Question about Panasonic Televison & Video
Panasonic DVD DMR-EX99VEB. When turned on, the machine displays "HELLO" but wont do anything else. It is stuck in DVD mode and wont allow any other mode to be selected. Any answers?
  • 49 Answers
Hi It is lence problem, first clean the lence by using good quality lence cleaner(without liquid). and then remove the cover and top of the spindle. slightly clean the lence by cotton.Till problem will continue change the lence.
thanking you
Posted on Oct 03, 2010
Tip
DVD stuck on Panasonic DMR ES10 in eternal cycle of "self check"/"please wait"
My DMR ES10 was eternally in a "self check"/"please wait" cycle. Couldn't even turn it off normally. By pressing the "Power off" for 10 seconds it will turn off forcefully. Now, after it says "BYE" press the "CH UP" (on the recorder, NOT on the remote))+"STOP" (with the recorder turned off) for another 10 seconds. This will force the opening and we now can take the DVD off. Turn the DVD recorder ON and, if the problem is on the laser, because of dirt, etc it will work and we can now run a DVD cleaner. In this case, the machine was stuck just because the first thing it does is check the DVD inside, and because it can't and just keep trying, it will never do anything else, until we take the DVD off with it turned off.
on Oct 18, 2013 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have Panasonic dmr-e95H and need to reset the
My DMR-E95H displays: "CHK REMOTE2" whenever I push a button on my "replacement" remote. Is there a way to reset the DMR-E95H without the original remote?
Apr 05, 2010 | Panasonic DMR-EH57 HDD Recorder Player
Panasonic DMR-EX768 displays message EXT-L and wont let me access the guide menu or record anything. Can anyone help please.
Hopefully you will have figured this out by now but you have accidentally turned on the external link function (used to automatically record from a sky box or similar) - simply press the ext-l button on the remote (second row from the bottom of the remote, 3rd button from left) to turn it off again and everything will work normally once more.
Feb 07, 2010 | Panasonic Televison & Video
Machine stuck on remote dvd 2 setting
Try holding 1 and enter at the same time for more than 3secs
Nov 16, 2009 | Panasonic DMR-E50 DVD Recorder
Hi when I turn on my Panasonic DMR-EZ45VEBS I get an error that states 'LD FVU' then the CD slot ejects. It them simply doesnt allow me to do anything. Has anyone experienced this? If so can you help fix...
I get exactly the same problem with my Panasonic EZ48 recorder.
It also displays FM List DL error .It sometimes sorts itself out by holding the on switch for 20 seconds.
Ian
Nov 29, 2008 | Televison & Video
DVD recorder DMR-E55
You can try a factory reset (reboot).Here are the steps..
The following will set your recorder to the Factory defaults.
(Will not format HD on DMRE80).
With power off (stand-by mode/CLOCK DISPLAY SHOWING):
1)Press and hold [skip reverse] [Time Slip] [Eject] buttons for about 10 sec
2)Display will show 'L1 TEST'
3)Now power off DURING TEST
4)Clock should be fashing 12:00
5)Turn power on and language menu will be displayed on TV
Use for
DMRE50
DMRE55
DMRE85
For the DMRE75V press both [dub] buttons and [eject].
Hope this helps.
Nov 20, 2007 | Panasonic DMR-E55 DVD Recorder
Open Questions:
Televison & Video Logo
318 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
