Question about Dacor Preference SGM304 Gas Cooktop
Dacor cooktop ignition problem
One of the burners on my Dacor 4 burner gas cooktop no longer ignites automatically, it just continues to spark, but it will light with a match. Is this something I can fix myself, and if so, what should I do? ejgs
  • advt-ny Aug 02, 2008
    I have same problem since unit was new. tech came once and still same problem - was intermittent. Now that ignightor does not spark at all.
    I've had the unit 5 years and know about seating parts correctly, keeping it clean etc. Tech around here is terrible. Any thoughts out there?
    Are the ignightor replacement fairly straight forward for a reasonable handy person?
  • Anonymous Mar 18, 2014
    ONE burner on a gas cooktop will not light
  • 110 Answers
Posted on May 30, 2008
Dacor cooktop igniter clicks but burner does not ignite. This is true for all burners. after repeated attempts the burners will start - What can I try?
Take a hairpin or a toothpick and clean the hole near the igniter so that the maximum amount of gas can flow to the spark is what I would try.
Dec 29, 2016 | Dacor Cooktops
After cleaning one of the small burners will spark
make sure the little hole right by the ignitor isn't plugged.
Jun 15, 2010 | Dacor Preference SGM365SS Gas Cooktop
10-12 year old dacor 4 burner epicure cooktop --left front burner
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
May 29, 2010 | Dacor Epicure ESG366 Gas Cooktop
R rear burner not sparking
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
One of the burners on my Dacor 4 burner gas cooktop no longer ignites automatically, it just continues to spark, but it will light with a match. Is this something I can fix myself, and if so, what should I...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 28, 2010 | Dacor Preference SGM304 Gas Cooktop
Our Dacor gas cooktop igniter won't click. When I turn on the burner, you can hear the gas coming out, but no click so the burner won't lite.
Go to and check on how much a new igniter is. Is there two or 4 igniters on your model (lift the top of the range up and it is the little silver piece sticking out with a white base around it), If its 2 is the other side working? Make sure there is no food deposits around where the gas and the spark meet.
May 01, 2009 | Cooktops
Stove top ignition doesn't stop ticking
My Dacor cooktop had a similar problem of continuously clicking igniters. I unplugged it a couple months ago and used a piezoelectric igniter to get it started. Then I looked in the Dacor FAQ and it said to clean the ceramic igniter posts with alcohol not water. I had to scrape some gunk off a couple of the posts with a knife before cleaning with alcohol. Now it works.'
I think the igniters use electrical conductivity to detect when they need to spark, so even slight invisible contamination on the igniter insulator can confuse the sensing system. Also they all seem to fire as a group, so all of them need to be clean because if any one of them is dirty then they will all malfunction.
Mar 22, 2009 | Creda Colonial 42352 23 in. Electric...
In addition to polishing up the end of the igniter as mentioned above, remove the burner cap cover and and the round burner cap. As noted above, electrical contact or grounding is an important element in the spark igniter function. Any poor contact surface can cause the igniters to continue to spark after a burner lites. If everything seems in order, polish the underside of the aluminum burner cap and the top side of the aluminum burner base (where they come in contact with each other). This is part of the grounding circuit for the igniters. I used an "SOS" pad. In our case, these parts had tarnished with age. My wife was very happy when I fixed this one.
Dec 09, 2006 | Dacor Preference SGM365SS Gas Cooktop
Oven Striker
If I'm not mistaken, these dacor cooktops have an automatic re-ignition (meaning if the flame goes out, it will just relight it without you having to do it) If none of your burners will light, you probably have a bad spark ignition module. These are somewhat hard to change, as you have to take all the burners off and disconnect the spark wires and take the whole top of the cooktop off to get to the inner workings. Also, to get these burner bases off it takes a special tool by dacor, AND you usually have to replace all the burner seals once you take them apart.Your other, simpler option is to unplug the cooktop and plug a lamp or something in to the outlet the cooktop is using, just to make sure you have power. Just cause the breaker doesn't look like it's tripped, doesn't mean it isn't bad and the outlet is dead. Hope this helps!
Oct 12, 2006 | Dacor Preference SGM466SS Gas Cooktop
Dacor Preference SGM304 Gas Cooktop Logo
918 people viewed this question
Top Dacor Cooktops Experts
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
