Question about Samsung Televison & Video
29 inch TV model no.CS 722 AN. H. output tr blows off and stand by blinks
  • 49 Answers
Sir 1- Use heavy ampier transister for hor output
2-measure h output transister base and emitter resestance value it is nearabout 15to33 ohms,you can use.
3-check lot by replacement
Posted on Oct 03, 2010
Lg 29'' flatron tv circut diagram
Check the LOT. If it is faulty, horizontal output transistor will blow out. Check the capacitor connected across the collector of the horizontal output transistor to Gnd. If it is bad, or have any loose solder terminals, H-Out transistor will blow out. If you wish to get more http://electronicshelponline.blogspot.com/ check this link. Pull up older posts there, either by its left side bar, or see it in Timslide option.
Jun 22, 2013 | LG 29" Stretch LCD 17:6 aspect Mo TV
I have sony 29'' crt tv . model no KV-DZM61 .when the tv statrs on it shows green led,and after few second the led glows red and it blinked for 2 times .then the tv goes in stand by mode
2 blinks means - over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
Jun 23, 2011 | Sony KV-XR29M61 TV
I have a sony 29'' crt tv . model no kv 29xr m80.when the tv statrs on it shows green led,and after few second the led glows red and it blinked for 8 times .then the tv goes in stand by mode .which section...
Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Mar 28, 2011 | Sony KV-XR29M61 TV
Which remote control used for 29" TV CS-29L30ML SAMSUNG
If there is any customer sevice center of Samsung nearby, please enquire there about the remote model of your tv set by giving your TVs model number, usually marked on the back side of the tv. They can surely guide you.
Oct 15, 2010 | Samsung CW29M64NS 29" TV
To Connect AV Cable from Panasonic VCR to Sony 29 inches
You can either connect the antenna output of the VCR to TV ant in or hookup the audio/video outputs from VCR to audio/video TV inputs. If using the antenna output you need to sellect channel 3 or 4 to view VCR. If using the adio/video lines you need to select the line input on TV to view VCR.
Feb 18, 2009 | RCA F20640BC 20" TV
Sony 2167 No power on
I have not worked on your particular model. But, I have serviced many TV sets over the years. My answer will ge generic.
Check all the capacitors in the horizontal output stage and power supply areas for high ESR. All the caps that are out of spec must be changed.
The high voltage multiplier & flyback can also cause the fault you are having.
You have to consider that the DC voltages are not the only important spec that has to be met. There are also many power drive signals that work with reactive devices. If there is any defect in the critical areas there will be failures.
Jerry G.
Nov 26, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Weight
I have one of these TVs and still love it.  The manual says that the weight is listed at 250lbs (approx.).  Most of the TV stands in retail stores only hold up to 240lbs., so that is something to consider.
Sep 23, 2007 | Mitsubishi CS-40503 TV
check video processor output diagram and signal amplitude if u can find video processor raplace it and try it must work
Aug 13, 2007 | Sharp 32C-240 32" TV
Televison & Video Logo
53 people viewed this question
Henry  Thomas
Henry Thomas
