Question about KDS Radius RAD-5 15 in. Flat Panel LCD Monitor
Monitor problems with kds
When i turn on my pc my monitor image flicks on and then off
  • 3 more comments
  • ranunga Jun 22, 2008
    dge
  • alastair472 Jul 25, 2008
    I have the same problem with mine, I took it apart today to check the switch but couldn't find anything noticeably wrong
  • revjjw Aug 30, 2008
    When I first turn it on, I can see what is on the screen, then it goes black.
    KDS FLAT SCREEN MODEL #568
  • rpheagin Sep 03, 2008
    if i turn off the power to my monitor and later come back and turn on the monitor, the screen comes on for about 3 seconds then goes blank. i then have to keep turn it off then back on sometimes as much as 30 minutes and it will then stay on off/on
  • Gina48 Nov 15, 2008
    This monitor will not display anything but a light gray screen after it is turned off. It's a fight to reboot and pull plugs out and finally, usually after a 2nd or 3rd reboot the monitor will have a display. I hate to keep my computer on all the time.
  • 3 Answers
The monitor is either overheating, or (more likely I think) the overheat sensor is sending a false overheat signal.
I've heard it can be bypassed by either clipping the sensor or clipping and then shorting the leads. I can't confirm that and I don't know what the sensor looks like or what it is.
Sorry I couldn't be more helpful.
NV
Posted on Sep 22, 2008
When I turn it on , it flicks on and then off. Since there is no image, I turn off and then on again which results in the same: it flick an image on and then it turns it off.
Posted on Jun 22, 2008
Kds k917s monitor won't turn on green power light flashes on when plugged in
check the vga cable which get loose connection then the signal from pc not recognized.
Dec 25, 2012 | NEC MultiSync Computers & Internet
Xtreme Flat KDS 19" monitor got a burned smell,
This monitor should be trashed, CRT monitors are not worth repairing. LCD monitors a cheap and energy efficient.
Jul 19, 2011 | KDS Xtreme Flat 9e 19 in.CRT Conventional...
HPvs17x power flicker on/off no image, 3-10min after image ok!
More likely to have failing power supply problem due to bad caps, look for caps with bulging top first and post back what you see inside, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 02, 2010 | Computers & Internet
I have a older kds lcd monitor that goes black less than 1 min after turning on, the power light stays on, the monitor will come back on if you repower the monitor then goes back off in 3 or 4 seconds. Is...
if you look closely can you see a very dark image on the screen? your problem is usually the result of the backlight on its way out, these are very hard to replace so you will need to take it to a profesional, in most cases it is cheeper to buy a new screen.
Jul 02, 2009 | KDS Computers & Internet
Monitor
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 25, 2009 | Gateway MX3215 Notebook
Kds model 780 monitor no signal, power button does not work
My monitor does the same thing at times and sometimes shows "No Signal" and at other times the screen will maintain the images but the backgound color switches to mustard yellow. In each of these cases I have been able to solve the problem by unplugging the power cord from the electical outlet for about three seconds and plugging it back in. I have a KDS model 780 LCD.
GOOD LUCK
Dec 15, 2008 | KDS Radius RAD-5 15 in. Flat Panel LCD...
Kds just two seconds
I have the sameproblem soI plugged in a HP 1702 after 2 days it started doing the same thing. I am using an old school kds with no problems.
Could it be a bug in the system with flat screens.
Jul 28, 2008 | KDS K717s 17" LCD Monitor
KDS FLAT MONITOR
best I can tell, the Rad 5S is out of warranty, and you appear to be having a problem with the image inverter.
#1 Try the monitor on another system and ensure that the issue is the monitor, and not the video card it is attached to as the point of failure.
#2 If the monitor appears to be failing, contact a local TV repair shop on a repair estimate. Likely answer is that you can buy a larger better monitor cheaper than you can get the one you have repaired, even if the parts cost is low, due to the bench fee/labot cost of repairs.
Here is one site I like for monitors:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010190020+4017&name=%24100+-+%24200
Jul 24, 2008 | Computers & Internet
KDS Radius RAD-5 15 in. Flat Panel LCD Monitor Logo
288 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
