Question about Kodak EasyShare V610 Digital Camera
Displaying error front flap not closing over camera lens
  • 43,501 Answers
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101;'
Posted on May 17, 2011
Everytime I turn on my Nikon Coolpix camera it says lens error and I do not know why.
something is blocking the lens to get out ..and the camera can not start ..and it displays the error and close...try to see if something or maybe just the usage under poor conditions like rain or sand ..caused the lens not to open proper..sometimes weak batteries can not action-ate the lens gear ..and the error is on also ...
Aug 02, 2010 | Cameras
F--error even though I cleaned connections with lens and camera
Hi mmarushack, in the manual page 132 it states that the F- - error means the lens is not attached or a non CPU lens is attached. If a older non CPU lens is attached select M mode. That would be on the right side of the lens mount as you face the front of the camera. The assumption is you have a CPU lens then I would suggest doing a reset of the camera. Open the terminal rubber flap on the left side of the camera. Just below the USB connector is a small push button. That resets the camera thus fixes you camera. If not do call Nikon at 800-645-6689
May 28, 2010 | Nikon D80 Digital Camera with 18-135mm...
Cannon powershot SD1100 IS it displays the
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Nov 24, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Canon A540 E18 error
You don't want to take it apart. Wayyyyyy too many parts and steps. I bought a used one with the same problem, lens was stuck half open and out of alignment, it was dropped. I got it working well in about an hour.
I tried all the described tricks, plus a few others.
#1 get a strong canister vac or shop vac, and put the end of the hose right over the front of the camera and turn it on for a few seconds, and turn it lens side down. This will remove any grit in the gears and may pull the lens itself all the way out.
#2 if the lens is still stuck try rotating the outer collar gently both ways until you hear it click into place. If it does, look at the alignment of the inner barrel to the case. the lens will never fully retract if it is out of alignment, if it is you will have to force it back onto the gears it should be on.
If it was dropped resign yourself to the fact you must at some point nearly break those plastic gears inside to get them back where they need to be, and there's a fine line between forcing and breaking it.
Just remember you'll have to get the lens closed and aligned before it will work, closing it is a proces of both rotating the outer collar and gently wiggling the inner sleeve closed. Before it will close it has to be straight. Once it its closed put a fresh set of batteries in.
This whole E18 issue is not as complex as people might think, you just have to be reeeeal gentle with that lens assembly when it's extended.
Oct 03, 2009 | Canon PowerShot A540 Digital Camera
My coolpix displays lens error when it is turned on. The lens opens and closes twice before the display reads lens error.
his generally happens if you have dropped it. when the message comes. try tapping the camera. if it works then you are lucky. if not then you have to change the lens array. it costs about 60$
Jul 15, 2009 | Nikon Cameras
Lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 18, 2008 | Casio Exilim EX-Z750 Digital Camera
Camera lens
Does the camera take pictures?
If you take the camera near a lamp, can you just about see menu items on the LCD?
If so, it's possible that the backlight ribbon cable slipped out of the socket. To check open up the back of the case and carefully lift it up a bit just to see the ribbon cables. The narrow one is used for backlight. Try to disconnect it (open the tiny black flap in the connector) and connect it again (close the black flap). Have a quick look at the connectors on the ribbon cable and make sure they are clean. If it still doesn't work I'm afraid most probably you have a faulty backlight and will need to replace either the whole LCD (easy) or just the backlight (fairly fiddly job). In any case, you'll probably need a donor camera (ebay ;) to scavenge for replacement LCD.
Good luck,
Raf
Jun 17, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens error
your lens are stuck! did you drop the camera? you need to get a repair on the lens
Jan 10, 2008 | Nikon COOLPIX L3 Digital Camera
Kodak EasyShare V610 Digital Camera Logo
55 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
