADIO INSTALLING
with the bose sound system you have to bypass the audio system through the factory amp. the factory is located behind the right side of the glove box.
Posted on Sep 29, 2008
AlmostBob
  • 550 Answers
SOURCE: Gas/oil mix ratio for Ryobi Trimmer
50:1
Posted on Oct 10, 2008
ginko
  • 19396 Answers
SOURCE: Diehl Timer 4 pin wiring
The documentation for this timer is not available for download, you can enquiry about this device here :
Posted on Oct 15, 2008
Electric hedge trimmer want run why?
electric hedge trimmers have 2 switches to press before it runs
one is the trigger that you pull and the other is in the handle that you hold in your left hand
both have to be on before it starts
it is a safety feature to stop operators cutting off their fingers
Jun 09, 2016 | Little Wonder 2230S 30 Single Side Hedge...
How to fit a trigger spring on a Ryobi Trimmer model PBC-3020
I have to go on general experience with my knowledge of Rybobi on this one. The handle of the unit where the spring is should have several screws in recessed holes. If you remove those the handle should split in two. When you do this make sure you are careful when separating it. There are usually some small parts that have specific places and you want to see how they seat back in there as you reassemble.
Aug 15, 2014 | Ryobi Garden
How do you fix a jammed trigger on the Ryobi 10 Amp Electric Power head
Not really a fix but it worked for me. I opened up the case. Their is a little black box with a red button that must be depressed. Pulling up on the trigger pushes the button. Their is what i call a counter press above the trigger. By pressing it, it makes room for the trigger to slide up and press the red button. There isn't much you can do improve this process. But i took the two springs off the trigger and depressed them trying to shorten them thus reducing the force needed to press. The counter press in spring load. I carefully stretch it by pulling on the end directly above the trigger(not against the frame). This took some pressure off the counter press. I finally took a small file and carefully filed down the edge of the counter press where the trigger presses against. This makes it slide upward easier even if the counter press isn't pressed down fully when you squeeze it. The trick is pressing the counter press first, but doing these things has made my trigger a lot smoother. It use to be a hard press to activate, but now it is 10 times better than it use to be. Good Luck!!
May 17, 2014 | Ryobi 10 Amp Electric Power Head RY15122
Hi i want a trigger for a husqvarna strimmer 39r part number 502 1170-1 serial number 8500542
I have a whole 39 r wih a broken casting ( so handle is no longer attached to the engine body. tryong to get rid of it
May 07, 2010 | Ryobi 15" Electric Factory Reconditioned...
Getting the Ryobi Started
You don't mention what model. On mine, CS26, it says, Turn handle switch to on (right as your holding it), press primer bulb 7x, turn choke handle to start (down), pull till unit starts. Run 6-10 secs then turn choke handle to run, (up). Do not squeeze the throttle trigger during start procedure. Hope this helps
Apr 23, 2010 | Garden
My Ryobi Electric Trimmer RLT5031AH has been incorrectly Assembled with the Handle 180 degrees out of line. According to the instruction book this cannot be reversed. Can you possibly help?
If your talking about the top handle where the trigger is let me know because I beleive you can remove the screws and turn over to opposite side watching throttle cable is ok.
May 15, 2009 | Garden
Gas Trimmer will not stay started
My straight shaft trimmer will idle but dies when the I pull the trigger.
Apr 03, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
