My hp pavilion dv6000 isnt going past the boot up screen. I put a recovery disc in and it just restarts the computer? tell me this is a hard drive problem please, id hate for it to be the mother board
  • 7,733 Answers
Fine a solution ---.HERE.
Post back!
Posted on Oct 03, 2010
Where is the reset button
If you mean how do you return to factory condition, press F11 just before it boots and follow the prompts.
Recovering your computer without recovery discs
Creating recovery discs (or USB storage device solution)
Ordering recovery discs from HP in the United States and Canada
Finding recovery discs from other Web sites
Contacting Support
HP recovery discs can be used to return a computer's software configuration to its original condition. HP provides a recovery solution on the hard drive, but it is still a good idea to keep recovery discs stored in a safe place in the event of a hard drive failure. Use the sections in this document to obtain a recovery solution that works best for you.
NOTE:HP computers designed for commercial use, such as Workstations or Pro series, use "Operating System" or "HP Restore Plus" DVDs. To order these types of discs, go to the HP Replacement Part Store . Recovering your computer without recovery discs You may not need recovery discs to recover the software on your computer. HP provides a recovery solution on a separate area of the hard drive. If the hard drive is still functional, you can still perform an HP system recovery from the hard drive as long as the recovery information has not been destroyed or corrupted.
To do a software recovery from the hard drive, turn on the computer and repeatedly press the F11 key until "Windows is loading files..." displays on the screen. If your computer originally came with Windows XP or earlier, press F10 to enter recovery instead of F11.
  • graphic.php?im=im_e58rok73o1nlhbzFeedback
  • Dec 21, 2013 | HP Pavilion dv6000z Notebook
    Bootmgr missing on hp pavilion slimline s5503w
    This document pertains to HP and Compaq desktop PCs that came with Windows 7.The following error opens when attempting to start the PC:BOOTMGR is missingPress CTRL+ALT+DEL to restart the PCIf you recently installed an additional hard drive, turn off the computer and remove the drive before using the following steps:
    1. Open HP System Recovery:caution.pngCAUTION:Do not perform a system recovery! Stop at the first recovery screen.
      • Press the F11 key repeatedly while the computer is starting.
      • If you have a recovery disc, turn on the PC and insert the first recovery disc into the drive. Use the disc to enter the system recovery.
    2. Select Microsoft Startup Repair tool and wait for repair to find and fix errors. When finished, restart the computer; even if the startup repair tool finds errors but cannot fix them.
    3. If the error message persists, open the recovery manager screen as was done in step 1.
    4. At the recovery manager screen, press ALT + D.
    5. Enter the following text at the command prompt: bootrec /rebuildbcd
    6. If bootrec displays "Add installation to boot list?", press y .After bootrec completes successfully, the computer displays "The operation completed successfully".
    7. To close the command prompt, enter the following text: exit
    8. At the Recovery Manager screen, select Microsoft Startup Repair tool (again) and wait for startup repair to find and fix errors. When finished, restart the computer.
    9. The error should no longer open. If it does, perform a system recovery, making sure to backup important files.
    If you removed a hard drive before using these steps, replace the drive. If the error occurs again, make sure the additional hard drive is not set as an active drive. Only the main bootable drive should be set as active.
    Feb 10, 2012 | HEWLETT-PACKARD Pavilion Slimline s5503w...
    When i am start my hp pavilion this shows Bootmgr is missing alt+cntr+del to restart again it same cycle
    1. Error: BOOTMGR is missing:
    ??¢ If you recently installed an additional hard drive, turn off the computer and remove the drive before using the following steps:
    ??¢ Open HP System Recovery:
    ??¢ CAUTION: Do not perform a system recovery! Stop at the first recovery screen.
    - Press the F11 key repeatedly while the computer is starting.
    - If you have a recovery disc, turn on the PC and insert the first recovery disc into the drive. Use the disc to enter the system recovery.
