Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite he (5t)
Hi i was wondering if i was able to wash shoes in my new washer? would you happend to know?
  • 46 Answers
You can wash Shoes in it... But the manufacturer does not recomened it.. I would suggest that you remove the laces and you should be just fine
good luck
Posted on May 30, 2008
Kenmoor elite he 5t steam washer 47787 leaking from bottom. cant tell where leak is origanating from
Check your incoming fittings at the back of the machine-then if they aren't leaking your going to need to do a tear down and check inside machine-if you can't see anything going on you may need to hook water back up and run to see where the leak is-cheers Denny
Oct 26, 2013 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he 5t the code f21 comes on, the hose is ok.
This is a Long Drain Issue. Likely that something is stuck in the pump trap. Take off the mottom tree screws under the drum panel. This will remove the drum panel on the front. From under neither you can see the drain pipe trap. Unscrew the trap cap in the from. Clean out all debris and re-install. this should do it.
Feb 15, 2010 | Kenmore Elite HE5t Washer
My kenmore elite He 5t wash machine is flashing F
This typically indicates slow drain condition. Check for any clogs or kinks in the drain line. Also check that the pump is not clogged and that no pump impeller blades are missing/broken and that the impeller moves freely. Any broken/missing blades or if the impeller won't turn freely will indicate a faulty pump. Hard objects can sometimes make it to the pump and cause damage. Hope this helped and best wishes.
Sep 09, 2009 | Kenmore Elite HE5t Washer
Dying clothes
Dying usually needs the cloth to be submersed in the liquid so it can absorb the dye. These machines do not fill with water to the point the clothing would be submersed and would not work well in my opinion. eric
Jul 02, 2009 | Kenmore Elite 45986 Front Load Washer
Code F20 is appearing on me washing machine
http://www.fixya.com/support/r3608632-f20_error_code
May 27, 2009 | Kenmore HE2 Plus Front Load Washer
F 11 code
The electronic control board is damaged. It needs to be replaced. I think its Part#8182237. As of this date, it is on back-order. Check your warranty book on this part, it is highly expensive. It may be covered under a 2-5 yr. part only warranty.
Sep 03, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE 5t
Low or no water supply, hot or cold side or water pressure switch not switching over to indicate fully filled though if this happens drain motor will continue to run continuously while f-20 flashes
Jan 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
437 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
