Whirlpool wf665/1 Does not go into spin cycle, will not pump water out
  • 1 more comment
  • Ingabish Sep 16, 2008
    my whirlpool wf665/1 keeps stopping mid washing cycle until i turn the dial around a couple of clicks then it starts again but last wash it didnt finish and i had to empty out the water myself. i've cleaned out what i think is the filter in the little opening on the bottom left at the front, but it didnt make any difference. can't find my manual
  • nutzzy911 Oct 23, 2008
    • i have the same problem with my mach en can anything be done to correct it
  • jzerby Jan 31, 2009
    Mine is doing the same thing. The lid switch seems to be working fine. (Open the door during fill cycle and the water stops.) If I advance the dial a notch or even wiggle it, it proceeds until the next time the before the water drains. Is the dial machanical or electronical? My dial sounds like an egg timer with a bad spring. Please help!
  • 975 Answers
DRAIN MOTOR PUMP might be clogged or stuck , if your handy , just open the washer and look at the bottom , theres a little motor with 2 hoses connected , take it out ( be ready with some rags and a pail ) clean it and remove any debri from the impellers , put it back and try again , hope this helps and please rate , thanks AJ
Posted on May 27, 2008
    Problem Solver:
Sounds like pump blocked,little flip down flap bottom left, pump behind there,take front off pump and clear. Mine had a sock in it would you believe!! hope this helps
Posted on Nov 02, 2010
  • Chummpy Nov 08, 2010
    oh my god!!!!!. My girlfriend has had the washer for around 6-7 years. I only moved in acouple of years ago.I always wondered where the filter is. But never having a front loader before I just thought it must work another way. It stopped during spining and draining cycle the other day. So I thought I would see of I could fix. Just read your post. You guys are awesome. Found so much stuff in there. Lots of money, several simcards and a huge bloody sock. The famous missing sock. Well that mystery is solved. Thankyou everyone.
4 Suggested Answers
beltronic205
  • 1474 Answers
SOURCE: Whirlpool WF665/1 clunking/grinding
Could be worn drum bearings.
Posted on Jun 04, 2010
  • 213 Answers
SOURCE: whirlpool washing machine won't spin after rinse cycle
there is a coupling between the motor and transmission that has cracked. with the crack in the coupling the transmission cant spin as fast as the motor causeing the loud noise. replace coupling to solve problem
Posted on Nov 21, 2007
  • 3 Answers
SOURCE: whirlpool super capacity Lsq9549lw0 has trouble spinning on its own.
If the washer does fine thru the agitation cycle (the washing), that means the motor is OK and the coupler is OK.  It would not agitate unless both are OK.  (and don't listen if anyone tells you the lid switch is bad -- machine would not fill & go thru wash cyle). The spin is another matter.  There is a separate tube for spinning the basket.  There is a drive  block at top of the tube (that sometimes fails)  and there is a separate cluch mechanism below, under the tub.  Those places is where you should look.
Posted on Jul 10, 2008
My whirlpool machine does not spin properly and there is always water left after the spin cycle, when its turned on it will stop after spin cycle like its finished but there is still a lot of water left in...
hi, it sounds like one of two possibilties, will try and help out. The first thing to check is whether the water/drain pump is actually working fine, i think it blocked. Secondly the pump may also be overheating and malfunctioning during the cyle, run it without clothes and check the flow of the drain during the drain/spin cycle and take it from there.
Jun 14, 2011 | Whirlpool Washing Machines
Washer stopped during spin cycle
Hello, try to checked the pump filter, and the pump is actually working. then I would suspect a draining problem.
If filter clean and pump works fine then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Thanks
Jun 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
The spin cycle is not spinning
Hello, if your spin cycle is not spinning all the water out, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely....if it's frozen or stiff,replace it
Thanks
Jun 04, 2010 | Whirlpool LSR5132PQ Top Load Washer
Trying to locate the belt on a Whirlpool washer
Hi:
Your washer does not have a belt. It has a transmission, and they seem not to fail very often. Usually, the problem lies with the timer or some other switch. What exactly happens when your spin cycle comes around? Normally, after the wash cycle, the machine stops, then the spin cycle starts in the opposite rotation. The first thing that happens is the water is pumped out, then as the speed increases, the spinning throws the rest of the water out of your clothes. If your machine does pump down the water, but doesn't spin fast, then you might have a transmission problem, but if it also fails to pump out the water, you could have a timer or switch problem, as some machines won't spin with the lid open, and if the switch is broken, the machine thinks the lid is open.
Feb 15, 2010 | Whirlpool Washing Machines
WASHING MACHINE SPIN CYCLES NOT WORKING
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
The following is a link to a diagram of washer parts, If you scroll down about half way down the page, you will see the pump:
washer water pump
Jan 09, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not drain after wash cycle or the spin cycle
check to see if your pump is slightly plugged with a sock or ?
Your top loader should pump out in about a minute and a half when totally full of water.
Aug 11, 2008 | Whirlpool GSC9455 Top Load Washer
Whirlpool washer ultimate care
check for problem with the pump it is coupled to the motor, if it is spinning then it should also be pumping out the water
Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
1,538 people viewed this question
Top Washing Machines Experts