    ??¢ Select Microsoft Startup Repair tool and wait for repair to find and fix errors. When finished, restart the computer; even if the startup repair tool finds errors but cannot fix them.
    ??¢ If the error message persists, open the recovery manager screen as was done in step 1.
    ??¢ At the recovery manager screen, press ALT + D.
    ??¢ Enter the following text at the command prompt: bootrec /rebuildbcd
    ??¢ If bootrec displays "Add installation to boot list?", press y .
    ??¢ After bootrec completes successfully, the computer displays "The operation completed successfully".
    ??¢ To close the command prompt, enter the following text: exit
    ??¢ At the Recovery Manager screen, select Microsoft Startup Repair tool (again) and wait for startup repair to find and fix errors. When finished, restart the computer.
    ??¢ The error should no longer open. If it does, perform a system recovery, making sure to backup important files.
    ??¢ If you removed a hard drive before using these steps, replace the drive. If the error occurs again, make sure the additional hard drive is not set as an active drive. Only the main bootable drive should be set as active.
    Dec 12, 2010 | HP Pavilion Ze4900 Notebook
    Can you factory reset hp pavilion dv6000 laptop without disc
    yes if u have a backup in ur harddrive. usually a drive partition with system restore comes with a brand new system.
    Dec 06, 2010 | HP Pavilion dv6000z Notebook
    The problem of my hp pavilion dv5 is this, i want my laptop to be back on its original state so i tried system restore. i have my recovery discs aside from the built-in recovery partition. i inserted the...
    You have formatted the hard drive (containing Boot Manager) using recovery disk 1.
    That's why the error message.
    Just insert disk 1 again.
    Shut down the computer (press & hold the power button for a minute).
    Restart.
    Follow the instructions that come up.
    If it doesn't help, reseat the hard drive. (open the back cover, take out hard drive, reconnect it)
    Also you may go to BIOS (tap F1 while booting) and set the cd-drive as the first boot device.
    Hope it helps.
    Nov 06, 2010 | HP Pavilion dv5-1000us Notebook PC
    Need a recovery disc for Pavilion dv-5 notebook
    Hi:
    You most likely have a bad hard drive, and a disk set is not going to help you, though you will need it too.
    What you need is a new hard drive, a copy of all the drivers for your laptop, which you can download for free from HP. If HP won't send you a copy of the recovery disk, you can use any OEM copy of the same operating system that your laptop has a sticker for, but you won't have all of your programs.
    Nov 23, 2009 | HP Pavilion dv5-1140us Notebook PC
    Error : 0x400110020000100A
    Look carefully at the hard drive that you are replacing. When you take it out of the [mine is a Compaq f750us] computer you might see, for want of a better term, a "STRETCHER" attached to the contacts/connectors, remove it. Put it on the NEW hard drive, put hard drive into computer. Try it again. I did and I did NOT get the "error" code! Why because the HD is now CONNECTED...touches the contacts..
    Jul 22, 2009 | HP Pavilion DV6700T Notebook
    Reformated used HP recovery disc when I restart it says SW build ID different from ID on recovery media
    You have 2 options. You can write to Microsoft or to HP about your Issue & they might be able to help about the ID issue. Best I would suggest you buy the OS. ( Full installation Pack) this way you have nothing to worry.
    May 11, 2009 | HP Pavilion a1610n PC Desktop
    I have hp pavilion dv6000 i had a problem about recovery manager
    Did you attempt to load recovery/factory image from hidden partition and if so did you follow User Manual or Guide re instruvtions? if so there should have been no problems. I would try again though do it slowly and carefully when choosing Options so that you don't change Partitions where the Default Software is.
    Was it Alt and F10 buttons when powering up from a Shutdown, i.e Cold Boot?
    Apr 09, 2009 | HP Pavilion dv2000t Notebook
    Computers & Internet Logo
    43 people viewed this question
    David Payne
    David Payne
