Question about HP Vs17 17" LCD Flat Panel Monitor
When i was playing game sunddenly the computer is stuck and i plug of when i again turn on it says that no input signal what to do
    Sergeant:
    Champion:
  • 293 Answers
Ur pc have a problem not ur monitor
Posted on Oct 03, 2010
Searching for signal
DVI and HDMI are the exact same signal, except that DVI doesn't include the provision for audio. Essentially the problem you're having is that you have the monitor set to auto input rather than HDMI input or DVI input. Setting the monitor to not look for any input you plug in and defining the input should cause the hunting wait to be eliminated.
Nov 23, 2013 | ASUS VK222H Monitor
When i plug up the L1975NW lcd monitor what should show up ?
"no input" means that there is no signal from computer or the monitor cable is unplugged. When you first turn on monitor it usually does a self test and then looks for signal. Not connected to PC will give a no signal. If it is connected but PC is off (not unplugged) then it should go into standby as you vid card will be sending a standby signal to any monitor connected. Sometimes the Plug and Play monitors need to register before it will recognize a standby signal from PC, so plug it up and boot up PC. Then shutdown normally, your monitor should go into standby when the PC shuts down.
Nov 11, 2013 | Westinghouse L1975NW Monitor
I am trying to play my game. When I plug the when I plug the red,white ,yellow extention in the AV1 and go on input it does not work it says no signal and I dont understan why I would need signal to play a...
The input is not "seeing" the signal from your game---try another input and make sure connections are correct and the set is switched to the input you hooked up to(they are labeled on the back)
Nov 07, 2012 | LG 60pk200 60 1080p Plasma Tv 60pk200
To reduce background noise from an audio mixer
when you say background noise I assume you mean the inherant noise that electronics produce. the the first thing to do is to make sure that all you input connections are shielded type, you don't need to spend money on gold plated connections, but do buy cables that are made with stranded wire and of decent size, bigger (fatter) is better when it comes to minimizing high frequency losses. Next, calibrate your inputs one at a time with a 1000hz signal that is 0db inn level. You can find this signal online through a search. you can also buy small plug in devices that produce this signal at 0 db (that is Zero Decibles) this is a common reference for "consumer" grade mixers, If you can't or don't want to spend any money on this you can use a signal from any tone generator, and some mixers have them built it. If you don't have any of the former, here is what you can do. turn all you mixer controls to 0 (zero) detent. in other words, flat, no treble, no bass, no midrange. on your inputs there should be input level knobs, these woule be set to thier lowest positionn if using a line input signal. if a microphone that level would be different, but wait on that for a bit. now have all you input knobs (or sliders) at minimum level. Now turn on your amplifer (if your using one) or what ever you monitor the output with. Headphones is a good choice as you can hear everything.
You should hear nothing. (nothing is supposed to in the inputs yet) if you hear noise take note of what it sounds like. turn the sound output level out (if headphones, turn up to a high level) and listen again. is the noise white (hiss) or hum (low freqency) if you have no noise, you have a good mixer and that is what it should be.
No plug in your first input, this is your choice but I would suggest you plug in microphone, now turn it up to the point where you can hear your own voice, you should hear just that, and maybe anything in the backgroud (furnace, tv, etc_) the quieter your environment, the better you can adjust this. Remember you will now need to turn up the input level. If you have meters you should be able to adjust the input to register in the green without turning red, a litlle yellow once in awhle is ok.
If this is quiet and clean you are ready to move on. turn that mic down to zero, but leave the input where you set it.
now plug in a line level source (your tape player,/cd player/ but don't use your computer as a source (yet). without anything playing on your machines you should hear very little noise in your headphones, if you hear a lot of noise you have bad cables.
Now play something through the tape/cd player, what ever and turn up the slider (not the input) this should give you a level,again in the green, with a little yellow, NO RED
once finished with this turn it back down and go to the next input. this time plug in your computer which most likely is coming from the green jack on the back (or front) of your PC/Mac or whatever. computers are very noisy machines, and just being close to one is sometimes enough to cause noise in a high gain system. anyway, plug in your computer and listen, you should hear some noise and I'd be surprized if this wasn't the source of your problem. make sure your volume level on the output of your pc is set to maximum, this will give you an advantage when recording. now turn up the slider on this input and listen for the noise level. good cables are important here and also the price of your computer may be reflected here as well since more expensive machines are better filtered and therefor produce less noise.
play a sound file (windows audio samples are noiseless and clearn) so use them if you can find thiem, look in your music folder for the sample files
You may hear some noise but your mixer is now set up at optimum and should give you nice sound if it is a quality mixer, good luck, Keith
Mar 24, 2011 | Audio Players & Recorders
I have a Panasonic SA-PM31 stereo system with two auxiliary input methods: the first appears to be a common auxiliary cable input which says "phones." The second is a two cable input system...
The corect input for your ipod is another one who's name is "auxiliary" The "phones" input is dedicate only for pick-up, or another device who had to output a very small level signal. Your ipod have a high power level on output because he is amplified for a good level sound on your earphones. So, you can serious damage your Panasonic SA-PM31 sound system when input a too high level signal on "phones input" Phones is for unamplified audio signals like pickup signal direct from the head wires, or casette deck signal direct from the head wires. Gross (unprocessed) signal.
Dec 12, 2010 | Audio Players & Recorders
Weirdness
are you talking about game saves or games?
try this if its games
connect it up to your computer and check if they are in the psp\game folder
if there gone there is nothing you can do about it
if your running cfw u can just download them again
Jun 06, 2009 | Sony PlayStation Portable (PSP) Slim...
LG 37in HD LCD tv not responding to any pressed buttons.
Based on your description, it appears that you have main board issues with your unit since your controls do not work and some inputs are NG.
Apr 24, 2017 | LG 37LP1D 37 in. LCD Television
TV wont read any of my game consoles input signal
i had tht EXACT same tv in white and i used to play game systems on it. eventually i got bad joo joo and it stopped working :/
May 15, 2008 | Toshiba 36A50 36" TV
HP Vs17 17" LCD Flat Panel Monitor Logo
24 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
