Question about OKI Pacemark 3410 Matrix Printer
Theres power but no lights coming on
Theres power but no light on my oki 3410 printer and ti will run for some time then goes off, and if I remove the cable going to the printer head then switch on power the power supply will be ok accept for the control switch and the lights.
  • Anonymous Mar 17, 2009
    if i turn on the printer it doesn t work i check the cable but theres no power, its not use
  • 40 Answers
I think your power supply fan is faulty ?
Hope this helps.
Posted on Nov 29, 2008
(1) Open the access over.
(2) Pull up and rotate the head clamp 1 to unclamp the printhead 2 as shown fig. 3.3.1.
(3) Disconnect the printhead 2 from PC connector 3.
(4) To install, follow the removal steps in the reverse order.
Notes on installation:
(1) Insert the printhead 2 into the PC connector 3 while pushing it against the carriage
frame 4.
(2) The head clamp 1 must surely be sandwiched between printhead 2 and carriage
frame 4 as shown Figure 3.3.2.
(3) Be sure to check the gap between platen and printhead (see 4).
(4) Be careful not to touch the print head while it is very hot.
(5) Make sure that there is not any dust or oil on the connector contact section A. If it
is found, wipe it off by alcohol. Good Luck ! I couldn't attach any pictures.
Dec 17, 2010 | OKI Microline 3410 Matrix Printer
Power light is on but no other buttons work.
I too have this problem. Any answers would be greatly appreciated.
Dec 01, 2010 | OKI Pacemark 3410 Matrix Printer
Is there a way to reset the printer if you want to stop a job midway when i print a report? OKI Pacemark 3410 Matrix
yes, clear all print jobs in the print queue on the PC.
The press "Stop" on the printer.
2. Turn the printer off for 1 minute the restart
3. Shut the PC down and restart.
This will clear the memory for both devices.
Apr 16, 2010 | OKI Pacemark 3410 Matrix Printer
Pacemark 3410 - printer shuts off after 30 seconds
Good chance the power supply is burned out. Located in the rear bottom of unit. You must remove the whole machine from case to get to it. Costs about $200.00 at any shop.
Aug 04, 2009 | OKI Pacemark 3410 Matrix Printer
Oki c3400n all 3 lights are flashing amber 2 times a second
i suspect an ouput sensor actuator beeing dislodge in the process of paper removal
Mar 18, 2009 | OKI C3400n Laser Printer
I need to test several OKI 3410's
To perform the Font Sample Test, follow this procedure.
1. Verify that continuous feed paper is installed.
2. Verify that the ribbon is correctly installed.
3. Verify that the width of the installed paper matches the paper width menu setting.
4. Power OFF the printer.
5. Press LINE FEED as you power ON the printer.
6. The test will print.
7. To stop the test (at any time), press SELECT.
8. When the two page test is complete, the SELECT lamp will turn OFF.
9. Press SELECT to place the printer ON-LINE.
Good Luck
Feb 04, 2009 | OKI Pacemark 3410 Matrix Printer
I have an Okidata Pacemark 3410 and the alarm light is blinking and will not print. i turn on and off and the alarm light just comes back on.
Normal 0 This doesn’t help fix all printers because each situation is different and in most cases we don’t have enough information to determine the fix. So hope this will provide some help.
Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 29, 2008 | OKI Pacemark 3410 Matrix Printer
3410 Oki printer
If your print fades in then out every 5-6 lines, your platen probably has flat spots on it. This can be caused when someone forget to perform an alignment on a PH.
To run a test page you can power off the printer. Hold down the LF key and power on at the same time, this will print a self test.
Feb 04, 2008 | OKI Pacemark 3410 Matrix Printer
OKI Pacemark 3410 Matrix Printer Logo
173 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
