Central air stops blowing cold after about 4 hours. The air blows at 63 degrees when it's cold.
    Problem Solver:
  • 12 Answers
Sounds like your evaporator coil is freezing up. This is a sign that you have a restricted air flow over the evaporator or you're low on freon. The 63 degree tempurature is indicitive of low freon. You should call in an a/c expert to check the freon level and while he's there have him clean the evaporator coil.
Posted on Oct 04, 2010
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital...
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital temperature on the climate control is not correct. When it states that it is below 30 degrees on the ext and it is warm outside the air wont be cold. Once it starts going above 30 degrees the air gets colder. Today the blower stop working all together. Was told it maybe the climate control unit was bad. You can hear the door opening/shutting when you switch the temp from cold to hot. But there was no heat blowing out whatsoever in the winter time. Could you please give me your opinion on whether or not it is the climate control unit or something else?
Jul 11, 2011 | 2000 Pontiac Grand Prix
I have a Ruud A/C. For 4-6 hours my air conditioner blows cold air, then it it starts to blow hot air after that. Happens like this every day. What can it be
Check the indoor coil to see if it is icing up, if so clean the evap. coil filter ect. you have to have good air flow or it will freeze up. Setting the stat. to low below 72 degrees will do it as well, because your coil would be below 32 degrees. If that worked clean your condenser coil too. take a hose to it a solid stream and hose it clean, be thorough get very inch.
Jul 05, 2011 | Heating & Cooling
Unless we set the thermostat very high, like 80 degrees, the heater will blow cold air. When the heat does blow, it will eventually stop blowing heat and the fan will continue to blow cold air.
Check and make sure the filter is clean. This sounds like a restriction in the system. If the unit has central cooling make sure ther indoor evaporator coil is clean at the furance.The unit may be cycling the burners on and off at the high heat limit , fan/limit control. You can also eliminate the thermostst from the furance. Turn power off at the furnace and disconnect the wiring from the thermostat. Jumper the red and white wire together. Turn the furnace back on. The furance should run in the heating mode. Try this and see if the problem is still there.
Jan 25, 2011 | Heating & Cooling
Air Conditioner stops blowing cold air when vehicle is not moving
plus one on the cooling fan problem. if it was low on charge then as you slow down, condensor temps and line prressures would raise therefore it would cool at low speed and and not when moving since the incoming air would drop system temp,reducing line pressure and then cusing compressor to cycle. the auxillary cooling fans must be on whenever a/c is on, if not, thats your problem. get this taken care of because if you get stuck in traffic, your engine will overheat also if fans are not running
Sep 02, 2009 | 2007 Ford Five Hundred Limited Sedan
2003 Saturn L200 - Suddenly stopped blowing cold air
If it happened all of a sudden, check the fan belt, and the A/C fuse. These are the most likely culprits. If the fuse is blown, the clutch on the A/C compressor may have gone bad, and should be looked at.
Jul 28, 2009 | 2003 Saturn L-Series
A/c stops blowing cool air after 90 minutes to 2 hours driving
sounds like it has a slow leak in it i would put dye in it and drive with it on for about 3 days and take a light see if u see dye comeing out anywhere
Jul 19, 2009 | 2004 Dodge Intrepid
Heater blows cold air from top vents after running for 1.3 hours
Sounds like you may be able to fix it by flushing your antifreeze and back flushing the heater core. Some car owners cheep out and put stop leak into the antifreeze, others dont change there antifreeze at all. Both are mistakes.
Mar 05, 2009 | 1990 Chevrolet Lumina
Central heating HVAC blows cold air -
is there a light or source of heat near t stat or low battery in tstat
Jan 04, 2009 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
