Question about Miele W866 Front Load Washer
Dont know were the powder goes or the fabric softner in my miele w735
gittos73
  • 244 Answers
SOURCE: Fabric Softner section won't fully drain....
take your soap draw out pull the fabric softener tub out wash leave all of your soap draw in a bucket of hot water scrub with a brush this should clean a small hole which lets your conditioner out simply fix common fault m8
Posted on Aug 14, 2007
murdozzz2
  • 75 Answers
SOURCE: Fabric Sofner won't dispense
hi there remove the soap drawer then remove the cover over the softener compartment you will more than likely find a blockage in the cover siphon or the down tube on the drawer
Posted on Feb 29, 2008
SOURCE: Fabric softner is building up in dispenser
Same deal - I have to soak up all the residual water in the softener dispenser between washes. (The detergent and bleach compartments are fine).
Posted on Jun 19, 2008
mumma_1
  • 903 Answers
SOURCE: Fabric conditioner drawer
Try cleaning inside the the machine where the soap dispenser drawer fits into. Sometimes this builds up with lots of soap and fabric conditioner residue and stops the conditioner from going through.
Take the drawer back out and look inside where it goes to see if there is a build up of soap etc...
hope this helps
Posted on Nov 03, 2008
barkencoa
  • 3463 Answers
SOURCE: Fabric softner still in draw when wash finished
There is a blockage in the dispenser that is causing the prob.
Remove drawer from dispenser, and thoroughly clean every part of it, taking all the pieces out to do it.
To test it is working, put it back together, and before you put it back in, fill the conditioner compartment with water until it starts to overflow, turn water off, and the remaining water should continue to run out, until it is empty, if it does not , then it is still blocked.
Plz rate my solution.
Thanks.
Posted on Jan 04, 2009
To use liquid detergent does the machine have to come with cup
ROFLMHO Thuli the lid /cap of the detergent bottle is your measure.and yes you just pour it into the water as you would use powder .bleach and fabric softeners are the only thing to keep seperate
May 26, 2015 | Washing Machines
White clothes come out stained
AT LEAST YEARLY YOU HAVE TO CLEAN WASHER ORTHER VICE STAINED COMING NORMALLY.. YOU HAVE TO CLEAN WITH OXSY CLEANE LIKE BORAX,CLOREX,,
Jan 20, 2014 | Miele Washing Machines
Dispenser - which tray to use for liquid detergent?
Liquid goes straight into the wash before you put it on, you can get a liquid ball that you fill and put in with the wash, dispenser just for powder which goes in 2 or fabric softner.
Mar 01, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hey, in which dispenser number do you put washing powder and fabric softer 1 or 2? Thanks
1 is usually for pre-wash, 2 for washing powder and fabric softner goes into the section with the level indicator should be small square section with removable top.
Feb 28, 2011 | Hotpoint Ariston AW125 Front Load Washer
Softner not being flushed into machine
Hiya,
there is only a few reasons for the softener not to filter through firstly i would surgest removing the drawer that the softner goes in & flushing it through with hot water this will help dislodge anything that may have built up inside, sometimes the fabric softner section has a top part that comes off if so remove this & flush both sections, if you can see a black sludge then it is just build up that is blocking the path stopping the softner getting through.
Hope this helps
Apr 21, 2010 | Bosch WBB24759GB Front Load Washer
Whirlpool washer wfw9400sw automatically puts in softner.......
Not normal at all. Compartment marked '1' is for prewash powder, '2' is for main wash and the compartment marked with a flower is where the softener goes. If you've got this right, there's a problem with the machine.
Mar 23, 2010 | Whirlpool WFW9400S
Dark spots on my clean clothes
do you use a lot of fabric softner? If you do this might be your problem try to change soaps and stop useing fabric softner. try useing powder detergent and make sure that it is HE. let me know how it goes thanks
Jun 02, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
"fabric softner staining the clothes"
make sure you delute it with water. yes fabric softner will start to stain your clothes if you use too much of it. I would recomend stop useing it for a while. so you can clean the washer out. There is a product called Washer magic or Affresh that cleans out residues built up in your washer. or you can just run several loads of HOT water and bleach to clean it out. The hot water will melt the left over fabric softner in your washer. Fabric softner is kind of like hardend bacon fat thats what it looks like in your washer after time and if you do not clean your washer it builds up and builds up.
Also i do recomend alternating liquid detergent and powdered detergent. The reason why is powder leaves a residue that liquid takes away and vise versa. try this and let me know how it goes
Feb 12, 2009 | Maytag PAV2300 Top Load Washer
Mile 864 front loader - clothes come out with new grease marks
Problem will be the use of fabric softner or too much detergent. The stain you are seeing is generally to animal fat that is present in fabric softner, Best solution is to cut back on the amount of softner being used, same with powder.
Sep 18, 2006 | Miele W864 Front Load Washer
Miele W866 Front Load Washer Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
