Question about Acer Computers & Internet
I forget my BIOS password please what will i have to do?? Also my acer laptop has problem with harddisk so please give me address of recognised acer laptop service center in surat
    Problem Solver:
  • 9 Answers
I believe probably the easiest and safest way for you is remove your Windows OS Passwords with Windows Password Recovery tools. I found a good one at http://www.reset-windows-password.com last week, and then I downloaded it and used it to remove the lost password within only few minutes. Furthermore, the powerful tool didn't cause a little data lose. It's worth an attempt.
Posted on Mar 15, 2012
    Problem Solver:
  • 9 Answers
If you often change your Windows password or your memory isn't good, it is normal that you forget the password. To help you remember, or on the lowest to help you be in control and know your password, why do not you obtain a software program plan that will reset the password for you? The software program plan is capable of resetting and positively removing the more mature password in purchase for you personally for getting in a location to available your operator account. Why do not you consider a glance at this software program program? Please visit: http://www.passwordseeker.com
Posted on Mar 14, 2012
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 72 Answers
Acer laptop has a special bios sequence that can be so tricky and very confusing but I can
show how to do it in few minutes. These steps are simple and picture illustrated.
You can handle or solve bios password problems by either flashing the bios but this can
be done by a professional which is very risky and can damage the laptop,
Or by replacing certain security chip or resetting the one in the board, this will be costly
and also risky.
Or by contracting the manufacturers. Well, good luck!
Above all am going to show you the simplest way to bypass it. The truth is that the bios
password will prevent you from setting the boot order because the default boot order is
either ide or USB devices.
Don't worry, follow these steps:
1. Switch the laptop, and remove the hard disk from the back of the laptop.
2. You need external USB mass storage drive that you will use to connect it to
another computer.
3. You also need third party software like epm partition magic (click here to
download it). Install this software in the other computer before you plug in the
USB mass storage device.
4. then open the software select on the hdd, then press delete and after that click
apply, the system may require to boot(allow it to do so). When this is done, if
open the epm again, your hdd will show in the window (UNALLOCATED). Don
creates partition, just disconnect the hdd and insert it back to your Acer laptop.
5. Put your bootable cd like window xp or vista. Power on the laptop, it will
automatically enter to boot setup.
6. After the setup and you still want remove the password, you will use bios debug
software. Good luck.
By Divine O Fabian. www.laptopmasterpassword.net
Posted on Oct 08, 2010
  • Acer Master
  • 7,733 Answers
Press F2 during start up; BIOS setiings on password and diasble it.
Post Back!
Posted on Oct 03, 2010
My extensa5220 bios password i forget, what a solution please help
Only place that can help you is Acer Support or Unlockbiosrecovery.com to unlock your bios password. They can both generate a bios master password unique to your laptop that will delete all bios password giving you complete control to your bios setup. Acer Support will charge you $100+ while Unlockbiosrecovery.com on charges $20 and they guarantee their service. I use them often and they have always worked.
Sep 18, 2011 | Acer Extensa 5620 Notebook PC
I have forget my bios password,i removed my batery but i am still having same problem.
hello there!!!
there are many ways to remove or bypass bios password!!!
1. removing battery to drain the data in bios memory
2. short the jumper of the bios mostly found at the lower side of the memory slot.
thanks
Jan 03, 2011 | Acer Extensa 4620 Notebook
How can i fix my acer notebook?i cant open bcos thy have unlock password? when i try to open my laptop it is show up the harddisk security,,, primary master WDC WD1600BEVT-22ZCTLOCK. WHEN i press...
You need to log into the bios and edit the hdd password...
You can press DEL or F2 key when you power ON the laptop... It will take you to the bios setup...
You can navigate in the bios to reach the hard drive password section and you can set the password as blank...
Once you are done press F10 to save the changes and exit out of it...
If it doesnt works, then you can give a try by restoring the BIOS to its factory defaults(using the restore defaults option in bios) which should turn OFF the Bios HDD security feature...
Dec 11, 2010 | Acer Aspire One D250 Netbook
I put the password to my bios, but now i didnt remember my password. i took off the battery for a couple of hours but still the same problem. i try the backdoors password but still the same condition. i...
Unfortunately you must get in touch with acer to reset the password. There is no back door password, those worked in 1999, they are soon 12 year old codes.
Nov 27, 2010 | Acer Aspire 5735 Notebook
I have a laptop acer 5542 i forget my password how to unlock my passworad give the solutions
you will able to remove Acer BIOS passwords by simply opening your notebook and removing the CMOS battery for 30 minutes.
Once your BIOS password is removed, you will need to press the key during POST (Power On Self Test) to enter the Acer BIOS setup.
Nov 26, 2010 | Acer Aspire 5542 Notebook
I have forget my bios password in wipro laptop,so ...
I have a Acer Aspire 5570Z laptop, but i forget the BIOS password would some one please tell me how to reset it as i open the laptop it requires the password to go on
Your response is highly appreciated if possible email it to me at thetaurianbaby@hotmail.com
May 20, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5715Z. Bios password problem
remove the ram at the rear of the unit in the little compartment and look for two metal pieces ( bars maybe) take a paper clip and short out these then replace the ram close the door and reboot.
Please rate this help to keep the free service online++++Thanks for using FIXYA
Sep 07, 2009 | Computers & Internet
Forgot my password in cmos harddisk
The hard disk password is setup using the BIOS configuration, this password is stored on the hard disk and there are no backdoor passwords you can use except the password you created and if you know this password then you can remove it permanently using the BIOS configuration. Moving this hard drive into another laptop will not work either, it won't allow access to this hard disk.
Your only option is to purchase a new hard drive to replace the one with the password.
If you also created a BIOS password, you need this password to get into the BIOS configuration.
All these passwords are created by users to prevent unauthorized access into the laptop and hard disk.
Apr 24, 2009 | Acer Aspire 5602WLMi (LX.AB10J.002) PC...
How can i change my harddisk password in acer aspire 5600 series..
Power on, enter the bios setup (press F2, F10 or [Delete] when powering up and go to the "security" section.
Locate "drivelock" or "harddisk password", from there disable the HD lock.
Apr 24, 2009 | Acer Aspire 5602WLMI Notebook
Password problem
Which Password?? the bios password or the OS login password, POST back i will give you my best help
Jan 02, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
322 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
