Question about Fujitsu LifeBook Notebook
Replaced fujitsu laptop motherboard and now does not boot up
  • 78 Answers
1. Remove the battery
2. Plug the Notebook directly to the wall outlet
3. Turn it On
4. if it did not turn on return the Notebook and have the motherboard check again. also have your Power Supply check. there is a chance that this is faulty too.
Posted on Oct 03, 2010
  • Jose Reyes Oct 05, 2010
    The laptop will power on, the CPU fan spins and then shuts off after 5 seconds with or without the battery. The laptop screen is black, there is no error beep and does not do POST.
    I think the moteboard is bad but am wondering if there is a trick to starting up laptop after replacing the motherboard.
  • litoslandero Dec 01, 2010
    i am having the same problem. did you find an answer to your problem?
When plug in fujitsu amilo orange flashing light not posting.
Posted on Mar 26, 2011
Fijustu ah530 corei 5 bios password
BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
Fujitsu stuck on logo screen
Assuming you cannot boot at all, this sounds like hardware failure (either motherboard or processor). If you take the laptop to your local computer repair store, they can diagnose the issue more accurately.
If you can get to your boot options, attempt to run any manufacturer diagnosis tools, and it could possibly tell you what is wrong.
Jun 18, 2012 | Fujitsu LifeBook AH531
Fujitsu Siemens AMILO Pro V2030 Not Boot, power button doesnt do anything. Only charging light is on when plugged to power. What should be done?
You have a problem on the motherboard.The power regulator circuitry in laptops is on the motherboard. You'll need to take it to a repair shop.
Apr 04, 2011 | Fujitsu Siemens AMILO Pro V2010 Notebook
Hello my fujitsu e2010 jusr stop working it will
Hi. Try to remove the battery, unplug the ac adapter and press/hold the power button for 10 seconds then plug the ac adapter in. do not put thebattery back in yet. turn the computer on and see what will happen.
If nothing happens, your motherboard needs to be replaced.
Good Luck!
Jun 06, 2010 | Fujitsu Siemens LifeBook E2010 Notebook
I have a fujitsu lifebook that will not charge my battery. I replaced the ac adapter, and i replaced the battery and continue to have the problem
Bad power circuit on the motherboard. Usually part of the motherboard and thus would require motherboard replacement to fix the problem.
Nov 13, 2009 | Fujitsu LifeBook A6020 PC Notebook
Chip very hot on motherboard and laptop will not boot.
well i had a amd chip that would get really hot and it would make the computer not boot up at all so i replaced it and it fixed the problem i was told it was about to go out so maybe this advice will help u good luck
May 26, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Not booting Properly.
have try to reset bios if not u have to reset bios.
Pullcmos cell for 15 seconds from mohter bord also u can reset bios with jumper settigns it is near cmos read carefully on motherbord u can find jumper u can see "clear cmos " on motherbord
May 06, 2009 | Fujitsu Siemens LifeBook E8020 Notebook
Fujitsu LifeBook Notebook Logo
341 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
