Question about Dell Dimension 2400 PC Desktop
Monitor is flickering,how to resolve it? - Dell Dimension 2400 PC Desktop
  • Dell Master
  • 32,281 Answers
If this monitor is a LCD type then -
The problem is a back light fault and is caused by either a faulty inverter board or a faulty CCFL lamp.
You can source parts from the Internet. Try these WEB sites :-
www.lcdparts.net
http://www.nylaptopparts.com/
http://www.ccflwarehouse.com/
Posted on Oct 03, 2010
  • Joel Far
    Joel Far Mar 19, 2014
    Try to resolder near the Ccfl inverter area sometimes the problem is cold solder itself. If you know to use to solder and you have the right tool and a knowledge on electronics
MY LITEON MONITOR IS FLICKERING, IT HURTS MY EYES, ALTHOU ITS HARD TO NOTICE, BUT ON WHITE BACKGROUND ITS VERY NOTICABLE
To Resolve this issue...
Right click the mouse on desktop, Go to Properties. Select the "settings" tab and go to "Advanced" button. Here select the "Monitor" tab and change the "Screen refresh Rate" to the next Hertz.
Problem wilbe resolved now!
Dec 10, 2010 | Lite On Computers & Internet
Whenever i turned on my system, my monitor flickers, what do i do to resolve this problem pls?
try to change the cables or try to use another monitor so hat we can diagnose the issue to find whether its with monitor or the computer..then e can proceed accordingly
Sep 30, 2010 | Computers & Internet
I have a sony vaio vgn cs36gj and on the start bar there is a line right across the bottom that flickers every five seconds. I have my screen adjusted to the correct resolution. I have also plugged in an...
90% chances are that this is the problem with your Graphic settings.(go to your Graphic Properties and make sure that Refresh Rate should not be more then 60Hz). Change it to 60hz and restart your machine, This should resolve.
**Please post your feedback and Vote if the problem resolved as per your satisfaction**
Sep 28, 2010 | Sony VAIO VGN-CS260J/P Laptop
Monitor flickers on and off
power supply is more than likely going to need some new capictors. if you can solder its not a hard fix. just look at the power supply and look for swollen caps.
Jul 06, 2010 | ViewSonic VX2235WM Monitor
Monitor on/off button flickers
Hi!
The reason why the button of your monitor flickers is because the 12 volts output supply for your inverter board is not stable..
If you have the skills and the right tools for this, Here's what you need to do
1. If your monitor comes with a power supply adapter, open it..check and replace blown capacitor with same value..
2. If your monitor is using a cable power cord..open the back cover of your lcd..on the power supply section.. check and replace blown capacitor.
3. Check and resolder the terminals for fixing possible loose connections.
4. On the inverter board section...check and resolder the terminals for fixing possible loose connections, the high voltage inverter usually loose connections when overheat.
5. Other things to check if step 1 to 4 did not resolve your problem. Check and replace burnt high voltage transformer.. Check and replace busted backlight inverter..
Hope this fix your problems..
thanks.. much appreciated if you rate this help.
May 29, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
MY MONITORS DILPLAY FLICKERS!! RED Color becomes black
Display driver is not installed on your system kindly installed VGA driver.
If issue has been not resolve than change your VGA cabal For the same.
Thanks
Abhay Singh
Nov 24, 2009 | SAMTRON 55V 15" CRT Monitor
My pc monitor keeps flickering and jumping up and down
It could be some loose connection, check both end of the VGA cables. If this does not resolves the issue, then check if you monitor is near a high voltage cable/magnetic waves/microvave(microwave oven).
If this still dosent resolves the issue, click on the OSD menu option on the monitor, see if you find Degasus, try and use that. If not you need to repair your monitor.
All the best.
Regards,
Shrey
Oct 09, 2009 | IBM P 202 21" CRT Monitor
Monitor flickers with changing colors making it almost impossible to see anything, it started & stopped for a while then after maybe three weeks after it started again ! I tried disconnecting & changing...
I suggest upgrading the OS on these problem terminals to the latest on the wyse website. It might be an incompatibility with the monitor and terminal (might have been fixed in later builds), in which case you will need to log it with Wyse directly, as they will need to test this.
Chances are though you either have a faulty monitor cable, a faulty unit, or faulty monitor. Perhaps even a combination of more than one of these above problems. Try to rule out each bit of hardware before blaming anything in particular.
Try a few different monitor resolutions, colour depth and refresh rates too. Cant hurt :)
Mar 31, 2009 | WYSE Winterm S30 Network Terminal
Gateway monitor flickering
I had an older mac Mini that would do that and could not use it with that monitor. it worked fine with my G5 powerpc, was probably a video card issue. I got it to work also by connecting with a VGA connection rather than a DVI
Mar 24, 2008 | Gateway FPD2275W LCD Monitor
Dell Dimension 2400 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
