Question about Sewing Machines
A Brother, Charger 622, I bought it second-hand. It needed a good cleaning & I took out the bobbin case in the bottom of the machine & can't put it back correctly. Needle breaks.
  • 5 Answers
SOURCE: needle will not pick up the bobbin thread
www.whitesewing.com try there web site
Posted on May 29, 2007
louislevel_2
  • 374 Answers
SOURCE: bobbin thread breaks. sounds like clicking while sewing
hi there,
pls, the see the figure how bobbibs thread directionc21dcd7.jpghave you seen theres a screw on latch body case of bobins,you can adjust this but mostly this is factory
adjusted,bobbin tension can adjust here.but try to follow the thread direction.set up again the dial setup tension to #3 and stitch to #8 to #12.bobbins slip due to accumulation of thread under
bobbins.hopefully this may help you to continue sewing.
have a nice day,
Posted on Apr 19, 2009
Mimito7
  • 128 Answers
SOURCE: Needle hitting bobbin case and breaking off
It sounds like the machine is out of time.. However, it is not an easy fix at home.
SOURCE: Bobbin Case Spins - in Huskystar C20
I had this problem when I first bought my machine. I took it in and they told me it was a recall problem. All the machines were having the same problem. They fixed it and I have not had the problem since. I bought mine at a Joanne fabrics. Hope this helps.
Posted on May 28, 2009
  • 10 Answers
SOURCE: Needle breaking, hitting bobbin case
I had this problem and it is very easy to fix!
With mine I looked at it for about half an hour, and all I needed to do was put the bobbin case back in,(how it fits normally) and then hold it and turn it anti clockwise until it clicks, it may be quite pressured to do but ive heard a lot of people having this problem and thats all that needed doing!
Hope i helped! :)
Posted on Oct 28, 2010
I need a schematic for a Brother 6700 embroidery machine. I cleaned the bobbin case and around it and now the machine is making lots of noise.
It is probably one of two things,
1st..always put the needle plate on before you install the bobbin case. You can lock the bobbin case down by putting the needle plate on after putting the bobbin case in. Take off the plate and remove the bobbin case, install the needle plate, then install the bobbin case.
2nd...your bobbin case may be damaged now, if it is scratatched or chipped get a new case.
Good Luck
Jun 30, 2017 | Brother Sewing Machines
Brother 700e
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Aug 16, 2012 | Brother SE-270D Computerized Sewing...
Brother Sewing Embroidery Machine
I agree with sylviaivie about find another repairman, they are suppose
to guarantee the work they do.
when the upper shaft is replaced & then the machine is retimed
the machine should work just fine.
but just don't take it back to that man to be repaired
here is a tip if it happens again,,
always try to cut the top thread first,
& turn the machine up on it's back to access the bottom cover
take the cover off the bottom to get access to the bobbin thread
where you can cut the bobbin thread
then you should be able to get the needle out without breaking it &
damaging the upper shaft, replace the needle & make sure
that the thread is good quality & not knotty, clean out the bobbin area of lint or thread
always change the needle on the embroidery machine every project
make sure the bobbin area is kept clean of lint or thread
clean under the needle plate at least once a week for lint if you
embroidery everyday or just often
Aug 01, 2012 | Brother Sewing Machines
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
Jun 09, 2012 | White Sewing Sewing Machines
Pfaff 2024 bobbin case basket is jammed-even after clean & oil
the jam that happened may have caused the machine to jump time & it would have to be serviced
May 16, 2012 | Sewing Machines
I've cleaned, oiled, bought new needles new thread new bobbins held the thread away 3-5 inches tried all tensions rethreaded ect.. and my thread always breaks when i start sewing...
clean under the needle plate where the feed dogs are for lint
also clean in the bobbin area for lint or loose threads
also check for burrs on the needle plate or on the bobbin & case
it could also be out of time
Nov 22, 2010 | Brother LS-1217 Mechanical Sewing Machine
My machine was working.fine when during a seam it froze. I took off the the bobbing cover and saw the bobbin case had shifted out of place. I replaced it and got the needle moving freely again and now my...
also get a can of air & use it on the bobbin area
change the needle
rethread the machine top thread & bobbin
make sure the bobbin is not warped or damaged
check the top thread tension
Nov 17, 2010 | Brother CS6000i Computerized Sewing...
Mar 21, 2009 | Husqvarna Viking 1
Thread getting stuck
We had he same problem with no solutions posted. Solution: First, make sure the bobbin case is clean. Ours was slightly rusted. The rust acted like a fine sand paper keeping the thread from encircling the bobbin. We used an metal cleaning powder to remove it. we also noticed that the entire bobbin area of the machine was dirty and had oxidation on the metal. We cleaned that as well.
Second, we checked the hook's action. (We took off the ring around the bobbin and removed the bobbin case as well. we left the hook in the machine and then turned the machine. We watched for how well the hook grabbed the thread from the needle.) We noticed that the hook was slightly slow and was not grabbing the thread. The hole in the needle was slightly above the hook as the needle retreated and hook spun around.
To repair this, we took off the front plastic cover (the side facing the operator). There are screws on both sides of the machine for this. After the cover is removed, you will notice a flat bar going from top to bottom about 1/3 from the right of the machine. This bar has four screws. This bar is the timing adjustment for the bobbin hook. Loosen all four screws. If you turn the bobbin by hand, you will see the bar flex back and forth. Turn the bobbin all the way to the right and tighten the screws. The hook should now catch the thread properly.
Aug 25, 2008 | Brother LS-1217 Mechanical Sewing Machine
Bobbin case is moving out of place
I was having the same problem with my machine and finally the spring broke. I couldn't find any parts for this so my husband made me a new spring out of a coke can! LOL!! Anyway, he messed with it for a while and it kept doing it. He figured out that it was not the spring but the other piece under the spring was not pushed up far enough to keep the bobbin case in place so he took a screw driver and pushed it forward toward the bobbin case and now my bobbin case does not move!! And the machine is sewing perfect! At least for now. Anyway, it's not the spring or the thread adjusting screw!
Jun 06, 2008 | Brother CS6000i Computerized Sewing...
Sewing Machines Logo
611 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
