Question about RTO PasLode 900420 Impulse Framing Nailer
Paslode gun will not engage the fan when tip depressed
  • 2,176 Answers
If this is the framer, could be quite a few things. first do you have nails in the magazine, the safety might be bent not allowing full travel, the spark unit might be faulty. If you are comfortable with some partial disassembly, let me know and I will go into further detail for you on troubleshooting, you will need an allen wrench the size of the cap head screws. Let me know
Posted on Oct 03, 2010
Fan comes on new gas cartigage.gun will not fire
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problemsheatman101
Mar 04, 2011 | RTO PasLode 900420 Impulse Framing Nailer
My gun wont fire. When I p, , but wonthe fan comes onss on the lumber to firet fire. John
heatman101
Jan 19, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Hi .my im350 nail gun isnt working gas and battery ok and gun is cleaned.light on green .but when depresssed makes strange noise and lights on fire from fan end?
heatman101
Oct 24, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode framer when you depress trigger there no resistance and it does not fire
Paslode framer has a lever inside of trigger that may be bent or missing. Easy to check. Remove air line and nails. Remove trigger by pulling pin. Check under trigger for missing parts. Test gun by connecting to air and place nose of gun against wood or hard rubber and then depress firing pin. If gun fires then problem is with lever under trigger or safety mechanism which is in two parts. Check safety for bent or broken piece, usually upper part will be missing lip that actually pushes on the lever. If however gun does not fire when firing pin is depressed, time for replacing orings in gun. Parts are available at www.toolpartsdirect.com . Good luck with your repair and post again if you have other questions.
Jun 30, 2010 | NRS Paslode 501000 Powermaster Plus...
Paslode Impulse Framing Nailer won't operate
heatman101
May 10, 2010 | Omega Paslode 901000 Impulse Cordless...
My Impulse Framing Nailer fan doesn't go on when i press down on the gun
heatman101
l;';[]
Apr 11, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode battery wont hold charge.brought new battery, same thing.brought new charger, same thing. put battery in gun, fan runs and then the battery is flat again.
if you have bought a new battery and charger , and it still will not hold a charge. you might have bought a bad battery or charger , also the fan dosent allways run so the fan going off is not a sign of a dead battery. depress the trigger or safety and the fan should start up again
Feb 14, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail gun 325 black not firing
Any time these guns become intermittent or stop firing but the fan still runs, the first the to check is the expiration date on the gas cartridges. The do expire and this will make the gun work inconsistently or not at all.
Dec 08, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode framing nailer loss of power.
Here's what I found at the Paslode Troubleshooting Site:
Tool will not cycle - fan runs, indicator light
is solid green.
Lockout bracket is stuck in lockout position.
Work-contacting element is bent, or build-up of
debris in track restricts operation.
Follower is not behind fasteners.
Fuel Cell empty.
Spark wire out of spark plug.
Spark plug is dirty.
No spark is generated.
Check lockout.
Remove and inspect lower probe. Clean and
lubricate track with Paslode Impulse® oil.
Repair or replace lower probe as required.
Position follower behind fasteners.
Replace fuel cell.
Remove cap and check spark lead, insert in
spark plug and replace cover.
Clean tool cylinder head and spark plug.
If this doesn't work, I suggest contacting Paslode directly 800-222-6990
Mar 11, 2009 | RTO PasLode 900420 Impulse Framing Nailer
RTO PasLode 900420 Impulse Framing Nailer  Logo
155 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
