Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Pss 26MSWA ice maker does not work
Removed filter because of panel alert. installed plug. now no ice is being made. we were on vacation for 1 month and upon return ice in bin was frozen together. I removed all the ice and reinstalled the bin.
there is some condensation in the freezer so I lowered the temp to -2 / 36. Nothing is blocking the peeler arm. HELP.
Thanks
After lowering freezer temp to -2. works fine now, must have needed time to cool down enough.
Posted on May 27, 2008
The ice maker is not working and the water dispenser is not working right. I've changed the filter,checked the water supply and reset ice maker and waited 24 hours. What's next?
First make sure you have water going to refrigerator Samsung water filter heads go bad and won't let water thru or it could be the fill valve it's right near the filter
May 30, 2016 | Samsung RF4287HARS French Door...
Icemaker will not restart
1 Lower the bail wire to turn on the ice maker, and remove the ice bin. Then, using a screwdriver if necessary, remove the ice maker, clean it thoroughly, and then reinstall it.
2If the problem persists,consider removing and replace the entire ice maker and valve. With this type of problem, you can have it repaired, but it's often wiser and less expensive in the long run to replace the unit entirely.
Apr 10, 2015 | Refrigerators
Why is icemaker not working
Good Morning Friend,
I understand the ice maker is not working in your Frigidaire refrigerator, model# FPHG2399PF. Please follow these steps to resolution:
    1)Make sure the ice maker power switch is on. This button is located on the ice maker itself.
    2)Make sure there is not a small cube caught in the ice maker itself. If there is, carefully remove it.
    3)Check your water filter. Water filters should be changed roughly every 6-8 months. Also make sure your water filter is seated correctly. Try taking out the filter and re-installing it. Listen for 2 clicks and make sure it is flush with the water filter housing.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 21, 2014 | Frigidaire FPHG2399PF Professional 23 Cu....
Changed water filter and bushed lock & water buttons, red light went off but green light and other indicator lights (crushed ice, cubes, night light) did not work. Removed new filter & put . .back...
Below are instructions to reset water filter light. Thanks, Sea Breeze
If helpful please rate.
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
Apr 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker has stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
689sshg
May 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
heatman101
sfhgsyw54
Mar 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Jenn Air, french door style, bottom freezer. with the water dispenser on the inside left jamb of the box. there is also a ice maker. for the first 9 months every thing worked very well. then...
You have another plugged filter. That is why you ice cubes are hollow, the water is flowing so slowly into the ice maker, it does not fill up.
Recommend you install an external filter somewhere in the feeder line that connects to the rear of the refrigerator. The are surprisingly inexpensive, compared to the filter inside the new 'fridges. I recommend you buy a replacement external filter cartridge at the same time you buy the external filter kit. Of course you will need to change the internal filter one more time or bypass it per any instructions provided with your fridge.
Aug 11, 2009 | Refrigerators
Ice maker doesn't work
Unplug Ice maker from plug on inside wall, remove and let thaw. Don't worry when removed the water will not enter the freezer. Let me know if this works as I get very little support from LG. Thanks, Se Breeze
Jul 30, 2009 | LG LRFD25850 French Door Refrigerator
Icemaker stuck in 'vacation mode'
Feel inside the ice slots are there any old cubes that have evaporated in time? Take the ice maker out and clean it up and place it back inside to see if it will fill with fresh water. Take a hair dryer and melt the old ice inside the slots and see if it will try to fill. I will wait for a response from you.
KSCS25INWH00 Kitchenaid Parts
APPLIANCE 911
KitchenAid Refrigerator Ice Maker Assembly 2198597
May 06, 2009 | KitchenAid Superba Architect KSCS25IN Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
97 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
