My hand set states it is not connecting to the base, This is with-in 5 feet. It worked before, now nothing. whats up? I've tried to reset everything.Even let the battery go down then retried again and still nothing. Do I need to inter a new code # or some simple like that? Please help, Tommy at pro1bus@gmail.com or 831-707-0562
  • 2,382 Answers
Hi, if you have tried the best solution which is resetting the handset and it still does not connect to base, entering a new or the old code won't make any change a solve the issue. Then you have to contact the technical department of the phone company to make a report....
Posted on Oct 03, 2010
Hand set says connecting even before it is reset with new base.
This sounds like a registration problem, each 'old'
handset must be de-registered from its original
base and then registered to the 'new' base.
NOTE: the CS6229 handles a maximum of 5
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
You will need to clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( II.) To clear the base of all handset registrations
( if needed, else skip ahead to ( III ). )
1. press [Find Handset] on the base and hold
past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink. 2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration ===============================
( III.) To register each handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
Good luck !!
Jul 23, 2015 | Vtech Lands Phones
Panasonic KX-TG6700
Did you try disonnecting the unit from the power for a few hours?
Apr 13, 2008 | Panasonic KX-TG6500 Cordless Phone
Factory reset for ht-q20??
1. RESET
While "NO DISC" message appears on the display of main unit, hold the main unit's STOP button for longer than 5 seconds. "INITIALIZE" appears on the display and all settings will return to the default values.
Using the RESET function will erase all stored settings.
2. Firmware update
Upgrade File ver 1.3, All OS (ENGLISH) 18 Sep, 2007
Upgrade guide ver -, All OS (ENGLISH) 21 May, 2007
HT Q20
Dec 03, 2012 | Samsung HT-Q20 Theater System
Registering Handset to Base Station
Registering the handset to the base station has nothing to do with your wireless router. The handset and the base act like walkie talkies. The signal from the handset must match the signal in the base station. The handset may have a reset button of its own, or a sequence you must go through to register the handset to the base. Try removing the battery from the handset and see if that will work. If not you need the manual to tell you what to do to register the hand set to the base.
Dec 12, 2017 | RTX DUALphone 3088 for Skype
I have just inherated the at&t e5634b phone system. I have replaced the batteries in the hand sets. As per the manual I have de-registered each hand set. The problem is that when I register the...
This problem can be caused by the following, A bad battery, (which you say you are all new). A full base memory and a Faulty main base unit
This main base unit can only expand to four handsets and no more. If the base unit has been reset then the assigned numbers for each handset would begin with " handset 1" if they show any other number when reset then it would not have been reset..To re-set main base you will have to
De-Register All Handsets
Unplug the power supply from the base unit then Remove all handsets from the charge cradles and base then Press and hold the PAGE button on the base.
Plug in the power supply again while pressing the PAGE button, Continue pressing PAGE until the IN USE and CHARGING indicators are lit. (this could take up to 10 seconds)
Release the PAGE button All Handsets will display "enter base id".
If this does not solve your problem then you will have to replace the main base
Apr 20, 2017 | AT&T E5634B Phone System w/ Caller ID
I have purchased a SL82318 Handset. I have a SL82318 system, with all three original handsets working perfectly. This fourth handset displays: "Connecting..." and nothing else. According to...
*331734#Menu Select on the handset should de-register that handset from the old base, then you can register it to the base as per the manual (put it in the base and hold down the handset locator button for 4 seconds)
Jan 04, 2011 | Vtech SL80108 1.9 GHz 1-Line Cordless...
Cordless phone red light blinking no dail tone all of this happened after a breif power outage today
You have not mentioned the model but it is for sure that your phone inter communication has failed. Hence the base and the hand set is not locking on. Remove off all the leads and clean the base terminal charging points. open the hand set and reset the battery, dry off any residue of water moisture on the front panel of the hand set. now connect back and lock it in to see if the set latches. If not check if the power outage had caused a failure in the base unit DC input. check the area for +5 volt to processor , optocoupler and sub circuits. also checck the battery of your hand set for low voltage as it would have gone below the threshold level of charging. Test the voltage, if not replace the battery and set . it must work then. Helpful? Good day
Jul 22, 2010 | Lands Phones
Second hand set doesn't work
The second hand set problem was resolved by placing it face down on the base unit. Apparently it needed to be reset for some quirky reason.
I found the solution in the manual, and although it didn't really address the problem, I thought it was worth a try. It worked.
Feb 17, 2008 | Uniden TRU 448-2 Cordless Phone
20 people viewed this question
k24674
jasbo
jasbo
