Power on but no response at all after pc software disc install fail few times
    Master:
  • 397 Answers
This sounds like your system has issues other than trying to install an operating system. I would recommend looking into replacing both your RAM and your hard-drive since those are the likely culprits for both the installation failing, and your system locking up.
Posted on Oct 03, 2010
Bios black screen
Did You Check to See If Memory is in correctly ?you might have dislodged them by accident please check this !! Can you get back into bios there must be a reason for the black screen like Memory is the computer beeping ? What you can do is use a friends laptop or computer and create a recovery disc on there computer then put that disc into your laptop or you can borrow there windows disc.
Boot Manager:
Windows failed to start. A recent hardware of software change might be the cause. To fix the problem:
1.Insert your Windows installation disc and restart the computer.
2.Choose your language settings, and then click "Next".
3.Click "Repair your computer."
If you do not have this disc, contact your system administrator or computer manufacturer for assistance.
Status: 0xc000000f
Info: The boot selection failed because a required device is inaccessible.
(more Info Please)
Sep 18, 2017 | Toshiba Satellite Computers & Internet
Acer Aspire 5750 Error please help
Probably damaged the motherboard. Maybe time for a new laptop.
Mar 10, 2017 | Acer Aspire Computers & Internet
Compaq presario CQ57 windows failed to start
Double check that there is power (no joke). Press power button and if you get a response tap F8 many times. If you get a screen then select "Last known good configuration". If you get nothing then it may be time for a shop visit.
Jan 12, 2013 | Compaq Computers & Internet
Hpg72 ,I remove battery after computer no power on
Possible that PC is hanging up as there is fault on the OS (operating system) or a virus in the OS. Also it is possible that the backup battery (CMOS) has low voltage or the memory card is a suspect. In this case you need to check the voltage and also try and swap a memory card. Sometimes the memory card connections can be faulty either on the card or on the slot. Cleaning the slot and card must be done before you try a replacement. If the PC boots and fails then the hard disc can have bad sectors or is corrupt. However if there is no result the motherboard also can be suspected. In this case you might need the help of proper tools and equipment support to do a chip level service.
It is best to go for a paid antivirus software which you can get in a package. Personally we are not recommending any particular company but you can try with Avira, Antivir, AVG, Kaspersky. It is always best to install the antivirus when the installation of the OS is done.
Now before this you can open the internet options in the browser and clean all the cookies, temporary internet files, defragment the drives and RESTORE the PC to an earlier set date.
You can use a registry cleaner like Advanced system care. Download from the site and check you system for corrupt files. Also use a good antivirus software which is active to keep your system performing without an attack on the OS. Remove all unnecessary programs installed which you do not use all the time and clean up the drives. This will free up the space and make your system faster.
If there is no response but the PC tends to work slower and occasionally hanging when a program is being executed then you might have to install the OS once again. Install the OS and then an antivirus before the drivers of the PC is installed.
Mar 12, 2012 | Computers & Internet
When i click on webcam i face an error "web cam is either disabled or has failed. please check your web settings." i dont understand what i have to do at this time......even i have install the...
Please restore your PC to an earlier software installed date. This will reset the drivers once again on the PC. If not the recovery disc must be used to reset.
Feb 04, 2011 | Computers & Internet
Laptop gives no response after reboot/restart
how old is the laptop
if it has a disc hard drive it could be that the motor in the hard drive is failing
go into device manager and do a systems check
Apr 03, 2017 | Toshiba Computers & Internet
HP printer F4180 series doesnt print - transferred from older xp pc to newer vista pc using installation disc
may be the driver disk which yo using that if for xp if you have vista cd install it.
Don’t connect the printer usb cable first
1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 24, 2010 | HP DeskJet F4180 Inkjet Color All-In-One...
Windows boot manager
Hit F8 a few times while your computer starts to boot, a boot selection screen should come up. Try selecting "Last Known Good Configuration" and see if you can boot up without running the repair install.
Sep 02, 2009 | Toshiba Satellite P205-S6287 Notebook PC
UN-Install Nero Burning rom 5.5 FREE Version (now out of date)
If you are running XP or Vista, I would run a system restore. Go into start all programs, accessories, system tools, system restore and choose a date prior to the day you installed nero.
Armymason
Mar 02, 2009 | Ahead Software Nero 5.5 (NERO5.5) for PC
Factory default disc on acer 4520G
If you have Nero of Power ISO installed you can right click the .iso file and there should be a command in the shortcut menu that states "burn with Nero" or burn iso with Power ISO, etc. this should apply to other disc burning software you have installed.
As you may know, .iso files are a compressed disc image file that contains the data layout for a complete CD or DVD. Most of the time, burning an iso image from first opening your disc burning software is more difficult but can be done by hunting through your software's menu commands.
Hope this has fixed ya!
Worldvet
May 16, 2008 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
